Insurance Settlement Build - Page 4
Thread: Insurance Settlement Build
Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 106
  1. #76 Re: Insurance Settlement Build
    Member SaturnICL's Avatar
    Sep 2008
    Sparks, NV
  2. #77 Re: Insurance Settlement Build
    Mar 2009
    Howland, Ohio
    Just an idea... someone may want to pluck the pics of the XJ dumping it's fluids.
  3. #78 Re: Insurance Settlement Build
    Mar 2008
    stationed at tacoma wa
    *cough* we assume you dug the contaminated dirt up and cleaned up the spill
    -e-boner
  4. #79 Re: Insurance Settlement Build
    Member Shinobi's Avatar
    Oct 2008
    Reno, NV
    Quote Originally Posted by jborushko View Post
    as a matter of fact we did we had quite the clean up crew
    RIP 2004 WJ - 3.5' lift , JKS Disconnect and 33's
    NO! Shinobi's Jeep up side down on the news
    2001 WJ - 6" Clayton , 35's BFG AT KOs , and buch of stuff
  5. #80 Re: Insurance Settlement Build
    Aug 2006
    Asheville, NC
    Awesome vids of the crack! Looks like Ron4x4 could use a locker. There were some points where it looked like his front axle wasn't turning at all. Does he have a 242 or 247 TC? The first thing I thought when I saw the guy laying on the ground holding his leg was "I bet he didn't have the doors on". Hopefully he's ok.
    2000 WJ - Stroked, Locked & Long Armed
    2006 XK 2" RC & 31" AT's
  6. #81 Re: Insurance Settlement Build
    Senior Member dp96zj's Avatar
    Texas
    Quote Originally Posted by Shinobi View Post
    Then .. another guy that was driving his jeep out decides to roll it a second time ...
    good times
    That must've sucked!
  7. #82 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    Well SaturnCL and I did some fender trimming today :thumbsup:
    We only did the front but will continue the rear tomorrow or Wednesday .
    Chris is good at making a straight line im not lol
    Nibbler at work
    Check out that clean cut !!
    BYeBYE
  8. #83 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    Check out all that rooom !!!!
    other side
    lol I got a lil to happy with the saw saw
  9. #84 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    the front all done
    I hate blurry pics :maddance:
    Oh and just for sh1ts and giggles
    37's baby !!!
    All I need todo is move the front axle forward a bit , big ass bump stops and pucks to fit 37's .. oh yeah and new axles lol
  10. #85 Re: Insurance Settlement Build
    Member Rangerwj's Avatar
    May 2008
    Golden, Colorado, United States
    nibbler did a pretty good job. looks good
    2000 WJ. some lift and mods. deathwobble.
    CSM How High Off Road Club
  11. #86 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    been a long time since ive updated this .... but since then I scored a good deal on some jk rubi axles with 5.13 and chromos and with the help of others I got it installed also got new bumpers(big thanks to SaturnICL and LSRgreg ) , new 35's , winch, and recently installed hydro assist.
    Here are some wheeling pics
    Parts of Fordyce
    rubicon
    local trail
    Some pics from GSW this year
  12. #87 Re: Insurance Settlement Build
    Seattle, WA
    Meh, shits weak
    And what dumbass almost flopped it here
    In all reality though this thing has come a loooong way. Good job.
    I collect Jeeps.
    The Polar Bear Detailed Build
  13. #88 Re: Insurance Settlement Build
    Lookin good man. WJ's look good wide.
    2004 Ford Lightning
  14. #89 Re: Insurance Settlement Build
    Jan 2009
    Tempe, AZ
    shin, what hydro assist ram did you get, and where did you get all the hoses and fittings?? lets see some pics!!!
    G-
    Your neighbor has a ZJ on dubs? Awesome!
  16. #91 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    G-
    Heres what I did ...
    I picked up a box from ebay a while ago for dirt cheap, sent it to SaturnICL to get it drilled and tapped.
