View Poll Results: Who will be the February 2009 MallCrawlin Rig of the Month?
Voters
60. You may not vote on this poll
  • ATL ZJ and his 94 ZJ
    27 45.00%
  • action_fab and his 95 ZJ
    3 5.00%
  • ZJones and his 98 ZJ
    20 33.33%
  • chadjans and his 93 ZJ (yay pink interior!!)
    8 13.33%
  • Stealth Crawler ZJ and his 93 ZJ
    2 3.33%
Thread: February 2009 Rig of the Month Voting Thread
Results 1 to 18 of 18
  1. #1 February 2009 Rig of the Month Voting Thread
    Get your vote on!
  2. #2 Re: February 2009 Rig of the Month Submission Thread
    Year:
    1994
    Model: Grand Cherokee
    Drivetrain: 4.0, np435, twinsticked 205. 35 spline chromoly HP60 spooled front, welded 14b rear. 1350 driveshafts, 5.38s.
    Suspension: triangulated 4 links front and rear. 14" fox coilovers and 3" radflo air bumps front. 16" Rock Equipment air shocks rear.
    Tires: 40" LTBs
    Other Notable Mods: OBA; MM9k with warn solenoids, waterproof in-cab winch control, and 3/8" rope; plated Ford 60 knuckles; griffin radiator; corbeau seats; OEM rear view mirror mounted on cage
    Favorite Mod: full hydro
    Least Favorite Mod: my crossmember/skid hangs too low and will be replaced by a flat belly skid at some point.
    Favorite Trail: Lower 2 at Tellico, RBD at Morris Mountain, Lower Damnation in Harlan
    Best Carnage: sheared 231 mainshaft, chromo 44 stub, a couple j20 boxes, numerous torn trusses.
    Link to MallCrawlin Build Thread: http://mallcrawlin.com/forum/showthread.php?t=3395
  3. #3 Re: February 2009 Rig of the Month Submission Thread
    Member action fab's Avatar
    Hot Springs, AR.
    I know I won Jan. ROTM but I thought I would through my DD up for grins...
    Year: 1995
    Drivetrain: 5.9 swap with K&N FIPK, borla headers and cat back with cat delet, 52RE with shift kit, B&M deep sump pan, high flow pump and hardend sun shell, and ATLAS II 4.3 with 32 spline outputs. 30/35 combo (about to be replaced in May. with locked and chromoed spyder 9 super 30 combo)
    Suspension: mix between RE coils, Superlift RockRunner control arms and track bar, and bilstien shocks
    Tires: 35" Xterrains
    Other Notable Mods: ARB bumper, warn winch, IPF superallys, Tom woods F&R Drive Shafts, black rubicon rims, pioneer matched sound system, optima red top, and some other small nick nacks.
    Favorite Mod: 5.9 and ATLAS
    Least Favorite Mod: alum. high vol. D35 cover....
    Favorite Trail: I live five miles frome superlift ORV... so I have to many to chose from.
    Best Carnage: Broke a Dana 30 carrior last weekend. along with a R&P.
    ORS
    Light weight, High Quality, Innovative off road products
  4. #4 Re: February 2009 Rig of the Month Submission Thread
    Sep 2008
    Mesa, Arizona
    I know I won't win but I'll give you one more to choose from.
    Year: 1998
    Model: ZJ Limited
    Drivetrain: 5.9 v8 D30/D44a/249 TC
    Suspension: IRO 4.5" lift with 8 adjustable control arms, extended brake lines, heavy duty tie rod converstion, JKS quicker disconnects, steering stabilizer.
    Tires: 33x12.50x15 BFG Mall Terrains
    Other Notable Mods: Custom roof rack with 4 Hella 500's, Custom Track bar, CB in center console, Custom Quick Disco mounts, Custom front bumper started (check build thread)
    Favorite Mod: JKS quick discos for extra flexing, and fender chop so I can turn, and stuff the mall terrains.
    Least Favorite Mod: I like all my mods.
    Favorite Trail: Crown King, AZ
    Best Carnage: Broke Track bar at Butcher Jones, AZ
    Build Threads:
    Jeepforum: http://www.jeepforum.com/forum/showthread.php?t=679452
    MallCrawllin: http://www.mallcrawlin.com/forum//sh...ad.php?t=18224 -- Basically the same.
  5. #5 Re: February 2009 Rig of the Month Submission Thread
    Year: 1993
    Model: ZJ Laredo
    Drivetrain: I6 (4.0), AW4 tranny, 4.3 2 Speed Atlas with 1350 Ujoints front and rear, High Pinion Dana 60 front axle with ARB Air Locker, Corporate 14b rear axle with home made spool and loaded with 5.38 gears, High Angle Driveline rear driveshaft, Tom Woods front driveshaft, Alloy USA Dana 60 shafts, Poly Performance Dana 60 driveline slugs.
