IRO ZJ front Long Arms arrived ( Pics ) - Page 2
Thread: IRO ZJ front Long Arms arrived ( Pics )
Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 102
  1. #26 Re: IRO ZJ front Long Arms arrived ( Pics )
    Quote Originally Posted by Jim311 View Post
    If you wanted to lengthen the lowers you could always cut and sleeve it and weld it up again.
    If you were going to go that that much trouble you might as well cut it and thread it for some adjustablenessssss.
    Will
  2. #27 Re: IRO ZJ front Long Arms arrived ( Pics )
    SLC, Utah
    Quote Originally Posted by ZJones View Post
    What does that have to do with his new long arms?
    just referencing quality of their stuff.
    97 with stuff....
  3. #28 Re: IRO ZJ front Long Arms arrived ( Pics )
    Southern IN
    Ive seen tj's with the 3 front control arms. Articulate great, but if an upper mount fails or a upper bolt breaks, so does many other things.
    96 ZJ, Locked on 35's
  4. #29 Re: IRO ZJ front Long Arms arrived ( Pics )
    Quote Originally Posted by black_zj View Post
    How does having a tie rod seize relate to their product quality? Did anything break?
  5. #30 Re: IRO ZJ front Long Arms arrived ( Pics )
    Install this yet????
    Will
  6. #31 Re: IRO ZJ front Long Arms arrived ( Pics )
    Senior Member 93ZeeJ's Avatar
    Oct 2007
    Littleton
    yeap
    heres pictures for everybody.... let the criticism begin
    Ok so i got some time today to put my HP30 back in the front and put the IRO long arms on at the same time.
    First i pulled off my stock control arms.... heres a picture for everyone to see what driving on stock control arms at 4.5" lift for a year will do. you can see how bent up they are from where they contact the axle...im lucky they didnt cave in on me completely.
    Next i took off my KevinsOffroad.com Crossmember + TC Skid ( which is for sale.. pm me if interested ) so i could install the new IRO crossmember.
    Below are pictures of where the holes for the crossmember need to be drilled... its extremely easy to drill since there is a lip that the bolts/nuts go through....you dont have to fish a nutplate into the unibody ( the rear has a nutplate )
    the outer 2 holes are the stock crossmember mounting holes and the 4 other ones are the ones that need drilled
    Next we bolted the crossmember on and connected the transmission mount to it.
    Connected the LA's to the axle.....then connected them to the IRO crossmember
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
    HP30-truetrac/D44a-Aussie 4.56
    6.5" Long Arms, 35"s
  7. #32 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    The install went extremely smooth untill the end...where we ran into a few things that i wanted to make everyone aware of.
    - I was at 4.5" of lift and my front driveshaft worked just fine...now that the axle is pushed further forward... my front driveshaft is about 2 7/8" too short. YOU WILL NEED A NEW FRONT DRIVESHAFT for the front long arms... i havnt ordered the rears yet so i dont know about the rear... i would guess that you would need one for the rear as well
    - second... stock steering = the suck when it comes to this kit. I called IRO and they said they have ran into this problem before. Where the drag link and tie rod connect to one another was hitting the sway bar mount and the Steering Stabalizer (mount and shock ) when the wheel was turned fully left (SS) or fully right (sway)
    The solution.... ( as recommended by IRO ) was the put a ~5 degree bend in the drag link. So we did so and now all is well
    Overall im very satisfied with the kit... i havnt gotten a chance to flex it out yet cause ive been too busy with work and school but that will come soon along with pictures of it
    I plan on ordering the rear long arms with my tax return and at the same time move up to 6.5" of lift instead of 4.5"
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  8. #33 Re: IRO ZJ front Long Arms arrived ( Pics )
    Looks good Matt, you ought to take the right side upper mount off the axle and then truss the whole thing, that would be suhweet.
    Neil R.
    Funniest thread on MC
  9. #34 Re: IRO ZJ front Long Arms arrived ( Pics )
    Jan 2008
    Marengo, Illinois, United States
    O man I can't wait to get the front ones! I love the rear long arm so MUCH you going to love the rear long too.
    1998 ZJ Jeep Grand Cherokee Limited I6
    Lifted 6", Goodyear MTR's 33", Winch, Bumpers, Sliderz,Long Arm, 4.10, Locked, and Loaded. (the last bit is a pun)
    2000 Mustang and a 2006 Kawasaki Ninja 636
  10. #35 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    Heres some up to date pictures of the ZJ ( Hanson Offroad front bumper is still off to get fixxed...might just be replaced with a tube bumper to match the rear that is gonna be built for it )
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  11. #36 Re: IRO ZJ front Long Arms arrived ( Pics )
    Member jeepdude25's Avatar
    Jun 2008
    Colorado Springs
    Very nice setup so far!!!!
