IRO ZJ front Long Arms arrived ( Pics ) - Page 4
Thread: IRO ZJ front Long Arms arrived ( Pics )
Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 102
  1. #76 Re: IRO ZJ front Long Arms arrived ( Pics )
    Junior Member wildman_wilds's Avatar
    Mar 2009
    Minnesota
    All the strength is in the Iron Y on the drive side. So it is unessesary to have one on the pass side. The lower control arm is really strong to keep the axle in position. The Iron Y secures the pinion angle. quote=ZJones;231559]I don't understand why there is only one upper? Can someone explain that to my newb ass?[/quote]
  2. #77 Re: IRO ZJ front Long Arms arrived ( Pics )
    Mar 2007
    Is it safe to assume that you are from Ironrockoffroad, Wildman? I assume so just from you being in Minnesota.
    ~Franklin D. Roosevelt
  3. #78 Re: IRO ZJ front Long Arms arrived ( Pics )
    Quote Originally Posted by wildman_wilds View Post
    Quote Originally Posted by ZJones View Post
    Yeah but the reason to run ONE arm instead of TWO is because there is no binding with IRO's setup. If you swap in a different front axle you'd better build a hell of a mount for it though. When I first swapped in my d44 all I had was a pass side upper mount because I didn't want to build a truss. I will admit right off the bat that I had a shitty design. I didn't think the mount would be receiving any lateral loading, which I was apparently wrong about. Two peices of 1/4" plate with a tube welded in up top for a bushing insert, and a 3/16" gusset. Although I bet if the brackets didn't have the logo's cut in them it would have lasted. Either way, 20/20 hindsight and I have it built correctly now.
  4. #79 Re: IRO ZJ front Long Arms arrived ( Pics )
    Sep 2008
    Mesa, Arizona
    My main concern is the one caster adjuster. If that thing breaks on the trail and you don't have a replacement then what? I know it's 1/4 steel but look at AgitatedPancake's mount that's made outta 1/4, bent up like an unprotected rocker panel with a noob at the wheel.
  5. #80 Re: IRO ZJ front Long Arms arrived ( Pics )
    GOTTA LOVE TOPLOADERS!
  6. #81 Re: IRO ZJ front Long Arms arrived ( Pics )
    Mar 2008
    Saint Helens, OR
    CARNAGE!! Well, live and learn. I'm interested in how the IRO kit holds up to some abuse...
    NEW JOB!!!!! NEW BABY!!!!
  7. #82 Re: IRO ZJ front Long Arms arrived ( Pics )
    I was talking to Kevin (wildman_wilds) last night about the caster adjuster and after looking at it some more, it is stronger than I originally thought. My concern was not it necessarily breaking on the trail, as there's a bushing in the UCA mount to absorb some of the impact, but losing the adjustment and having the adjuster loosen up and having your angles go apeshit.
    There's 3 bolts on the bracket, one holds the bracket to the UCA/radius arm, the bolt on the bigger arc attaches to the UCA mount on the axle, and then the 3rd bolt is in the smaller arc and acts as the locking mechanism for the adjustment. The two arcs are setup in different planes per se, and the way it's setup they can handle a lot of push/pull type forces which is mostly what they will see as the axle tries to rotate. There may be some very slight pre-loading of the UCA bushing because the radius arm is fixed to the lower, but I doubt it would be enough to cause significant damage.
  8. #83 Re: IRO ZJ front Long Arms arrived ( Pics )
    Senior Member 93ZeeJ's Avatar
    Oct 2007
    Littleton
    i will be ordering the rear long arms in a few days when my tax return gets here... so there will be more pics to come at that point
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
    HP30-truetrac/D44a-Aussie 4.56
    6.5" Long Arms, 35"s
  9. #84 Re: IRO ZJ front Long Arms arrived ( Pics )
    May 2008
    Detroit
    Up-dates? You get the rears on yet?? Milage on this gear (on and off-road). Any issues, ect?
  10. #85 Re: IRO ZJ front Long Arms arrived ( Pics )
    Senior Member StinkoMan20X6_'s Avatar
    Aug 2005
    NC
    I know somebody with the front LA's on his cherokee and he hasn't broken any of that stuff yet. Even after getting the front of he jeep knocked off by a military cop which bent his unirails from the spring perch forewards, the arms and stuff survived fine and still drove ok once he got the frame pulled back out. There's no visible damage.