    The box was kinda rusty so I wire wheeled it and gave it a quick spray.
    I picked up some hoses and reusable fittings from a local shop, I picked the dual layer hoses but you can use the 1 layer.
    I got a Ram with an 8" throw a while ago from a buddy of mine for free
    First I removed the engine skid since I knew it was just going to be in way of the install. Then I removed the draglink.
    Then I removed the fittings on the box and the steering connector thing .
    I then removed the box which was kinda a PITA, When I put the tapped box in I had to remove one of the fittings since it hitting the PS reservoir. Once it is in I tighten all the fittings
    I measured and cut the lines as needed, I went with 3.5 feet on one , and 2.5 on the other. Then test fitted it and made sure i wasn't going to have routing problems.
    I left one of the ends off to test to see if I had all the lines connected right which is a good thing I did cuz I didn't have it connected right lol so I now have to make a new line since one of them is too short. I had to get all the air out which involved me turning the wheel back and forth with the engine off. Once that was done turn the engine on and add more fluid don't let the fluid empty or you will have to start all over again .
    hope this helps !
  17. #92 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    lol ya he actually just switched it to black steelies
    thanks mang
    Meh, shits weak
    Thanks man, it was nice to acutally watch my jeep perform and take some pics of it !
  18. #93 Re: Insurance Settlement Build
    Sacramento, CA
    any improvement on road with that hydro assist? looks like a clean set up
  19. #94 Re: Insurance Settlement Build
    Feb 2011
    New Hampshire
    [QUOTE=Shinobi;319246]been a long time since ive updated this .... but since then I scored a good deal on some jk rubi axles with 5.13 and chromos and with the help of others I got it installed also got new bumpers(big thanks to SaturnICL and LSRgreg ) , new 35's , winch, and recently installed hydro assist.
    Parts of Fordyce
    rubicon
    local trail
    Awsome job man. Buildin a very capable rig!!! On the other hand, that green ZJ dubmobile almost made me toss my cookies. Thats just wrong....wrong I tell you
    Brian
    1aauto.com
    866-433-3393
    Jeep Repair Parts
  20. #95 Re: Insurance Settlement Build
    Hell yeah Kanin, the WJ is lookin SERIOUSLY good! Nice list of upgrades since I saw it last GSW too .
    How are the tires treatin ya vs your old ones? haha I'm sure it's night and day!
  21. #96 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    Quote Originally Posted by Arsonist_Bob View Post
    yes it feels more responsive and no more DW
    Quote Originally Posted by 1ABrian View Post
    lol thanks man !
    thanks man, you mean GSR? lol ya after GSR I had to get hydro assist I couldn't turn worth the shit ..These tires are great on road and in moab ... but with the river rocks around my area it doesn't hook up as well as the Irocs or km2
  22. #97 Re: Insurance Settlement Build
    Jul 2011
    A, A
    Real sick wj great mods, just wondering on the first pics you have on here were you running 35's or 33's
  23. #98 Re: Insurance Settlement Build
    Jan 2009
    Tempe, AZ
    Shinooobi,
    I have heard from a few people saying do not do the hydraulic assist, because it will be too touchy and sensitive at highway speeds. Does yours feel any different at highway speeds? Any harder to control, dangerous feeling or anything??
    Thanks man!
  24. #99 Re: Insurance Settlement Build
    Oct 2008
    Reno, NV
    some people may have a different style or how they like their steering but IMO it made my steering 10X better than before, I drove it all the way to moab just fine even my GF drove some of it and it was fine. I was hesitant at first also about it being touchy and sensitive but so far its great ! got rid of my DW also. It is a little bit sensitive but not too crazy, its better than driving a boat. Too me it made it felt normal again ... but thats just my opinion
  25. #100 Re: Insurance Settlement Build
    Jan 2009
    Tempe, AZ
    Thanks for the info! I would have thought it would be fine..
    G-
