Project White Noise - Page 4
Thread: Project White Noise
Page 4 of 21 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 522
  1. #76 Re: Project White Noise
    Junior Member AJEEPINDEEPZJ's Avatar
    Jul 2009
    Summerfield, North Carolina
    Went to Uwharrie this past weekend in the mud. I tore off my driver sideview mirror, busted my passenger tail light, and ripped the plastic cladding off the driver side. All in all a great time! haha
    Anyone have a mirror for sale?
    Lets see pics of the carnage! as for the mirror, i would suggest go to the local u-pull-it to grab one
    93 ZJ 4.5",RE long arms, tom woods ds, 8.8 swapped, custom bumper, b&m trans cooler, 32s, few dents here and there
  2. #77 Re: Project White Noise
    Jul 2008
    North Carolina
    I didn't get any action shots, but I have a couple of the aftermath back at the Outpost. I will get them up soon enough haha.
  3. #78 Re: Project White Noise
    Jul 2008
    North Carolina
    Got the rear bumper on today!
  4. #79 Re: Project White Noise
    Jul 2009
    Looks good Clay! im diggin that color scheme too.
  5. #80 Re: Project White Noise
    Jul 2008
    North Carolina
    Thanks man! The body will eventually be all black, and think the silver bumpers will look awesome.
  6. #81 Re: Project White Noise
    Utah
    Looks really good!
  7. #82 Re: Project White Noise
    Jul 2008
    North Carolina
    Thanks man!
  8. #83 Re: Project White Noise
    Jul 2008
    North Carolina
    Mounted the hi-lift today.
  9. #84 Re: Project White Noise
    Dinwiddie, VA
    Lookin good! New goodies are on the way!!!
    "Matt"
  10. #85 Re: Project White Noise
    Jul 2008
    North Carolina
    Limit straps... where do you get them?
  11. #86 Re: Project White Noise
    poly perf
  12. #87 Re: Project White Noise
    Yeah polyperformance. Spend the extra coin on the quad wrap ones. I'm running the dual wrap ones, but there are numerous reports of the dual wrap ones breaking (happened to a friend actually). A cheaper setup is to cut up some ratchet straps. jdconti did that after his first attempt at limit straps broke. After some tuning of the length, they were really effective.
    Any type of fabric limiting strap is going to stretch over time, so make your limit strap mounts (or the straps themselves) adjustable to account for this. Or you can setup your straps an inch or two too short. In addition "shock loads" to the limit straps (i.e. dropping off of a rock and articulating the axle at the same time) will probably make them stretch a bit more.
    EDIT: SDHQ also sells them. Although you might need to be a red star member over there to view this: http://www.pirate4x4.com/forum/showthread.php?t=857971
  13. #88 Re: Project White Noise
    Jul 2008
    North Carolina
    Thanks guys, that is what I was looking for.
    Anyone have any pictures of what the axle side and unibody side mounts look like?
  14. #89 Re: Project White Noise
    May 2005
    Boone NC
    mounts for what?
  15. #90 Re: Project White Noise
    Jul 2008
    North Carolina
    Maybe I should have said tabs. I just wantt o see how/where people put the limit strap tabs on the uni
  16. #91 Re: Project White Noise
    Senior Member dp96zj's Avatar
    Texas
    I *think* I remember seeing Fuego's limit strap pics on his thread. Pretty sure it was before he ditched all those pesky body panels.
    I'm sure other people will post pics anyway.
  17. #92 Re: Project White Noise
    On the uni side, drill some holes in a plate/angle iron, weld on some nuts, make room on the unibody to fit nuts, weld nut plate to uni. The axle side you can use shock mounting tabs. I'm sure you could figure out an easier way to do it, but this setup has given me no issues. It was setup this way before the body panels were gone. In fact, i'm still running this same setup since I still have the uniframe.
  18. #93 Re: Project White Noise
    Jul 2008
    North Carolina
    Well last night I dropped the jeep off at my buddy's shop. Here is what is about to go on the 'ole jeep:
    Clayton longarms front and rear with 4.5" springs and 1" spacers
    1999 Explorer 8.8 in the rear
    Dutchman shafts with 6x5.5 bolt pattern for the 8.8
    4.88 gears and an Aussie in the 8.8
    Front 1990 Waggy D44
    4.88 gears and an Aussie in the 44
    Chromo shafts and 300m joints for 44
    Warn Premium hubs
    Hydro assist
    Tom Woods drive shafts front and rear
    Advance Adapters SYE
    35x12.5r15 trxus mts on ProComp wheels 6x5.5 bolt pattern with 2.5" BS
  19. #94 Re: Project White Noise
    Charlotte, Nc
    whewwww buddy that will be nice
  20. #95 Re: Project White Noise
    What brand 300m joints you going with? longfields?
    Keep them religiously greased or the hubs turned out when you are covering a lot of ground. I've seen some that wore out in short order when run with drive flanges.
  21. #96 Re: Project White Noise
    Jul 2008
    North Carolina
    They are Longfields, and I am using Warn Premiums, so they will be unlocked for all street driving. Instead of these joints what would have been a better choice (for future reference)?
  22. #97 Re: Project White Noise
    I think the Long joints are a killer deal for the money. My friend who had trouble with them had issues trying to baja his slugged 60 around with rare maintenance and he has broken about everything else short of 300m axle shafts and a 205. The cross eventually wore flat from lack of lubrication. You should be fine if you do regular maintenance.
  23. #98 Re: Project White Noise
    Jul 2008
    North Carolina
    Went by and visited the jeep today. It looks awesome so far!
    Here is the 8.8 all ready to bolt up
    Here are a couple shots of the rear long arms
    SYE bolted up
    Clayton's rear triangulated shock mount
    A couple shots of the unibody stiffiners welded up
  24. #99 Re: Project White Noise
    Jul 2008
    North Carolina
    Quick cell phone teaser pic. Should be driving her home this weekend.
  25. #100 Re: Project White Noise
    Member delawhere's Avatar
    Aug 2005
    newark delaware
    looks awesome man
    now all you have to do is paint the body and its a new jeep
    98 5.9L Clayton long arm locked armored. ready to rock&roll
