dude, awesome dub. just read your entire thread. i like it a lot!
question, i saw you replaced your upper CA axle bushings with JJ's, does that transmit more vibes to the body? and what size is the joint? im at school and my jeep is at home taken apart so i cant go measure real quickly. im about to begin a hp30 build and saw that and became interested
no more vibes to the body.. wouldn't have noticed the change, other than my old bushings were shot, so the axle rotated back and forth.
I have only done 1 side thus far. The passenger side has a weld in mount that i ahven't done yet. I guess it will twist off the factory sheet metal mount since they don't deflect like the stock bushings do.
I will get that other one on there one of these days, but for now its not really doing anything. Its almost like a 3 link... since the other one is soo worn out, its not doing much.
check out this page for all the info you need:
http://www.currieenterprises.com/ces...t.aspx?id=1277
G-
hey thanks for the info.
after i saw this i went to the currie site and found their JJ's but didnt see that kit. i might just stick with replacement bushings, but iv got some time to decide. thanks again
no problem... take it easy
G-
damn.. i just scored a sway loc dual rate sway bar and free led rock lights!
http://www.offroadonly.com/
they are doing a black friday special.. they were on the list, so i jumped on them!
Im super jealous ... That is what I want to run front and rear
Good luck making all that fit with stock axles. And your frame rails are wider than the TJ's to start with. Standard anti rock is the way to go.
Oh and come wheeling: http://www.mallcrawlin.com/forum//sh...ad.php?t=20967
i called them and got measurements before i ordered it. It will clear the frame rails, and the JK versions have 12" levers, which is the same as what the stock bar has. I will just have to fab up bushing mounts for it.. the anti rocks are great, but a little too soft for a daily driver. i had one on my tube crawler.
I spent all day yesterday getting the shocks mounted. Here are the pics:
Laser cut mounts: (made from .188 4130 sheet)
I made a gusset doubler plate on the back upper.. probably pointless, but oh well.
Here are the front uppers:
Front Lower: (I cut out the factory one)
The longest part was cutting off the rear lowers. That was a serious pain, since they are located in between the rear control arm mounts. I had to use a saws-all, die grinder, 90 deg grinder, and a 4" grinder to get it all cut off..
OK please tell me you have the front upper coil mount plates in a pattern
And when you finish the Sway bar mounts I will be interested since I am using the same
i do.. i actually cut some extras.. let me see what i have left... i will give you what ever i have left. They don't fit totally perfect, but close enough to burn them in with no issues.. I cut a couple of the back ones with no holes incase they didn't line up correctly too.
i will plan on making 2 of the sway-loc mounts.. i should get it next week! it will be easier to make them both at the same time for us.. so it will be an x-mas present for ya!
G-
Why did you mount the lower shock mounts so low instead of cutting into the rear hatch and moving the upper shock mounts higher? Those shock mounts are loooowwww.
^^ x2
Looks like how the JK's shocks are mounted. My dad has been hung up on his plenty haha
I think he means the rear lower mounts, they are so low.
Your jeep looks bad as hell, I love your bumper, when is the rear bumper commin?
they are only down 1", and they are close to the tires. I made them beefy so they will take some abuse if they get hung up. This is a daily driver, less crawler, so to me the trade off wasn't worth all the extra work of cutting into the rear hatch area, and making towers etc.
yes, why u want some?
one of these days.. i haven't started it yet.
alright.
Cool nice work as always. Have you started fabbing a truss yet? Mines almost ready. Knowing you though, you'll build some space age looking one out of titanium that hovers the axle over obstacles and makes mine look lame. LOL
you could just run a small piece of boxed up between the LCA and shock mounts to bridge that gap, brace it, and that will eliminate that rock target between the two mounts...and strengthen the mounts (even if its overkill)
yup.. good idea.
g-
Here are some pics of some snow wheeling i did over xmas in colorado. good times:
