GSSE-W Parking lot "swap meet"
Thread: GSSE-W Parking lot "swap meet"
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
  1. #1 GSSE-W Parking lot "swap meet"
    Tn
    If anybody is interested in buying, selling, trading, giving away parts at the event post up what you have or what you are looking for. This will be an informal deal and all parts MUST stay out of the $$$ cabin as we can't afford to risk damage to the rental.
    I'll start, I have;
    - 5.9 bumper covers and side moldings
    - YJ steering box
    - WJ brake/knuckle swap parts
    - D30 unit bearings
    - D30 outer axles
    - 17x9 black steel Pro Comp wheels in good shape
    I need;
    - 2nd gen. GC grill (to be cut up)
    I'm sure I'll think of more crap but this should get it started.
    EDIT- the grill needs to be a 2nd gen grill - the one that isn't flat accoss the bottom. (Thanks Clay)
  2. #2 Re: GSSE-W Parking lot "swap meet"
    Cool idea. Ryan is right- it will be very important to keep the cabin clean... more to come on that later.
    Here's what I'll have:
    random AN fittings, caps, and connectors
    20' coil of 3/8" aluminum tubing
    brand new exhaust hangers from summit racing
    20' of 3/16" 2500psi burst nylon brake line from aircraft spruce
    1310 to 1350 conversion ujoint (1)
    1330 to 1350 conversion ujoint (2)
    ford np205 1310 yokes, ubolt style, 32 spline (2)
    possibly 18" 250lb/in springs and 10" long 150lb/in springs for 2.0" coilovers
    stock ZJ gas tank (free)
    steel winch cable (free)
    VDO mechanical temp gauge with adapters, etc
  3. #3 Re: GSSE-W Parking lot "swap meet"
    sounds like someone's credit card is holding the security deposit.......
    Haven't quite piled up my previous stash of ZJ parts,but...
    -set of stock bridgestone dueler HTs (practically new) on TSI wheels.
    -clear turn signals
    -stock airbox
    if on the offhand chance someone wants any of that shit, let me know. its just collecting dust.
  4. #4 Re: GSSE-W Parking lot "swap meet"
    maryland
    also we should post up a wanted or needed list. I have so much random junk laying around it ridiculous.
  5. #5 Re: GSSE-W Parking lot "swap meet"
    Midlothian Virginia
    Cam bring those conversion joints in case I need to buy them
    I dont have shit for sale...
    a tapped waggy box is about it.
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  6. #6 Re: GSSE-W Parking lot "swap meet"
    Orlando, FL
    I've got a tapped YJ box with tractor supply redneck ram attached.
    www.grandslamsoutheast.com
    My Build Thread
  7. #7 Re: GSSE-W Parking lot "swap meet"
    you run 1350 driveshaft yokes?
  8. #8 Re: GSSE-W Parking lot "swap meet"
    Midlothian Virginia
    Sheeeeet, I read it wrong.
    Nevermind, I will get some baby ujoints myself.
  9. #9 Re: GSSE-W Parking lot "swap meet"
    I also have this available
    It's super nice but I had trouble fitting it to my application. has a bunch of adapters for the probe with it
  10. #10 Re: GSSE-W Parking lot "swap meet"
    May 2005
    Boone NC
    huh huh... you said probe
  11. #11 Re: GSSE-W Parking lot "swap meet"
    Feb 2010
    North East, PA
    built dana 44 and ford 9"
    hydro assist package with tapped xj steering box
    yj springs
    more details available if someones interested...
  12. #12 Re: GSSE-W Parking lot "swap meet"
    Tn
    Quote Originally Posted by Simo View Post
    yj springs
    I assume the hydro assist could be made to fit a ZJ with a front 60? How much do you want for it? You looking for any parts in trade?
  13. #13 Re: GSSE-W Parking lot "swap meet"
    Feb 2010
    North East, PA
    1.5x8x1” hydraulic cylinder (Surplus Center Item # 9-7258-8, DA HYD CYL SWIVEL EYES). swivel npt fittings, ¼” npt hydraulic hoses 36” long, and spare fittings/hoses. Its connected to a stock saginaw steering box off a cherokee that was rebuilt, drilled, and tapped. The pitman arm was reamed to accept chevy 1ton tre's. $125 as a complete package (box-hoses/fittings-cylinder). It has already served well when attached to a front d60 turning 39.5 iroks. However, the box may not help you because I believe the ZJ box has 4 mounting holes while XJ box only has 3.
