LSRGreg's WJ Build... Its ON! - Page 7
Thread: LSRGreg's WJ Build... Its ON!
Page 7 of 10 FirstFirst 12345678910 LastLast
Results 151 to 175 of 233
  1. #151 Re: LSRGreg's WJ Build... Its ON!
    Feb 2008
    Dublin, Ohio, United States
    dude, awesome dub. just read your entire thread. i like it a lot!
    question, i saw you replaced your upper CA axle bushings with JJ's, does that transmit more vibes to the body? and what size is the joint? im at school and my jeep is at home taken apart so i cant go measure real quickly. im about to begin a hp30 build and saw that and became interested
  2. #152 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    no more vibes to the body.. wouldn't have noticed the change, other than my old bushings were shot, so the axle rotated back and forth.
    I have only done 1 side thus far. The passenger side has a weld in mount that i ahven't done yet. I guess it will twist off the factory sheet metal mount since they don't deflect like the stock bushings do.
    I will get that other one on there one of these days, but for now its not really doing anything. Its almost like a 3 link... since the other one is soo worn out, its not doing much.
    check out this page for all the info you need:
    http://www.currieenterprises.com/ces...t.aspx?id=1277
    G-
    04 WJ, Limited, 4.7 HO, 242 Swap, 6" Clayton Longarm'd, 35" BFG KM2's, 17" WER Beadlocks OMF rings, Kevin's Sliderz, Kevins HD Tie Rod, TNT Customs Hi-Steer, Fox Bypasses, 4.56 Gears,
    Incline Winch Bumper from Frantzdesignworks.com
  3. #153 Re: LSRGreg's WJ Build... Its ON!
    Feb 2008
    hey thanks for the info.
    after i saw this i went to the currie site and found their JJ's but didnt see that kit. i might just stick with replacement bushings, but iv got some time to decide. thanks again
  4. #154 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    no problem... take it easy
    G-
  5. #155 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    damn.. i just scored a sway loc dual rate sway bar and free led rock lights!
    http://www.offroadonly.com/
    they are doing a black friday special.. they were on the list, so i jumped on them!
  6. #156 Re: LSRGreg's WJ Build... Its ON!
    Member SaturnICL's Avatar
    Sep 2008
    Sparks, NV
    Im super jealous ... That is what I want to run front and rear
    99' WJ
    Custom LA lift with 14" Fox coilovers, FW Super 60 front and Sterling 10.5 rear locked, Custom front and rear bumpers, raised gas tank, boat sides, 37's and lots of fender trimming
  7. #157 Re: LSRGreg's WJ Build... Its ON!
    Arizona
    Good luck making all that fit with stock axles. And your frame rails are wider than the TJ's to start with. Standard anti rock is the way to go.
    Oh and come wheeling: http://www.mallcrawlin.com/forum//sh...ad.php?t=20967
  8. #158 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    i called them and got measurements before i ordered it. It will clear the frame rails, and the JK versions have 12" levers, which is the same as what the stock bar has. I will just have to fab up bushing mounts for it.. the anti rocks are great, but a little too soft for a daily driver. i had one on my tube crawler.
    I spent all day yesterday getting the shocks mounted. Here are the pics:
    Laser cut mounts: (made from .188 4130 sheet)
    I made a gusset doubler plate on the back upper.. probably pointless, but oh well.
    Here are the front uppers:
    Front Lower: (I cut out the factory one)
    The longest part was cutting off the rear lowers. That was a serious pain, since they are located in between the rear control arm mounts. I had to use a saws-all, die grinder, 90 deg grinder, and a 4" grinder to get it all cut off..
  9. #159 Re: LSRGreg's WJ Build... Its ON!
    Sep 2008
    Sparks, NV
    OK please tell me you have the front upper coil mount plates in a pattern
    And when you finish the Sway bar mounts I will be interested since I am using the same
    99' WJ
  10. #160 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    i do.. i actually cut some extras.. let me see what i have left... i will give you what ever i have left. They don't fit totally perfect, but close enough to burn them in with no issues.. I cut a couple of the back ones with no holes incase they didn't line up correctly too.
    i will plan on making 2 of the sway-loc mounts.. i should get it next week! it will be easier to make them both at the same time for us.. so it will be an x-mas present for ya!