  12. #37 Re: IRO ZJ front Long Arms arrived ( Pics )
    Aug 2007
    mi
    how do they ride? they look pretty good.
  13. #38 Re: IRO ZJ front Long Arms arrived ( Pics )
    Member zjrog's Avatar
    Jan 2007
    Tooele
    Is there an advantage/disadvantage with the upper part of the Ylink being fixed as opposed to loose? Just curious as I see it both ways and am fabbing a Y link for my Ranger D30 swap...
    1995 ZJ Laredo 4x4 Upcountry package
    1990 XJ Special PIA edition
    1990 Ford Ranger 4x4 2.3
    2002 Ford Supercrew 4x2 5.4
    2003 Dodge Neon SE "Half-a-Hemi"
  14. #39 Re: IRO ZJ front Long Arms arrived ( Pics )
    Jan 2005
    Topeka, Kansas
    Quote Originally Posted by zjrog View Post
    ...didn't you mean to type ADJUSTABLE instead of loose?
  15. #40 Re: IRO ZJ front Long Arms arrived ( Pics )
    Jan 2007
    Tooele
    Maybe...
  16. #41 Re: IRO ZJ front Long Arms arrived ( Pics )
    Santa Fe, NM
    With the upper link fixed you can't adjust the pinion angle at all.
  17. #42 Re: IRO ZJ front Long Arms arrived ( Pics )
    Mar 2005
    Flagstaff, Zona
    Adjustability comes from the large cam, not a threaded insert. Look at the pics in post the previous posts. They look adjustable to me!
    Sold: 01 WJ, 93 YJ, 86 CJ7
  18. #43 Re: IRO ZJ front Long Arms arrived ( Pics )
    Oct 2007
    Littleton
    the pinion angle is definately adjustable... thats what that silver bracket on the upper mount on the y link is for
    as far as the other question goes for why the y link is fixxed and not loose
    do you mean why is it welded and gusseted instead of connected with a bolt like this?
    the Jeep rides amazing so far... especially since i went from 4.5" on stock arms to 4.5" on LA's... night and day difference
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
  19. #44 Re: IRO ZJ front Long Arms arrived ( Pics )
    Santa Fe, NM
    Sorry, I was referring to ZJROG's post. I know yours is adjustable, I meant that with a fixed upper it isn't.
  20. #45 Re: IRO ZJ front Long Arms arrived ( Pics )
    Jan 2007
    Tooele
    Is it better to be fixed and gussetted?
  21. #46 Re: IRO ZJ front Long Arms arrived ( Pics )
    Santa Fe, NM
    IMO, Clayton's is the 'ideal' setup
  22. #47 Re: IRO ZJ front Long Arms arrived ( Pics )
    I predict that single upper bushing gets destroyed VERY fast, to the point where the bolt is hitting the sleve. That's one downside of only having a busing at one side, since they welded / gusseted that solid.
  23. #48 Re: IRO ZJ front Long Arms arrived ( Pics )
    I've got one of his first few kits, I didn't even understand it at the time he installed it 8 years ago, but when I asked if was worried about competition coming out, he pretty much said nope... Simple strong design, no one else will do better.
  24. #49 Re: IRO ZJ front Long Arms arrived ( Pics )
    Jan 2008
    Amazing how quick everyone is to defend clayton, and how he is so sure of himself. I'm glade to see that so many people show loyalty to the person that makes their parts. Even so I do not think it is appropriate for anyone to mention clayton any more in a IRO LA thread. This has been beaten to death, that all you guys think clayton is still better, and its fine with me.
    So how about we end this fued, and the wasted text on things like "Claytons is better," and "That looks like it is going to brake."
    By the way if I'm not mistaken, IRO has a awsome track record. (just my 2 cents)
  25. #50 Re: IRO ZJ front Long Arms arrived ( Pics )
    Get off your high horse, the design aspects of the uppers were mentioned in opposititions to IRO's solution.
    That's fair game for discussion. I don't care if it's compared to Claytons, RE, or anyone else who's made a ZJ long arm: With the exception of Teraflex (who doesn't even have uppers, talk about bad design) - IRO went too far out of the box on this one.
    Just my .02.
