I want/need to get my 242 higher. It hangs a bit too low, I have seen some clock a 231 to get more clearance.
Anybody know of some good info on how to for a 242? Maybe a clocking ring? I saw somewhere someone said you can just re drill the holes and turn it.
I have looked long and hard but have sume up empty handed.
clockign ring is the same between the d300 231 242 and 249. and probably other as well.
I got a showing for my house in 15 min but when i get back i'l post it in the tech write-up room.
Hmm... I saw what you posted in the other thread. I may make one, may buy one. I don't know yet. Either way it's getting done.
I need to do some research. I read somewhere there is a slight difference between 231 and 242 stock mounting angles... making the rings different? IDK.
But thanks alot for the info and adobe files
http://cgi.ebay.com/ebaymotors/ws/eB...category=46104
Anybody see any reason this wont work? Seems like a good price.
Never heard of them but no it doesn't look like too bad of a price. I didn't really read it over...just glanced at the pic and price.
I usually source all my clocking rings and adapters from Novak. D300 clocking ring is $122.
http://www.novak-adapt.com/catalog/kit_153.htm
I'd buy it for the extra cash knowing it is from Novak, and bought through a reputable vendor. I just want to make sure it'll work for my 242.
Only thing I don't like about the Novak one is it is so long, 7/8" takes alot of the spline engagement away, unless I got a new shaft, but thats not what I want. The thinner the ring the better.
well, I found a guy on pirate selling rings that'll clock a 242 if a 300 or 231 will bolt to my tranny at only 61.00 shipped! Looks like I will be clocking my t-case! My belly skid is going to be WAY up there now.
I'll let you guys know how it works out.
I have been planning to give my WJ a tummy tuck and had considered a clocking ring also. Im just not sure how much angle the front d/s will take since it is the factory one with the rezeppa type cv joints. Are you running a double cardan style front d/s?
Update?
Me or the OP? I did the tuck but didnt clock the case. The front ds wont take the angle. I'll have to wait until I install a hp front axle.
I would love to see how this turns out. I'm going to have a 2 inch lift and wonder if I could get away with clocking mine up a little. The Tcase is always the first thing that hits...
2 inch lift? Get the factory skid plate.
Even at 2" the front ds may not like being clocked up. Only one way to find out.. Of course you have a zj so you could bolt in a hp30 so do it all at once.
Lift it more than 2" then. Youre going to anyway. Just skip the bb step.
Just get a Clocking Ring Great Lakes Off Road (you can find them on Pirate) $65 shipped. You get the ring and all the hardware its a great buy.
I did use a dead blow hammer to make a little more room above the 242 so I could clock it more. I got over 2 inches more ground clearance and only used the middle clocking position.
-TheCompound
I cannot find the Clocking Ring Great Lakes Off Road makes ? Can someone PM or reply to link ?
need it for 242..
thanks!
Joe
http://lmgtfy.com/?q=great+lakes+off+road+clocking+ring
first two search results bring it up....
I was a little thrown off by the fact they said it was for the D300 and the NP 241 and the 208.
Are they the same size as a 242?
The bolt spacing on the flange is the same.
[QUOTE=Dustmuffins;293082]I was a little thrown off by the fact they said it was for the D300 and the NP 241 and the 208.
Are they the same size as a 242?[/QUOTE
Yes they are the same...
-TheCompound
awsome, everything i needs to know. Thanks all