  14. #14 Re: GSSE-W Parking lot "swap meet"
    Mar 2005
    Bristol Tn
    I have a tail gate for a dodge heavy duty 03-09 white for sale. 200.00
    1- full set of 14 bolt ff drum brake drums, shoes and hard ware. All new except drums 100.00 obo
    1- 4.56 ring and pinion for 14bolt ff. surface rust, great pattern. 50.00 obo.
    1-orbital valve. 20.00 obo
    3- stock 17x8 dodge steel wheels. 100.00 obo
    Let me know what you want and I will load it up.
  15. #15 Re: GSSE-W Parking lot "swap meet"
    May 2005
    Boone NC
    trav any idea what the output on the orbital is? i'll take it if its usable..
  16. #16 Re: GSSE-W Parking lot "swap meet"
    Mar 2005
    Bristol Tn
    It is only a 5.?displacment. It would be great for toyota or something with a 6'' ram. Call me if you want it. I would do some trading.
  17. #17 Re: GSSE-W Parking lot "swap meet"
    May 2005
    Boone NC
    ehh don't worry about it. maybe will can use it
  18. #18 Re: GSSE-W Parking lot "swap meet"
    Aug 2006
    Asheville, NC
    I'll bring a Warn M6000. If anyone with a lighter rig is interested in it just let me know.
    2000 WJ - Stroked, Locked & Long Armed
    2006 XK 2" RC & 31" AT's
  19. #19 Re: GSSE-W Parking lot "swap meet"
    Aug 2009
    knoxville, TN
    yj springs
    what gears, locker, shafts, etc... are in the dana 44
  20. #20 Re: GSSE-W Parking lot "swap meet"
    Feb 2010
    North East, PA
    Quote Originally Posted by scott View Post
    Dana 44 High Pinion front axle from 1979 Ford Bronco with radius arm wedges cast into the axle tubes.
    4.88 gears with master rebuild kit installed
    4340 Warn outer stub shafts and Yukon alloy inner axle shafts
    Spicer 760x U-joints, Aussie Locker in 4.56up case, Drive Flanges, 1310 yoke
    Knuckles reamed (with 7 degree taper) for over the knuckle steering
    Diff guard, trac bar mount modified for 7/8” bolt in double shear
    All brakes, bearings, seals, and balljoints replaced new when rebuilt around 2005
    Extended Ford style radius arms with adjustable length Rubicon Express Superflex joints.
    Was taken out of functional rig in 2008. $900
    Project Dana 44 High Pinion front axle from early 1970s F150 (did not have cast RA wedges). Axle is now a clean bare housing with all bracketry, wedges, and inner C’s removed. Axle is ready to be cut down and/or inner Cs to be welded on at desired caster/pinion angle. Top mounted truss built using ¼” plate to form box around differential.Has original 3.55 R&P and 1310 yoke. $200
  21. #21 Re: GSSE-W Parking lot "swap meet"
    Aug 2006
    Asheville, NC
    I've also got a 31-spline mini spool for a Ford 9", some 15x8 5on5.5 wagon wheels, and some 8.8 disc brake parts. I don't plan to bring any of this stuff unless someone is interested though...
  22. #22 Re: GSSE-W Parking lot "swap meet"
    Anybody want me to bring any of this?
    Also, I NEED one Warn winch solenoid that looks like this if anyone has an extra laying around
  23. #23 Re: GSSE-W Parking lot "swap meet"
    Member S-10 Seanzy's Avatar
    Aug 2006
    Bristol, TN
    I wouldn't mind you bringing the 60 yoke and 1330 to 1350 bastard joints just in case I have a really bad breakage weekend. As of now I don't need them, but I'd appreciate you throwing them in the truck just to be on the safe side.
  24. #24 Re: GSSE-W Parking lot "swap meet"
    Quote Originally Posted by S-10 Seanzy View Post
    sold
  25. #25 Re: GSSE-W Parking lot "swap meet"
    Mar 2005
    Bristol Tn
    Cam I have a solenoid warn brand I will bring.
