dp96zj's Maintenance Thread - Page 2
Thread: dp96zj's Maintenance Thread
Page 2 of 13 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 324
  1. #26 Re: dp96zj's Maintenance Thread
    Austin, TX
    zj95 has a new hoe.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  2. #27 Re: dp96zj's Maintenance Thread
    Senior Member dp96zj's Avatar
    Texas
    zj95 has a new hoe.
    Haha funny guy!
    Ordered the new radiator last night, lift comes next.
  3. #28 Re: dp96zj's Maintenance Thread
    Member ZJ4.Slow's Avatar
    Mar 2008
    Houston, Texas
    Haha funny guy!
    Woot! lift
    1995 ZJ Laredo 4.0 Project Never Done...Build 5 Speed ax-15/231 4x4 conversion
    and a stock 99 WJ QD
  4. #29 Re: dp96zj's Maintenance Thread
    Texas
    radiator's supposed to come in wednesday, should be getting a half dozen boxes of goodies later on in the week!
  5. #30 Re: dp96zj's Maintenance Thread
    Dinwiddie, VA
    "Matt"
  6. #31 Re: dp96zj's Maintenance Thread
    Austin, TX
    And the parts pile begins to grow!
    Jon
    95 ZJ, it gone.
  7. #32 Re: dp96zj's Maintenance Thread
    Texas
    First package arrived
  8. #33 Re: dp96zj's Maintenance Thread
    Austin, TX
    It came with a cat.
    Jon
    95 ZJ, it gone.
  9. #34 Re: dp96zj's Maintenance Thread
    Texas
    Haha no, my mom actually found that little guy running around the school where she teaches. His name's Buc-ee
    Rad will be going in tomorrow, depending on if I feel like working in 100* heat (with humidity) or not.
  10. #35 Re: dp96zj's Maintenance Thread
    Texas
    New radiator is in. Install went a hell of a lot quicker than when I did it the first time, and it took me only about 30 min to get the "semi-old" one out. However, I had the same problem installing the all-metal as I did with my last one: the holes on the KOR rad support aren't the right spacing, one of them is about 1/4" off . After trying to wiggle it in, I said screw it, and hacked off one of the posts like I did with the last radiator.
    Side-by-side:
    Depth comparison: The new CSF has a 1/2" thicker core than the OEM replacement, as well as it is a great deal heavier.
    I also used this time to replace my leaking tranny lines, so all in all a productive day.
    Edit: If anyone has a use for a year-old plastic tank radiator (maybe for a rig you're trying to sell or something), I have one you could throw in. Definitely don't recommend it on anything that sees trail time.
  11. #36 Re: dp96zj's Maintenance Thread
    Texas
    Oh wait, what's this???????????????????????????
  12. #37 Re: dp96zj's Maintenance Thread
    Mar 2008
    Houston, Texas
    MmMm, so we putting the lift on tonight?
  13. #38 Re: dp96zj's Maintenance Thread
    Texas
    Christmas!
  14. #39 Re: dp96zj's Maintenance Thread
    Austin, TX
    Is it installed yet?
    BTW your control arms are bent.
    Jon
    95 ZJ, it gone.
  15. #40 Re: dp96zj's Maintenance Thread
    Houston, TX
    haha!
    first thing first take all the arms apart and service them while it's nice and easy to get to them!
  16. #41 Re: dp96zj's Maintenance Thread
    Mar 2008
    Houston, Texas
    That's some good lookin pron David
  17. #42 Re: dp96zj's Maintenance Thread
    Texas
    Alrighty, got em all disassembled and cleaned up.
    ____________
    A couple questions: First: I know, I know, they're gonna be bashed on rocks and stuff, but for when I'm cruising the malls, I want em to look good . But seriously, what do y'all recommend for the rust on this, as well as the flex joint ends (visible in first pic). Just scrape the rust off and put some sort of clear coat over it? I really don't want to respray them entirely, unless I can find a similar color.
    _________
    Second, should I replace this bushing while I have it off of the heep?
    Thanks in advance, guys!
  18. #43 Re: dp96zj's Maintenance Thread
    Austin, TX
    Replace it before it gets any worse, so then you won't have a 'clunk' whenever you accelerate from a stop.
    Jon
    95 ZJ, it gone.
  19. #44 Re: dp96zj's Maintenance Thread
    Texas
    Got the rear t-bar and shocks today. one small concern though, there's a little gash on the t-bar.
    It's about an inch long, maybe 1/8" deep. Not enough to break through, and the track bar looks like it's about 3/8" thick. I know the pics suck, but it's the best I could get.
    Should I try to sleeve that section, since I know there's a lot of force put on the trackbar, or not worry about it? I'll try to take some better pics if they're needed.
    Edit: The last pic is probably the best for judging how deep the cut is.
  20. #45 Re: dp96zj's Maintenance Thread
    Midlothian Virginia
    I wouldnt really worry about it, if you wanna do something quick, just throw some 1/2x1/2" angle iron on there and stitch it. That will stiffen it up, but honestly, it will be fine like it is.
    As for the rust on the control arms. Sand it with an angle grinder( like an 80grit flap wheel) and repaint the whole thing if you want it all one color. A metallic silver would look similar to the other ones, noone will notice.
    Looks good.
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  21. #46 Re: dp96zj's Maintenance Thread
    Texas
    Looks good.
    Thanks maxx. I don't have access to a welder (yet), so I'll probably leave it as is. I'm planning on sanding the LCA's and maybe throwing on some of the hammered paint on them, nothin too special.
  22. #47 Re: dp96zj's Maintenance Thread
    Midlothian Virginia
    Mail it to me, I will weld some shit to it, and mail it back
    But really, it looks like you got a fun weekend ahead of you. Is there a date of install?
  23. #48 Re: dp96zj's Maintenance Thread
    Texas
    I'll send it out, only if it comes back with a set of sliders
    As for the install, I work weekends. So depending on when I get the stuff needed from Kevin's, that'll decide which week I start workin.
  24. #49 Re: dp96zj's Maintenance Thread
    Austin, TX
    Bring it to Austin since my Heep can't make it out to CS, I'll install/weld/etc. it for ya.
    Jon
    95 ZJ, it gone.
  25. #50 Re: dp96zj's Maintenance Thread
    Texas
    Painted the LCA's, turned out pretty good IMO. Replaced the worn bushings as well.
    Also painted the coils, rear track bar, and shocks.
    Almost time for the swap, expecting some Moonworks and KOR gear in the near future!