  11. #86 Re: IRO ZJ front Long Arms arrived ( Pics )
    Junior Member chris93jeep's Avatar
    Aug 2009
    greene, NY
    hey i know im late on this post but i was looking at getting that set up for my zj. hey do you still have that kevins crosmember and skid plate?
    1993 jeep grand cherokee
    2 inch coil spacers
    helix throttle body spacer
    cold air intake
    magniflow cat/cherry bomb pro muffler
    31" Goodyears with black rims
  12. #87 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    IRO long arms have worked really really well.. veyr impressed with them
    ill post pics here soon.. im at work right now
    .. and i already sold the KOR crossmember and skid plate
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  13. #88 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    Quote Originally Posted by albersondh View Post
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  14. #89 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    ive put quite a few miles and taken quite a few trips with these
    they have held up very nicely and im very impressed with them
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  15. #90 Re: IRO ZJ front Long Arms arrived ( Pics )
    Mar 2008
    Saint Helens, OR
    FLOP!! So much for straight sheet metal. Or were you just trying to get us the best pose possible to show off the IRO hardware?!
  16. #91 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    lol the only lasting damage is to the quarter panel.. and i can pound it out pretty well
    and yes... i did it for you guys.. to get you a good picture
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  17. #92 Re: IRO ZJ front Long Arms arrived ( Pics )
    Mar 2008
    Saint Helens, OR
    lol, thought so- show off. Good to know it is going to alright, couple of new doors and a hammer later...
  18. #93 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    new doors are already on... just need to hammer now
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  19. #94 Re: IRO ZJ front Long Arms arrived ( Pics )
    Midlothian Virginia
    nice! story behind it?
    I would add another support leg on those sliders...
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  20. #95 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    meh was just on a very off camper spot... and tires started to slip on loose gravel.. slid sideways and when they hit the ledge it tipped
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  21. #96 Re: IRO ZJ front Long Arms arrived ( Pics )
    Mar 2008
    Saint Helens, OR
    man, you move fast.
  22. #97 Re: IRO ZJ front Long Arms arrived ( Pics )
    Apr 2011
    Muskogee ok
    I know this is an old thread but are you still running this setup, what problems you had with it if any. I am looking at getting the 7" setup. Great thread
  23. #98 Re: IRO ZJ front Long Arms arrived ( Pics )
    Feb 2011
    New Hampshire
    very cool. ya gotta love a good flop'n. Good to see its fairly minor damage and it doesnt keep you from heading out right away
    Brian
    1aauto.com
    866-433-3393
    Jeep Repair Parts
  24. #99 Re: IRO ZJ front Long Arms arrived ( Pics )
    Aug 2011
    Sweden
    I'm running IRO's premium LA kit on my ZJ
    and I'm seriously in love with it. It has been performing flawlessly for two years now, and the only
    problem I had was that those grease valves are to close to the walls of the mounts and my grease gun wont fit there.
    Oh yeah, rear upper arms are good at eating up their bushings. These are OEM rubber bushings at both sides on each arm and they wear out relatively fast.
    I'd put Johnnys at least on one side.
    That caster bracket is really nice, you'll have to put some thread locker onto those bolts though
    After using this kit I fully agree with the description IRO uses for this kit - ridiculous !!!
    Articulation is incredible
    ZJ '93 5.2 9.5"LA, 8.8 rear, D30 HP trussed, RCV orange dome shafts, ARB f&r, 37" Iroks, hydroassist, IRO stuff, WJ Knuckle mod, OBA(ac), more to come
    WJ '01 4.7 untouched (yet)
    http://www.diman.se/gallery/albums/u...0001/zj-wj.jpg
  25. #100 Re: IRO ZJ front Long Arms arrived ( Pics )
    Aug 2012
    Lake George, Colorado
    very nice thread 98ZeeJ and very nice rig Diman. i'm looking at getting the IRO long arm kit for mine when i get the money. i'm just conflicted about the 5.5 or the 7" kit.
    Thanks for all the pictures and great info!
    Tank
    Tank,
    98 ZJ, 5.2l V8, Ax15 manual transmission swap, NP231, misc performance stuff.
