LSRGreg's WJ Build... Its ON!
Thread: LSRGreg's WJ Build... Its ON!
Page 1 of 10 12345678910 LastLast
Results 1 to 25 of 233
  1. #1 LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Ok.. so im a total newb here, but this isn't my 1st party. I have owned 2 ZJ's before this WJ, and had a full tube crawler, that i just sold a few months ago. So its time to build my ultimate do all rig.
    It will be my daily driver, my run to moab doing 80, my medium duty crawler to run the trails with, my desert pre-runner, minor fun in the dunes and woops, my do everything vehicle. (at least that is the plan anyways)
    The factory specs:
    2004 WJ limited with 70k on the ticker
    loaded including Nav.
    4.7 HO motor
    Quadra Drive
    Black Crystal Metallic
    The Mods so far:
    Washer bottle re-location
    242 swap with d-shaft
    Mods for the immediate future:
    Clayton 6" long arm kit
    35" BFG KM2's
    Walker Evans True Beadlocks with OMF rings
    Fox Bypass shocks
    TNT Customs Hi-steer kit with relocated track bar, and flipped tie-rod
    Kevins Sliderz
    Custom front bumper with 8000k winch (designed and fabbed by me)
    major fender trimming
    Mods further in the coming months:
    Truss/Skid plate for Rear Alum 44 axle
    Rear aussie locker or ARB, 4.56 gears
    Front axle either swapped out for a dana 44 or polish up the terd a little bit... (mind you, not gonna be a "hard core" crawler)
    Truss for Dana 30 up front
    aussie or ARB, 4.56 gears
    Alloy axles with 30 splines
    Rear bumper and tire carrier
    i think thats about it for now.
    Here are some pics..
    Just installed the clayton cross member, and will be welding it in this weekend.... the coils, arms and track bar will be getting powdercoated a surprise color, that i am sure most of you will hate.
  2. #2 Re: LSRGreg's WJ Build... Its ON!
    Senior Member dp96zj's Avatar
    Texas
    Your sig. It's too short.
  3. #3 Re: LSRGreg's WJ Build... Its ON!
    Eat Shit & Welcome to MC!
    Nice Build, looks like you have a ton of work to do. Looking fwd to the progress.
    Will
  4. #4 Re: LSRGreg's WJ Build... Its ON!
    2nd floor Yuma, AZ motel
    Are you jeeps?
  5. #5 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    i can't wait until its finished!!
    Here are some stocker pics:
    and the ZJ washer bottle relocate:
    Elliot,, not sure what you mean ??
  6. #6 Re: LSRGreg's WJ Build... Its ON!
    Member Shinobi's Avatar
    Oct 2008
    Reno, NV
    Nice can't wait for your build
    hey is there a write up some where for the Washer bottle re-location? I would really like to do that to mine
    Thanks
    RIP 2004 WJ - 3.5' lift , JKS Disconnect and 33's
    NO! Shinobi's Jeep up side down on the news
    2001 WJ - 6" Clayton , 35's BFG AT KOs , and buch of stuff
    Insurance Settlement Build
  7. #7 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Quote Originally Posted by Shinobi View Post
    Thanks
    Here is the write up...
    http://www.mallcrawlin.com/forum/sho...054#post231054
    most people are sticking them down where the factory air box is, but im keeping my factory one in place, so i stuck mine up near the master cyl. I used all 3 mounts, and re-used my WJ pumps, and wire harness. I did have to soften the plastic with a torch and push it in so it woudn't rub on the brake lines sticking out the master cyl. You just gotta make sure its low enough to clear the lift strut. And i also made a little mount to re-mount the vacuum thing that hangs off the side of the fender well.
  8. #8 Re: LSRGreg's WJ Build... Its ON!
    Senior Member RiPPiNiTuP7's Avatar
    Dec 2004
    Ohio
    looks good.
    your screen name looks familiar, are you on RF.net?
    -04' silver ram 1500. 5.7 hemi. 4x4. a few goodies.
    -98' chargold zj. 4.0/242. stocker.
    -09' black yamaha rhino SE. new offroad play toy.
