Project White Noise - Page 6
Thread: Project White Noise
Page 6 of 21 FirstFirst 12345678910111213141516 ... LastLast
Results 126 to 150 of 522
  1. #126 Re: Project White Noise
    Jul 2008
    North Carolina
    Quote Originally Posted by Jeeperoni91 View Post
    looking good clay. where's my old lift now?
    Where have you been? Has the ZJ sold yet? I am still waitining on pictures of the Ferd
    Quote Originally Posted by 2KFLEXJ View Post
    Its in my shed... lol.
    Brett, your lift is in his shed right now
    Good progress Clay... looking forward to seeing this at harlan in 6 weeks
    Thanks Cam. I can't wait to make it. Hopefully I am getting the sterring straightened up this week, along with adding a power steering cooler.
  2. #127 Re: Project White Noise
    my jeep sold...and got brought back..
    so i still have the jeep and cams lift
    and maybe ill post some pics of the ferd for you to drool on later clay
    97 V8 zj.
    03 Cobra with horsepowers
  3. #128 Re: Project White Noise
    Jul 2008
    North Carolina
    So what the heck happened?
    You better you dirty SOB
  4. #129 Re: Project White Noise
    minus the chrome fender shit in picture now
    yeeeeee
    97 V8 zj.
  5. #130 Re: Project White Noise
    Jul 2008
    North Carolina
    Finally! haha
    So is it a 7.3 or a 6.0?
  6. #131 Re: Project White Noise
    6.0 with fresh head gaskets
    97 V8 zj.
  7. #132 Re: Project White Noise
    Jul 2008
    North Carolina
    Nice. You going to take the jeep to URE at all before you sale it?
  8. #133 Re: Project White Noise
    nope, i dont even drive it around at all
    97 V8 zj.
  9. #134 Re: Project White Noise
    Jul 2008
    North Carolina
    You should borrow a trailer and tow it to URE until it sells
  10. #135 Re: Project White Noise
    Jul 2008
    North Carolina
    OK, a little update. I have put about 250 miles on the jeep since all the upgrades. I have had it aligned two times, and the caster is now aorund 5 degrees. The steering still SUCKS. It is down right scary driving on the road. I had the hydro assist ram rebuilt and that did not help the steering problem. So as of right now the ram has been removed and the tapped holes on the steering box are plugged.
    I need some opinions. I also posted this in another thread, but why not here as well. Right now I have a XJ steering box installed in the jeep. It is tapped for assist, but it seems like it is need of a rebuild and that could possibly be the issues with my hydro assist. Maybe the assist is enhancing the problems with the box. In my garage I have a stock waggy box with the 4th mounting hole. What should I do? Should I have the waggy box rebuilt and tapped, or should I have the XJ box that is already tapped rebuilt?
    If I put in the waggy box, what else am I going to have to change in my steering?
  11. #136 Re: Project White Noise
    Jul 2008
    North Carolina
    Just drove the jeep with out the ram, just regular good 'ole power steering, and it drives so much better!
  12. #137 Re: Project White Noise
    Seattle, WA
    That sucks the assist is giving you such problems. Just for my own personal reference, do you know what your toe was set to?
    I collect Jeeps.
    The Polar Bear Detailed Build
  13. #138 Re: Project White Noise
    Also what diameter is your ram?
  14. #139 Re: Project White Noise
    Jul 2008
    North Carolina
    My toe was I think -1, but I am having it aligned again today so I will know exactly this afternoon.
    I don't know the exact, but I am thinking it was 2", just a guess, I will measure it tonight for sure.
  15. #140 Re: Project White Noise
    May 2005
    Boone NC
    i was wondering the same thing after you said it worked better without the ram..
    im not a big fan of hydro assist but i've never ran it. Are you running an upgraded PS pump? if not that could be your problem.. the pump cant keep up with the box and the ram.
    a guy that wheels with us had an issue with his pitman arm once , he had assist and was still able to steer it back to camp. he said it was taking alot of input from the wheel to get the ram. the way he described it he said he had to turn the wheel several turns before the ram would do anything. sounds a little similar to what you are experiencing.
    you are running a lockright in the front right?
  16. #141 Re: Project White Noise
    Jul 2008
    North Carolina
    I am running an aussie in the front.
  17. #142 Re: Project White Noise
    May 2005
    Boone NC
    if i were you i'd just drop the assist for simplicity sake. if you can't turn your wheels you probably don't need to force them. it'll be a favor to your d44 balljoints and knuckles. when i was wheeling the 44 i developed a rocking method to get the wheels turned the right direction in tight spots, basically rocking the rig forward and reverse and turning the wheel slowly while it rolled and i never had an issue with the balljoints or knuckles until i went to 38" tls..
    just my .02.. fwiw
  18. #143 Re: Project White Noise
    I like the idea of hydro assist, and the WJ will probably get it at some point.
    Clay, 2" sounds MASSIVE for hydro assist, I think the average is like 1.5"? The volume difference to push the two is huge.
  19. #144 Re: Project White Noise
    Jul 2008
    North Carolina
    I think I may just run without the assist for now and see how it goes.
    I think the ram is 2" but I could be wrong, I will take a look at it again tonight.
  20. #145 Re: Project White Noise
    Seattle, WA
    Toe should be .04 to .44*. Can you let me know what it turns out to be? Thanks.
    I collect Jeeps.
  21. #146 Re: Project White Noise
    Jul 2008
    North Carolina
    OK, just picked up the jeep and got home.
    Where do you measure the ram for circumfrence? If it is just the part that goes in and out then mine is 3.5"
    As for the toe, after the alignment today it is .04 and .09 left and right respectively.
  22. #147 Re: Project White Noise
    Jul 2008
    North Carolina
    First shake down run before GSSE. Went to URE today, the jeep is a beast! Have a real sqeaky front end when in 4wd and turning, going to have to figure that out.
  23. #148 Re: Project White Noise
    Beaumont, Texas
    Looks killer dude, you runnin limit straps?
  24. #149 Re: Project White Noise
    Jul 2008
    North Carolina
    Oh yeah, limit straps front and rear, but there is still a ton of flex with them, I am very happy with the set up.
  25. #150 Re: Project White Noise
    Jul 2008
    North Carolina
    A few more from yesterday
