Just delete the washer system to offset the weight of the exo
LOL
I may just carry a spray bottle with me for those dusty rides
Cage is complete
Looks great! You know you are supposed to fix those lights with Nascar approved 200mph duct tape right?
LOL, good 'ole clear box tape is working good so far
So now that my rig is getting pretty heavy with the bumpers, sliders, and cage (not to mention all the tools I carry and my big a**), would a stiffer spring benefit me?
nice tube work man.
Thanks, wish I could take credit for fabbing it
OK, need some honest advice. Here is my delima.
After adding the front and rear bumpers, and the cage, I have added well over 350lbs of weight to the jeep and I am sitting about 1" lower now than I was before.
I am currently running 4.5" RE springs, I have 1" spacers on both of the fronts and then... get this... to level out the rear I have a 2" spacer with another 1" spacer on top of it on the passenger rear and a then only a 1" spacer on the driver rear. WTF???
I have even swaped the springs around in the rear with the same result, so the only think I can think of is the spring perches must not be level (haven't measured yet, but I will).
Here is my question. I think the RE springs are too soft for me, so I am contemplating getting BDS springs (higher spring rate). So should I go with 4" springs (4.5" in the front and 4" in the rear) and add spacers again, or shoudl I get the 6" springs (6.5" in the front, 6" in the rear). I personally don't like stacking spacers, but I also don't like having a lopsided sig.
Thoughts?
I know you said that you swapped springs, but are you sure that your springs are properly seating on both the chassis and axle side?
Keep in mind that the front springs can also affect how high the back springs sit (due to weight distribution). When my rig had the back chopped off, my rear sat about 2-3" higher than it did before. Once I added in 1" spacers to the front, everything basically leveled out.
I have no idea if this happened or not, but I almost wonder if your unibody was tweaked when the exo went on and the exo just "locked" it into place. Before the tube went on, my buddy made a rear bumper for me. Said bumper fit perfectly in my rig, but when you look at it, it was far from square. When I sold it to a friend, the same buddy installed the bumper on my friend's ZJ. I was told that it was a royal PITA to install because his rig wasn't tweaked like mine was. I never really paid attention to how uneven my rig sits from side to side, but I'd bet that it's not equal.
As for the springs, a stiffer spring would probably be a good idea. That said, assuming that two springs are setup to to give a ZJ 4.5" of lift -- a softer spring should be longer than a stiffer spring. As such, the stiffer spring will sit a bit higher with your extra weight -- but may not be long enough to completely get you back to 4.5" lift. There is some math you could do (simple measurements and some simple calculations) to get a ballpark estimate of your unsprung weight -- which you can then use to get an estimated ride height of new springs -- but I have no idea if it's really be any more accurate than just picking a spring for a bit higher lift and trying it due to the variance in actual spring rates.
That would probably be the simple way to do it and I don't know that you would notice much of a difference over the way I would do it. The way I would do it (and I am intending to do this after my wedding stuff is over because I'm in the opposite boat as you where I need a softer spring in the rear) is to measure ride height compared to droop and use the known spring rates of RE springs to figure out and estimate of unsprung weight. Then I would use the unsprung weight to figure out the length and rate of an ideal, theoretical spring that will sit at the ride height I want. Once I figure that out it's a matter of finding a spring that matches it as closely (keep in mind that front TJ and XJ lift springs can be used, so you aren't just limited to the options for your ZJ). My situation is a bit different than yours though because I think I need to get into "TJ" spring rates for me to get the ride height and softer springs I need.
That said, I'm probably just over-complicating the process, and I have no idea if this will yield better results for you than just getting 5.5" or 6" lift springs (it probably won't be noticeable). But in all honesty, that's the main reason I want to go through that -- to see how closely the calculations mimic real life.
Let me know if you want to give it a shot. It involves nothing more than a total of 8 measurements (4 at ride height and 4 with each spring fully extended), some basic calculations, and some research of spring rates and lengths.
Thanks Jared, but you know I am too lazy for all that
I think I will wing it and buy the BDS coils, thanks for all the input!
I'm diggin the fresh paint on the drivers rock rail and the black on the pass side..
Yeah the Exo makes it look 'different' but it is growing on me more and more. The jeep really isn't pretty to begin with, I have gone for more of a function over form build. Hopefully this will save my noggin if were ever to roll.
Damnit Trey you pay too close attention to the details I just sprayed the passenger side last night (ran out of paint, and was too lazy to run back to Lowes)
So what happens when you are in a hurry to drop off a trailer and you have to back down a narrow gravel road that has a ton of turns and trees on both sides... this...
Clipped a tree trying to straighten out the trailer. I was going a little fast and wasn't paying attention like I should have... damn
That 'll buff out. Lol
LOL, I wish it would This is another reason to have a dedicated tow rig, if this was my DD, I would be really pissed.
Reminds me of the scene in Tommy Boy where he backs up at the gas station.
That sucks.
LOL, I know the scene well
BDS 6" springs came in today, hopefully getting them on this weekend.
clay i saw you post up about the suburban on nc4x.. you thinkin about changing tow rigs?
I had a thought, but I think the Dodge will serve me best. That burb sure is unique, but in all honesty when I posted up I was thinking it had a cummins in it, I just figured no one would want a 6.2 or 6.5 chevy diesel
