LSRGreg's WJ Build... Its ON! - Page 2
Thread: LSRGreg's WJ Build... Its ON!
Page 2 of 10 FirstFirst 12345678910 LastLast
Results 26 to 50 of 233
  1. #26 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Finally got my wheels in today! Only problem is, they didn't come with the RAD valves i wanted, so i guess i will be adding those myself. Man these sucker are pure beef! 45 lbs each, and aluminum. No wonder they use them on trophy trucks!
    No welds on these beads!
    Now they just need some powdercoat treatment!
    04 WJ, Limited, 4.7 HO, 242 Swap, 6" Clayton Longarm'd, 35" BFG KM2's, 17" WER Beadlocks OMF rings, Kevin's Sliderz, Kevins HD Tie Rod, TNT Customs Hi-Steer, Fox Bypasses, 4.56 Gears,
    Incline Winch Bumper from Frantzdesignworks.com
  2. #27 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Got some pics from the maiden wheeling voyage. Had a super nice weekend out in Box Canyon near Florence Junction, AZ
    Here are some shots:
    Testing out the flex to see how bad the tires are rubbing with the very minimal trimming i have done thus far:
    Here is where we had to stick the rear spring back in, since they dropped out 3 times that trip: (left sway bar connected, so rear end did all the flexing, and since i still have the bastard shocks, there isnt' much holding back from serious droop)
    Here is another spring drop:
    Aired down to 18 psi:
    It was a dusty weekend.. thank god for windows, and AC!
  3. #28 Re: LSRGreg's WJ Build... Its ON!
    Senior Member jborushko's Avatar
    Mar 2008
    stationed at tacoma wa
    its green dude
    96 ZJ swapped in 5.2, 242, 14bolt rear, big ugly home brew bumper, 7.5" of lift in the front 9" in the rear, long arms, hummer wheels with 37s... (dont worry front axle is next)
    It should be heavy. Weight is a sign of reliability. If it doesn't work, you can always hit him with it.
    -e-boner
  4. #29 Re: LSRGreg's WJ Build... Its ON!
    Feb 2008
    oregon
    i like the green, not on the sliders though.
  5. #30 Re: LSRGreg's WJ Build... Its ON!
    Arizona
    When are you going to upgrade your tie rod?
  6. #31 Re: LSRGreg's WJ Build... Its ON!
    Aug 2006
    Wa
    Monster Energy...... I like it
    2003 WJ 4.7, Clayton's 7", 35" Goodyear MTR's, Sliders, ARB, yada yada yada....
  7. #32 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Quote Originally Posted by chadjans View Post
    Ordered one from Kevin yesterday.
  8. #33 Re: LSRGreg's WJ Build... Its ON!
    Arizona
    Quote Originally Posted by LSRGreg View Post
    Welding to a stock one on the trail with three batteries brings the suck.
  9. #34 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Finally got the wheels mounted. I spent all day yesterday adding the Monster Valves, and getting them mounted up. The center caps finally came today, so i will get those coated to match, and some new lug nuts when i get them balanced at discount. Even though, with no balancing, they run just like they did on the stock wheels, even at 70 mph on the freeway..
    Here is a wheel with monster valve installed:
    Here is the difference between a Monster Valve and a regular valve stem:
    Little bit wider stance due to the 9" rim width versus the 7" stockers
    The tires make a little more road noise now, but nothing annoying. Even without them balanced it drives great on the street.
  10. #35 Re: LSRGreg's WJ Build... Its ON!
    Member ZJARCHER's Avatar
    Glendale, AZ
    Dang, looks GREAT man! Now it's time for a rearend
    If I see you around town Ill say hey
  11. #36 Re: LSRGreg's WJ Build... Its ON!
    Sep 2008
    Mesa, Arizona
    I love it. Nice work!
  12. #37 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Quote Originally Posted by ZJARCHER View Post
    thanks.. it should be easy to spot me now. hahah..
    g-
  13. #38 Re: LSRGreg's WJ Build... Its ON!
    Austin, TX
    I like the black Evan Walker's, nice job!
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  14. #39 Re: LSRGreg's WJ Build... Its ON!
