dp96zj's Maintenance Thread - Page 8
Thread: dp96zj's Maintenance Thread
Page 8 of 13 FirstFirst 12345678910111213 LastLast
Results 176 to 200 of 324
  1. #176 Re: dp96zj's Maintenance Thread
    Senior Member dp96zj's Avatar
    Texas
    Hmmmmm....
  2. #177 Re: dp96zj's Maintenance Thread
    Yea that thingy riight thar ya yep that... that is yer prolem...
    2004 Ford Lightning
  3. #178 Re: dp96zj's Maintenance Thread
    Texas
    haha yeah I hope so. It seriously felt like someone dipped it in motor oil.
  4. #179 Re: dp96zj's Maintenance Thread
    Houston, TX
    hmm kinda glad my filter is easy to get at now
  5. #180 Re: dp96zj's Maintenance Thread
    Texas
    Averaged ~2 more MPG with the new fuel pump, and that was driving 60-70mph most of the time with a steady crosswind. I still have the vacuum leak (as noted by the auto-switching to the defroster at WOT), but I'm gonna put that off until summer when I have some downtime.
    Next on the to-do list: get it inspection-worthy, as my sticker expires this month
  6. #181 Re: dp96zj's Maintenance Thread
    Texas
    My new exhaust routing:
  7. #182 Re: dp96zj's Maintenance Thread
    SL,UT
    NICE!!!!!
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  8. #183 Re: dp96zj's Maintenance Thread
    Austin, TX
    You forgot your tip.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  9. #184 Re: dp96zj's Maintenance Thread
    Texas
    My bad, this is how it's gonna look. I'm considering getting the whistle tip so I can go whoo-whoo!
  10. #185 Re: dp96zj's Maintenance Thread
    Member rodd88's Avatar
    Feb 2010
    El Paso
    Looking sweet dude!! Did you finally slap a muffler on there?
  11. #186 Re: dp96zj's Maintenance Thread
    Texas
    Well, I *did* have a muffler on there. The muffler and that nasty tail-pipe were just to get it inspected. It's all off now though
  12. #187 Re: dp96zj's Maintenance Thread
    Feb 2010
    El Paso
    Shoooooot ya need to get inspected by the shop by my house hehehe
    Originally Posted by dp96zj
    In short, JU is for mallcrawlers, MC is for people looking for answers.
  13. #188 Re: dp96zj's Maintenance Thread
    Mar 2010
    Houston
    God Dave, that exhaust was ugly. What did it sound like?
  14. #189 Re: dp96zj's Maintenance Thread
    Texas
    The UPS man dropped off a couple packages today
  15. #190 Re: dp96zj's Maintenance Thread
    Member ZJ4.Slow's Avatar
    Mar 2008
    Houston, Texas
    uhhhh ohhh....
    1995 ZJ Laredo 4.0 Project Never Done...Build 5 Speed ax-15/231 4x4 conversion
    and a stock 99 WJ QD
  16. #191 Re: dp96zj's Maintenance Thread
    Austin, TX
    A big box of dildos.
    Jon
    95 ZJ, it gone.
  17. #192 Re: dp96zj's Maintenance Thread
    Texas
    How did you know!?!?!?!?
    They were delivered to the wrong address, so they'll go and ship it back to you
  18. #193 Re: dp96zj's Maintenance Thread
    Austin, TX
    It's a turbo charger!
    Jon
    95 ZJ, it gone.
  19. #194 Re: dp96zj's Maintenance Thread
    Mar 2008
    stationed at tacoma wa
    did he deliver in the rear? handle with care?
    -e-boner
  20. #195 Re: dp96zj's Maintenance Thread
    Tn
    What did the controller run ya'? (if you don't mind me asking)
  21. #196 Re: dp96zj's Maintenance Thread
    Texas
    It was $130 + $8 or so for shipping. If you wanna check it out, this is the website:
    http://www.a1electric.com/Merchant2/...ode=FAN-PWM-V3
    I ordered it on 7/22 and got it today, so the company works pretty fast.
  22. #197 Re: dp96zj's Maintenance Thread
    Cool. Are you deleting the clutch fan?
    2004 Ford Lightning
  23. #198 Re: dp96zj's Maintenance Thread
    Texas
    Most likely. Mainly because I don't think there's enough room for both fans. If for some reason I can squeeze both of them on, I'll try it out.
  24. #199 Re: dp96zj's Maintenance Thread
    Mar 2008
    if you did that you would want to do a push and pull set up... with the electric in the front of the radiator and the clutch meat grinder behind
    -e-boner
  25. #200 Re: dp96zj's Maintenance Thread
    Beaumont, Texas
    Just ditch the mechanical fan. Taurus is way better. The trick getting it mounted and still having some type of shroud to direct air flow.
