Dual batteries.
Thread: Dual batteries.
Results 1 to 24 of 24
  1. #1 Dual batteries.
    May 2008
    Detroit
    Who is running what, how is wired up, how do you like it. I just finished mine and it worked out great. I’m using a solenoid and a dpdt switch. My three switch positions are ignition on = batteries connected. Position 2 main battery only (solenoid off). Position 3 full time both batteries connected. I’m running a red top and a purple haze DC. Next comes the tunes, inverter, OBA, CB, and finally I can throw my winch on.:
    http://www.mallcrawlin.com/forum/showthread.php?t=18938
  2. #2 Re: Dual batteries.
    Senior Member greengc4x4's Avatar
    Feb 2008
    lima,ohio
    Dumb question, in what situations will you use position 3? Also, what are the benifits of running a dual battery setup?
    '98 ZJ 5.9L Ltd
    UC Springs/.5" spacer/MX6 Shocks/SCT Tuned/BBK 52mm TB/K&N FIPK/Amsoil Filter/"Jeep" Valve Covers/Doug Thorley Headers/Random Technologies Cat/Magnaflow/"Kolak" Ignition/Optima Redtop/Lotek Dual Pillar Pod/AEM Tranny Temp Gauge/Mag-Hytec Tranny Pan/RB1 WJ Nav/Vancos/EU Headlights and Turn Signals/Turn Signal Mod/JKS Disconnects
    Waiting to be installed
    M1/Insulated Fuel Rails/24lb FMS Injectors/Underdrive Crank Pulley/Walbro Fuel Pump/Prothane Bushings/Hotchkis Swaybars
  3. #3 Re: Dual batteries.
    May 2008
    Detroit
    Quote Originally Posted by greengc4x4 View Post
    If for some reason there was not enough current left in the primary battery to trigger the ign-on position, I would default to this setting and draw current from the aux battery to trigger the solenoid and connect both batteries. This would give me the starting capacity of the aux battery to overcome the deficient primary battery. I see I have an error in my shizmatic where Im showing position 3 as being powered by the primary side. Switch position 3 should be getting power from the aux battery.
    When running lots of externally powered crap, 12VDC or 110AC via a power inverter, it is beneficial to run a stand alone battery that powers these items without interfering with your primary starting battery. The idea is that most of the externally powered junk will be used with the key off, and will only draw from the aux battery. There is also a huge benefit when running and using high current drawing devices like winches. Having double the amp capacity on-tap eases the load on the alternator and will provide much better performance. Example, as soon as I finished this job I immediately noticed that all my running lights were brighter, and the heater blower seemed to blow a bit harder as well.
  4. #4 Re: Dual batteries.
    Feb 2008
    lima,ohio
    Quote Originally Posted by albersondh View Post
    AWESOM! This is just the thing I have been thinking about doing lately. I knew I wanted to run two batteries, I just couldnt find a good write up or schematics on how to do it. You may be recieving a few PM's from me in the future BTW, im only a couple hours south of you in lima, ohio
    '98 ZJ 5.9L Ltd
  5. #5 Re: Dual batteries.
    May 2008
    Detroit
    Cool Im glad it helps, for sure let me know if you have any questions. Its pretty straight forward....
    Anybody else care to share there DBS with us?
  6. #6 Re: Dual batteries.
    If you check out my build thread I did a write up on the dual battery set up I did:
    http://www.mallcrawlin.com/forum/showthread.php?t=3556
    Yes one of the best things about a dual battery set up is being able to jump start yourself, I have had to do it several times.
    The other good thing is on LONG winch pulls I can switch both batteries together to not drain the main battery as much.
    I absolutely love my set up.
    Dirk
  7. #7 Re: Dual batteries.
    Mar 2010
    British Columbia, CAN.
    nice setup!!
    excuse my newbness, but could you run it with out the switch and just direct wire acc. to the secondary batt??, ie: inverter, 12v socket that kinda thing???
    lifes tough, but its even tougher if you're stupid
  8. #8 Re: Dual batteries.
    Oct 2010
    Texas
    Quote Originally Posted by tupperwgn View Post
    nice setup!!
    I have mine run this way. Hot to hot and negative to negative just like in my diesel. I just like having the extra juice and it works great. Just be sure and use the same batteries and good cables.
    1993 ZJ slightly modified, 4 linked and Jocks.
  9. #9 Re: Dual batteries.
    Senior Member Lifetime Supporter 5.9 ANDY's Avatar
    southern afganistan
    thats what mine is right now, my batteries are wired together as one, i have like 2/0 copper wire between them, and on my grounds.... very good current flow.
    proud Lance Corporal in the Unted States Marine Corps.
    This website is bad for the health of your vehicles, enjoy your stay
  10. #10 Re: Dual batteries.
