Basic Information:
Asking for $3,900 OBO - No trades.
Vehicle may be seen on weekends, or between 5 and 7pm depending on the day.
VIN: 1GKGC26F9SJ769417
MILEAGE: 235,744
TRANSMISSION: Automatic (4L80E)
Green exterior, with tan cloth interior.
Air Conditioning, rear A/C, Cruise Control, Tilt Steering Wheel, Tachometer, Tinted Windows, Power Steering, Power Windows, Power Locks, Power Mirrors, Power Drivers Seat, Anti-Lock Brakes, Drivers Air Bag, Intermittent Wipers, Rear Defogger, Leather Steering Wheel, Sony CD / MP3 player, Tow Package, Running Boards, Roof Rack, Third Seat.
I love this truck, but it needs to go for two reasons: I need a 4wd vehicle to tow with, and I do not have time to fix the rest of what is wrong on this vehicle. With a little love it would be a great truck, but I have enough projects around here right now, this vehicle needs to go! It seats 8 people very comfortably, has a removable third row, or all rows can be folded down making the interior available to load up with anything (lots of groceries?)
This thing has about $5,000 in upgrades alone over the last 30 months.
Come take a look at this truck, if you bring cash and a vehicle to tow it home with, I have the title in hand and can sign it over immediately. No tire kickers please, if you come to take a look at this, you should already know what kind of condition its in considering the descriptions Ive given here.
This truck is not running right now, please see details below (bottom). It will need to be towed to its new home.
GM official Factory Service manual for Motor and Transmission included.
Have all receipts since purchased in 2006.
Upgrades:
· Diamond style headlights, all new front grill / clip / turn parts. $500 investment that was on the vehicle for only the last 500 miles. From MrTailight.com
· Following Parts from SSDIESEL Supply (ssdieselsupply.com)
o STAINLESS STEEL 4 INCH TURBO-BACK EXHAUST
o HIGH PERFORMANCE MARINE INJECTORS
o 3 GUAGE POD CONTAINING: EGT, BOOST, AND TRANSMISSION TEMP (never installed sensor for tranny temp.)
o Programmed chip specific to this truck
o Upgraded dual thermostat cooling system
o DURAMAX COOLING FAN.
· Sony CD / MP3 player
Parts Replaced:
· Injection pump (and PMD, relocated to prevent failure) – July 2006
· 4 new tires (BFG Commercial) – 2 have a few thousand miles on them, 2 have about 10,000 on them. – June 2006, and November 2007
· New vacuum pump (actuates waste gate.) – June 2006
· New front brake calipers and brake pads – June 2006
· New front brake lines – June 2006
· New sway bar bushiness - June 2006
· 2 new batteries: February 2007
· New Alternator: February 2007
· New A/C Compressor: June 2007
· New Poly body mounts: September 2007
· Driveshaft Ujoints: October 2007
· Steering pump, hoses, and steering box: January 2008
· Idler Arm
· All 4 shocks
· Turn signal switch assembly (dealer new)
· Belts, Hoses, Belt tensioner assembly
· Front Disc Brakes
· Crankcase Depression Regulator Valve
· Waste gate Solenoid Valve
New parts that are included BUT NOT INSTALLED YET:
· FRONT and REAR evap cores
· A/C Accumulator
· Rear Main Seal
· New Starter Gear
· Rear Axle outer oil seals (one is leaking slightly.)
· A/C orfices for front and rear.
READ THIS: DETAILS ON WHAT IS WRONG WITH THIS VEHICLE:
· The starter gear sheered while starting the last time it was started. The starter motor cannot start the truck. I began repairing this, which is when I decided I’m just done with this vehicle, and need to move onto a 4WD one if I’m going to invest the time. The transmission is half removed, and resting on the transmission cross member.
· I believe the drivers side head is warped, or most likely cracked. It’s not uncommon in these motors at high mileage. A new head can be had for $300 or so (I suggest ssdieselsupply.com, they’ve been great to me over the years.) This will need to be fixed by someone with some mechanical skill, or a weekend mechanic with more time than I do.
· There is a leak in the evaporator coil (front) in the air conditioning system. The A/C works great for a few days, but it slowly leaks out in the evap coil (diagnosed by Firestone). I purchased all the parts to make both the FRONT and REAR air conditioning work, but with the other problems the truck has right now, I don’t have the heart to start the process of replacing more parts. All the parts you need should be included, as pictured.
· The tumbler (thing that allows the key to turn) will not turn all the way to the start position. I’ve installed a start button that’s ignition-hot, and turn the key to the run position, then use the ignition button. You can replace the tumbler if you choose, I prefer the button.
TERMS OF THE SALE: THIS VEHICLE IS BEING SOLD AS –IS. NO WARRANTY IS EXPRESSED OR IMPLIED, WHATSOEVER. THIS VEHICLE MUST BE PICKED UP AND PAID FOR WITHIN ONE WEEK OF THE AUCTIONS CLOSE.
PAYMENT TERMS: CASH ONLY. You are responsible for ANY AND ALL transfer fees, including local taxes, processing fees, etc. I will sign the title over to you, and it is no longer mine.
PICTURES: If you’d like pictures of anything specific, please email me matt@pgh-offroad.com and I will send them to you.
I need this gone. It's on ebay with no reserve and a starting bid of $1.00 -- whatever it sells for, it sells for.
http://cgi.ebay.com/ebaymotors/ws/eB...m=150340705292