    -96' black zj. 4.0/242. re 4.5" + 2" BB, 35" bfg at's, 8.8 w/ e-locker, open HP30, 4.56's, TW SYE & F/R driveshafts, currie steering, addco's F/R, ARB'ed, Warn 8k winch, & armor. - SOLD
  9. #9 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Quote Originally Posted by RiPPiNiTuP7 View Post
    looks good.
    yup.. thats me.
  10. #10 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Got the crosmembers and mounts welded in today...and added a 40 series delta flow muffler and turn down... next step is paint!
  11. #11 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    i had to move the mounting plates out on the sliders to fit up properly, and trimmed the inner mounts to fit with the clayton cross members. just gotta drill new holes, and they will be ready for powdercoat....
  12. #12 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    got it all painted up this morning.
  13. #13 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Finally got the parts back from coating.. here comes the lift:
    I still need to finish cutting off the original control arm mounts, and get the driveshafts extended... then get shocks, but its moving along. it lifted the front 7 3/4" and the rear 7".
  14. #14 Re: LSRGreg's WJ Build... Its ON!
    Staunton, VA
    That green is pretty sweet.
  15. #15 Re: LSRGreg's WJ Build... Its ON!
    Texas
    When I saw the parts all laid out, I thought the green was gonna look , but on the rig it looks pretty sweet!
  16. #16 Re: LSRGreg's WJ Build... Its ON!
    Sep 2008
    Mesa, Arizona
    The silver brackets and green arms and spings look legit. I hope to see this thing out on the trail sometime.
  17. #17 Re: LSRGreg's WJ Build... Its ON!
    Oct 2008
    Tacoma, WA
    I am loving that green, GOOD idea!
  18. #18 Re: LSRGreg's WJ Build... Its ON!
    Member wjguy's Avatar
    Dec 2006
    marysville washington
    WOW! Thas all I got. WOW!
    stuff welded and bolted to a wagon
  19. #19 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    yeah.. most said i was crazy to do the green.. but i think it looks great. It will look even better with the black wheels, and the beadlock rings will be the same green.. and i coated the sliders green too. i am slightly worried that the sliders might be too much green, but i didn't want to install them until i get the control arm mounts cut off.
    thanks for the compliments thus far.. so who knows if i can just lengthen the drive shafts, or do i need different types to not have vibes? I pushed the axles away from center of jeep to clear the tires without having to hack up the body serious amounts, so they are going to need something done for sure.
  20. #20 Re: LSRGreg's WJ Build... Its ON!
    Staunton, VA
    Not sure about dubs but I'm still running a stock front shaft on my xj and we have a shop that we bring a ram 2500 front drive shaft to and he cuts it to length for the rear might try to do that.
  21. #21 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Got the OEM control arm mounts cut off, welded the seams, then painted:
    Then got Kevin's Sliderz mounted up. I stopped by harbor freight and got a cheap 90 degree angle drill, and cut my drill bit down, so drilling the holes was a snap. I highly recommend doing that if you install them.
    Now i am just waiting for my TNT Customs hi-steer kit, and track bar relocator to show up, so i can get my steering and track bar angles a lot flatter.
  22. #22 Re: LSRGreg's WJ Build... Its ON!
    Member Lifetime Supporter AQHACowboy's Avatar
    Oct 2005
    Stedman NC
    Looks good, I have a 2000 WJ that I will be lifting soon. i was wondering why you went with the 242 instead of the 231?
    Danny
    2000 WJ Laredo (Daily Driver)
    4.0 I-6 4x4 186,000+ miles and still going strong.
    2007 Tahoe (Wife's truck)
    Fully loaded
  23. #23 Re: LSRGreg's WJ Build... Its ON!
    Dec 2006
    drive shafts- I would just get the tom woods set I love mine.
  24. #24 Re: LSRGreg's WJ Build... Its ON!
    Utah
    Looks damn good, nice work.
  25. #25 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Quote Originally Posted by AQHACowboy View Post
    i liked the idea of the 4 full time mode, plus i knew for sure it was a direct bolt in swap.. didn't have to worry about input shafts etc. not sure about the 231 case.
    Quote Originally Posted by wjguy View Post
    Yeah. i got mine lengthend, but the rear still vibrates pretty good at about 50mph and up. Did you end up doing a SYE, or just a slip yoke style CV type? I really don't want to mess with a SYE, but if that is the best way to go, i might have to. I will be calling Tom today to see what he says.
    Thanks.