    Aug 2004
    Dinwiddie, VA
    They look great man! I picked up OMF performance about a month ago now as a new vendor. Sold a couple sets of the Rock Domes but haven't sold a set of walkers or any of the old wheels they supply me with yet...quoted a few though!!! They aren't the cheapest in the world but they are damn nice like you mentioned.
    The powder coat treatment you gave them is very original for sure.
    "Matt"
  15. #40 Re: LSRGreg's WJ Build... Its ON!
    Mar 2008
    Mukilteo, WA
    I like the new color, its different thats for sure. It looks like your sponsored by Monster.
  16. #41 Re: LSRGreg's WJ Build... Its ON!
    Sep 2008
    Mesa, Arizona
    g-
    Is this your DD? I'll keep an eye out for you.
  17. #42 Re: LSRGreg's WJ Build... Its ON!
    Member Shinobi's Avatar
    Oct 2008
    Reno, NV
    very nice !! love the color .. when are you gonna do some fender trimming ?
    RIP 2004 WJ - 3.5' lift , JKS Disconnect and 33's
    NO! Shinobi's Jeep up side down on the news
    2001 WJ - 6" Clayton , 35's BFG AT KOs , and buch of stuff
    Insurance Settlement Build
  18. #43 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    thanks for the compliments guys.. the wheels are top notch in quality. the bead lock rings have specially machined seats for the bolts, since the rings get bent in like a cone as they get tightened on. The only thing i didn't like was the fact that they had a "made in china" stamping on them. That kinda made me dissapointed to spend that much on wheels that weren't made here. The rings and work that OMF did is all USA stuff, but the castings on the wheels were done in China.. i kinda lost some respect for Walker Evans. I know they used to be made here, but not any more i guess. But its hard to compete in the wheel business and not have them made in china.
    I don't even have them balanced yet, and they are just as smooth as my stock wheels that were balanced..
    Its my daily driver, and i live in Tempe, and work in Mesa near Alma School and Broadway.
    The fender trimming will commence once i get retainers made for the coils. I have already dropped the rears out a couple times, so i need to lock them down so i can get even more flex, then take measurements for the shocks, and do the trimming.
  19. #44 Re: LSRGreg's WJ Build... Its ON!
    Nov 2008
    RI
    Looks Great!
  20. #45 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    Ok.. another weekend went by with more work done..
    Got the new track bar mount welded in and installed... as well as Kevins HD Tie Rod..
    It drives like ass right now, since the drag link isn't flipped over yet, but i will be doing that tonight.. gotta rent a tie rod end puller, and do some drilling and reaming of my spindle and pitman arm.
    I also fabbed and installed my coil spring retainers:
    and i decided to use some exhaust clamps on the upper rears. LOL
    I think i might vinyl dip the ends of the hook style ones, so they don't make noise..
    I made 1 set of extras if anyone is interested.
  21. #46 Re: LSRGreg's WJ Build... Its ON!
    Arizona
    I would recomend not capturing the coils top and bottom. Unless you like replacing coils every other month. Weld a nub on the upper coil bucket.
    Why did you bother keeping the steering dampner?
  22. #47 Re: LSRGreg's WJ Build... Its ON!
    Feb 2006
    Sac, California
    I know springs meant for compression dont like to be extended, but its not that dramatic is it? I mean its probably only going to stretch a few inches
    The Blue Submarine
    2001 Grand Cherokee (WJ) 4.7
    RIDE!”
  23. #48 Re: LSRGreg's WJ Build... Its ON!
    Jan 2009
    Tempe, AZ
    hmm.. chad.. why would i be replaceing coils every other month?
    They will only get stretched a couple inches... and rarely.. If i just lock them in on one side, then they will flop out, like they have done already on the rear. The front hasn't come out, but my shocks i have right now only droop 2" lower than ride height, so they aren't coming close, but i want to fit the longest shocks i can, and i know it flexes beyond the lenght of the coils i have... Is stretching the coils a bad thing?
    Plus, i don't want them moving around either when they do get unloaded.
    as far as the steering dampener, i just decided to leave it. I will probably upgrade to something stiffer anyways, for doing more higher speed stuff..
  24. #49 Re: LSRGreg's WJ Build... Its ON!
    Arizona
    yes.
  25. #50 Re: LSRGreg's WJ Build... Its ON!
    2nd floor Yuma, AZ motel
    x2. Or extend your upper posts a few inches. Stretched coils = BAAAD.