    Suspension: Home made frame rail sleeves with five link front and triangulated four link rear. Johnny Joints all around. Rear 16" travel 2 1/2" bodied ADS Machine Coilovers, Ballistic Fabrication brackets all around, DJ Safety Limit Straps all around.
    Tires: 39.5" Bias Ply Iroks with Hummer H1 Beadlocks.
    Other Notable Mods: Very multipoint roll cage tied to frame rail sleeves, on-board air, dedicated front suck down winch, front and rear 10K T-Maxx Winches, frame rail bobbing with relocated fuel tank, PRP Competition High Back Suspension Seats, full front hydraulic steering using PSC Pump, Reservoir and Chief steering ram, Borla engine header, Magnaflow high flow cat and Magnaflow muffler, Ballistic Fabrication Dana 60 steering arms, Ruff Stuff Specialties diff covers.
    Favorite Mod: Home made suspension.
    Least Favorite Mod: Alloy USA Dana 60 shafts (company now defunct, no warranty)
    Favorite Trail: Miner's Revenge
    Best Carnage: bending a JKS front panhard bar and destroying side and spider gears in a front Dana 30 axle.
    Link to MallCrawlin Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=2899
  6. #6 Re: February 2009 Rig of the Month Submission Thread
    Fruita, CO
    Year: 1993
    Model: ZJ limited
    Drivetrain: 5.2, stock trans,
    Suspension: skyjacker 4" w/pro comp 3000's, rancho 5000 steering stabilizer, rear spring spacers.
    Tires: 33" pro comp AT's on 10x15 rock crawlers
    Other Notable Mods: everything but the hood is coated in bedliner and Wp 3/4 roof rack and front dif cover mit
    Favorite Mod: 33" pro comp AT's
    Least Favorite Mod: short arm's
    Favorite Trail: state bridge!
    Best Carnage: smashing the whole left side of the rear!
    Link to MallCrawlin Build Thread: http://www.mallcrawlin.com/forum/showthread.php?t=18251
    up and coming additions: claytons hardarm upgrade, winch and building the bumpers! will get some pics up soon.
  7. #7 Re: February 2009 Rig of the Month Voting Thread
    where is the poll dave?
    97 V8 zj.
    03 Cobra with horsepowers
  8. #8 Re: February 2009 Rig of the Month Voting Thread
    Damn, gimme a minute to add the poll already!! LOL It's there now.
  9. #9 Re: February 2009 Rig of the Month Voting Thread
    allright, cool deal.
    97 V8 zj.
  10. #10 Re: February 2009 Rig of the Month Voting Thread
    Sep 2008
    Mesa, Arizona
    I have reached my goal of more then one vote! I'm happy with that.
  11. #11 Re: February 2009 Rig of the Month Voting Thread
    Sep 2008
    Mesa, Arizona
    You forgot to say ZJones and his 5.9 98 ZJ
  12. #12 Re: February 2009 Rig of the Month Voting Thread
    Junior Member WJJOHN's Avatar
    Jan 2009
    Spanish Fork, UT
    man.. there's some nice rigs in here..
    01' WJ Limited, 6" front 3-link, 4.5" rear 4-link,, MX6 shocks, 33" KM2's, Cragar soft 8's, FlowMaster Off Road Super 44, K&N, Red Top Optima
  13. #13 Re: February 2009 Rig of the Month Voting Thread
    West Deptford, NJ
    ZJones gets my vote for being the rig closest to what shooting for! A very admirable crop this month, though!
  14. #14 Re: February 2009 Rig of the Month Voting Thread
    Sep 2008
    Mesa, Arizona
    ATL ZJ, congrats on the win (we all knew you would anyway) but there's no way I'm catching up now.
  15. #15 Re: February 2009 Rig of the Month Voting Thread
    Ha, no one's chickens have been counted yet- there are still a couple days left! Good to see some friendly competitive spirit.
  16. #16 Re: February 2009 Rig of the Month Voting Thread
    IIRC Action Fab was down by 6 or so at one point last month with only a couple days left.
  17. #17 Re: February 2009 Rig of the Month Voting Thread
    Hot Springs, AR.
    dont think I'm getting 24 more votes this time LOL
    ORS
  18. #18 Re: February 2009 Rig of the Month Voting Thread
    Shit, I just realized I completely forgot about this. Cam won, will get the pic on the main page and other stuff done in the morning!