    Oct 2006
    Calgary, AB, Canada
    I have mine wired the same as the original poster.
    FYI a stock XJ battery tray is surprisingly simple to mod to fit into where the ZJ airbox is.
    1998 5.9er, 6" Claytons Long arm, D30(elocker), Rubi D44 rear, TJ Addco rear sway bar, WJ knuckles/brakes, 4.10s, 33s, 9.5ti
    '93 ZJ LTD, 5.2L, Claytons Longarm, 8" lift D44 front(w/elocker), D60 rear(welded), 37" IROKS, 5.38s, 9.5ti<scrapped>
  11. #11 Re: Dual batteries.
    Dec 2009
    south jersey
    damn, this is something im gonna have to do when it gets warmer out. Nice setup
    97 Grand cherokee silver orvis edi-7" claytons lift longarmed front and rear on 36" Iroks
    91 mustang gt-stock block,stock heads,cartech turbo kit,T56 trans= 397rwhp and 436rwt on 8 pounds
    91 xj-3in shit lift,bushwackers,33" claws SOLD
  12. #12 Re: Dual batteries.
    southern afganistan
  13. #13 Re: Dual batteries.
    Member xtremzj's Avatar
    Sep 2005
    nh
    sorry for the bump. But i just bought the Kodiak setup for the dual batterys. What is everyone using for battery trays?
    98 GC 4.0 BORED .60, 4.7 stroker, rustys 4.5 custom lift, fastman tb, oba, 33 swampers this that and whatknot...
    92 subaru justy rally car mazda b6t- 1300lbs + 250hp = crapping pants
    run over a HONDA its your CIVIC duty!
    My jeep won the war, your honda mows my lawn.
  14. #14 Re: Dual batteries.
    Jan 2010
    SLC UT
    Try reading 3 posts up.
    93 ZJ long arms, 35's, F/R Long arms, 4.56 gears, and a bunch more
    98 5.9 slate gray 4" lift with stuff (sold)
    96 ZJ Lift, Long arms, 35's and a bunch of other shit! (RIP)
    [ IRONMAN 4X4 FAB ] [ RACELINE WHEELS]
  15. #15 Re: Dual batteries.
    Sep 2005
    nh
    yay 1 option. try gargling bleach.
  16. #16 Re: Dual batteries.
    I am EPIC Staff JordanA's Avatar
    Mar 2007
    Chapel Hill, NC - Winston-Salem, NC
    Quote Originally Posted by xtremzj View Post
    Ha, what? That was completely unneccessary.
    Krash80: And my trailer weighs 8,000 lbs empty.
    CurtP: What does your house have to do with any of this?
    The test of our progress is not whether we add more to the abundance of those who have much, it is whether we provide enough for those who have too little.
    ~Franklin D. Roosevelt
  17. #17 Re: Dual batteries.
    southern afganistan
    i built one out of some 3/16 i had laring around, it is as ugly as sin, mabe ill clean it up some day if im realy bored.... i think its the best way to go.
  18. #18 Re: Dual batteries.
    Yeah Andy, I think your jeep deserves a torchmate replacement for that tray
  19. #19 Re: Dual batteries.
    Jan 2010
    SLC UT
    If you make Andy one I want one to! I just picked up my second battery today and will be figuring all this out here soon as to which way I want to wire it up since I suck at wiring lol
  20. #20 Re: Dual batteries.
    Member Wwildman's Avatar
    Oct 2010
    NC
    That is my favorite thing to do is wiring .
    Warren You might be a redneck if you actually know what kind of leaves make the best substitute for toilet paper
  21. #21 Re: Dual batteries.
    Jan 2010
    SLC UT
    I hate wiring man maybe you can help me wire all this shit in sometime haha.
  22. #22 Re: Dual batteries.
    southern afganistan
    if you reay want to, go for it, i honestly thing the one on it is fine, just needs some, well...allot of cleaning up.
  23. #23 Re: Dual batteries.
    Nov 2010
    Colorado Springs, Colorado
    What did you guys use for the new intakes? I see 5.9 andy has a dual filter. what intake is that?
    1997 ZJ Limited 5.2, 3.5" lift, 31" Interco AT's, custo, inverter, Yakima roof rack.
    Currently in the worx, Fully trussed gusseted sleeved and chromoly. 4:56gears built D30 and Locked D35. Both built by Curt LeDuc
    Currie HD Johnny Joint arms. (u/l f/r)
    Full traction Race Springs
    f/r tube bumpers
    Magnaflow CAT and Dynomax cat back exhaust
    Goodyear Wrangler Yellow Letter "race tires"
  24. #24 Re: Dual batteries.
    Oct 2010
    NC
    Quote Originally Posted by biggoofy View Post
    No problem just bring it by the house .