    G-
  11. #161 Re: LSRGreg's WJ Build... Its ON!
    Why did you mount the lower shock mounts so low instead of cutting into the rear hatch and moving the upper shock mounts higher? Those shock mounts are loooowwww.
  12. #162 Re: LSRGreg's WJ Build... Its ON!
    SL,UT
    ^^ x2
    Looks like how the JK's shocks are mounted. My dad has been hung up on his plenty haha
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  13. #163 Re: LSRGreg's WJ Build... Its ON!
    Senior Member dp96zj's Avatar
    Texas
    Quote Originally Posted by LSRGreg View Post
    Just curious, but are you gonna keep using those upper coil retainers?
  14. #164 Re: LSRGreg's WJ Build... Its ON!
    Member leeanderthal's Avatar
    Jul 2008
    Benton Harbor, Michigan, United States
    I think he means the rear lower mounts, they are so low.
    Your jeep looks bad as hell, I love your bumper, when is the rear bumper commin?
  15. #165 Re: LSRGreg's WJ Build... Its ON!
    Sep 2008
    Sparks, NV
    G-
    99' WJ
  16. #166 Re: LSRGreg's WJ Build... Its ON!
    Member Shinobi's Avatar
    Oct 2008
    Reno, NV
    G-
    Why not make 3
    RIP 2004 WJ - 3.5' lift , JKS Disconnect and 33's
    NO! Shinobi's Jeep up side down on the news
    2001 WJ - 6" Clayton , 35's BFG AT KOs , and buch of stuff
    Insurance Settlement Build
  17. #167 Re: LSRGreg's WJ Build... Its ON!
    Oct 2009
    Florida
    Maybe its the angle the pic is taken at. It doesnt look like it will hang any lower than the lca mount once the truck is sitting on the ground? IDK?
  18. #168 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    they are only down 1", and they are close to the tires. I made them beefy so they will take some abuse if they get hung up. This is a daily driver, less crawler, so to me the trade off wasn't worth all the extra work of cutting into the rear hatch area, and making towers etc.
    Quote Originally Posted by dp96zj View Post
    yes, why u want some?
    Quote Originally Posted by leeanderthal View Post
    one of these days.. i haven't started it yet.
    Quote Originally Posted by Shinobi View Post
    Why not make 3
    alright.
  19. #169 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    they are down a little lower than the LCA, but not by much..
    g-
  20. #170 Re: LSRGreg's WJ Build... Its ON!
    Oct 2009
    Florida
    Cool nice work as always. Have you started fabbing a truss yet? Mines almost ready. Knowing you though, you'll build some space age looking one out of titanium that hovers the axle over obstacles and makes mine look lame. LOL
  21. #171 Re: LSRGreg's WJ Build... Its ON!
    Senior Member Sudz's Avatar
    Pennsy
    g-
    FWIW
    my setup
  22. #172 Re: LSRGreg's WJ Build... Its ON!
    Raleigh, North Carolina, United States
    you could just run a small piece of boxed up between the LCA and shock mounts to bridge that gap, brace it, and that will eliminate that rock target between the two mounts...and strengthen the mounts (even if its overkill)
    97 V8 zj.
    35"KM2s.aussies,4.88s,full chromos,1 ton hi steer in the 44/8.8.KOR/Clayton longarms.
    http://www.mallcrawlin.com/forum//sh...ad.php?t=17603
    03 Cobra with horsepowers
  23. #173 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    yup.. good idea.
    g-
  24. #174 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Here are some pics of some snow wheeling i did over xmas in colorado. good times:
  25. #175 Re: LSRGreg's WJ Build... Its ON!
    Santa Fe, NM
    Man your rig is sweet, in looks and performance
