Project White Noise - Page 10
Thread: Project White Noise
Page 10 of 21 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 226 to 250 of 522
  1. #226 Re: Project White Noise
    Jan 2010
    SLC UT
    I have a welder!!
  2. #227 Re: Project White Noise
    Jul 2008
    North Carolina
    Great news! The jeep started today with no problem, the winch still works and the transmission shifts into all gears no problem! So hopefully all the damage was just to the steering.
  3. #228 Re: Project White Noise
    Jan 2010
    SLC UT
    HELL ya man glad to hear that I cant wait to wheel with ya this year!!
  4. #229 Re: Project White Noise
    Jul 2008
    North Carolina
    Finally getting the Jeep towed tomorrow to get everything fixed. I am going to fix everything, but one upgrade is I am adding a Clayton belly skid.
    I originally primed the bar metal skid and then starting spraying it with bedliner. Well I learned that bedliner is not compatible with regular metal primer... as soon as I sprayed the bedliner over the primer (after 48 hours of dry time on the primer) the primer started bubling up under the bedliner. So I had to scrape all the remaining primer off, I had to use brake cleaner to get the primer off, and then spray the bedliner directly onto the bare metal.
    MMMM bedliner
    Here is all the scraped off primer
  5. #230 Re: Project White Noise
    Jan 2010
    SLC UT
    Hell ya man cant wait to see ya out on the trails this year
  6. #231 Re: Project White Noise
    Dinwiddie, VA
    Looking good bro!
    "Matt"
  7. #232 Re: Project White Noise
    I would suggest having the shop you are taking it to weld some angle iron supports to stiffen up the skid plate.
  8. #233 Re: Project White Noise
    Jul 2008
    North Carolina
    What do you suggest for supports (ie where)?
  9. #234 Re: Project White Noise
    The side bends do a good job at preventing the sides from getting bent, but the skid is so big to where the middle becomes the weak point. I would cross two pieces spanning as far across the skid as possible. That should hopefully stiffen it up to the point that it should be less likely for the skid to bend.
  10. #235 Re: Project White Noise
    Bedliner on a skid plate is a waste. Paint the thing with some .99 cent black for it gets removed by rocks.
  11. #236 Re: Project White Noise
    Jul 2008
    North Carolina
    Cool, thanks for the advice.
    I was wondering what was removing the paint from my sliders, it must be the rocks, who would have thought I used Rustoleum bedliner, and around here it goes for $4 a can, so for $3 more maybe it will last one more wheeling trip than the $.99 can.
  12. #237 Re: Project White Noise
    I have used that rustoleum bedliner on a few projects. It is pretty damn tuff.
    2004 Ford Lightning
  13. #238 Re: Project White Noise
    Jul 2008
    North Carolina
    It seems pretty durable, so we will see how it holds up on the skid.
  14. #239 Re: Project White Noise
    Jan 2010
    SLC UT
    Probably not good lol I have almost no powder coat left on my skid after just a few outings at URE
  15. #240 Re: Project White Noise
    Jul 2008
    North Carolina
    Got the jeep back home today!
    New ECGS 1 ton steering
    New Clayton belly skid
    New Flowmaster Hushpower exhaust
  16. #241 Re: Project White Noise
    Jan 2010
    SLC UT
    Looking good man!
  17. #242 Re: Project White Noise
    Jul 2008
    North Carolina
    Thanks, can't wait to get to URE!
  18. #243 Re: Project White Noise
    May 2005
    Boone NC
    thats a shiney new cat you got there too clay...
    glad to see it back together dude
  19. #244 Re: Project White Noise
    Jul 2008
    North Carolina
    LOL, thanks Trey bu the shiny part is the muffler, the cat is the same just a little lighter
  20. #245 Re: Project White Noise
    Jul 2008
    North Carolina
    Guess what... April 16, there might be some changes to the ZJ, stay tuned
  21. #246 Re: Project White Noise
    So how is the steering? Any dead spot?
    2004 Ford Lightning
  22. #247 Re: Project White Noise
    Jul 2008
    North Carolina
    Steering is great, no dead spots, got to really test it out yesterday.
  23. #248 Re: Project White Noise
    Jul 2008
    North Carolina
    The jeep is back!!
  24. #249 Re: Project White Noise
    Nice work man! Way to be patient. I was waitin for you to get pissed and throttle it.
    2004 Ford Lightning
  25. #250 Re: Project White Noise
    Member Dels383TA's Avatar
    Aug 2008
    Moncton, New Brunswick, Canada
    Cool vids, just wondering what you are running for tire pressure, I a usually around 10-12lbs in that kind of rok, but your tires dont seem to have much squat to them.
    96 5"lift,44 rear HP30 front, locked all the way, 5.2swap, 9.5 Keeper Winch,33" Firestone Destenation MTs,custom rear bumper,2" trim, and a set of kick ass rockers.
