Project White Noise - Page 2
Thread: Project White Noise
Page 2 of 21 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 522
  1. #26 Re: Project White Noise
    Jul 2008
    North Carolina
    That is another sketchy thing is before I have always gotten a printout to show that everything is in spec, but this time, no printout. I got it done at a Merchant's Tire here in Greensboro, NC.
  2. #27 Re: Project White Noise
    Feb 2008
    oregon
    Quote Originally Posted by Brad S View Post
    nah, don't pay someone else to do it, you can do it yourself.
    just loosen the nuts on the drag link adjustment sleeve and twist it a bit until your wheel is straight again.
    if its a DD or if it sees street driving he should take to a professional, they have machines that can do what an eye ball or tape measure cant. sounds like the OP did take it to a shop and they returned it like that though. take it back because centering your steeringwheel is part of an alignment.
  3. #28 Re: Project White Noise
    Senior Member Goosed76's Avatar
    Mar 2008
    Saint Helens, OR
    Quote Originally Posted by BigClay View Post
    yeah, you should always get a print out with an alignment. Just because it drives straight, doesn't mean the angles are within spec. You can run a car with more Toe in than necessary and have it drive straight, but will wear you tires super fast, etc. Take it back, raise hell, and get it done right. Remember, he who bitches the loudest usually will get what he wants. I'm surprised the steering wheel wasn't centered- it's a super easy adjustment to make. Did you have them adjust your Caster with the new arms, and possibly center the axle? Might cost more, since it's more than the factory adjustment, but worth it. And get a print out.
    93' ZJ, 4.0L, 3" lift, 31's.. SOLD.
    New Ride- 1998 Ford Ranger 4x4, 4.0L, 5-Speed, 4x4.
    NEW JOB!!!!! NEW BABY!!!!
    Now considering another XJ/WJ/ZJ purchase as a baby mover- No room in the Ranger.
    Leaning towards XJ, 99-01.....
  4. #29 Re: Project White Noise
    Jul 2008
    North Carolina
    Thanks guys, I am going to take it back there on Thursday after work. Then that will probably be my last visit to that shop.
  5. #30 Re: Project White Noise
    Jan 2008
    Wichita, KS
    Changing the orientation of the steering wheel does not effect driveability of the vehicle.
    I agree, if you paid the shop for the alignment, they should have done that for you.
  6. #31 Re: Project White Noise
    Jul 2008
    North Carolina
    I have had the jeep in the garage for what seems like forever, but it finally has a new coat of paint on the roof. I do not have a sprayer, and didn't want to do a rattlecan job, so I was left with rolling and wet sanding. I used JD Blitz Black, and for a roller job, I think it turned out OK.
    Here are some before and after pictures of the roof. I think I am going to wait a while before I even prep the rest of the jeep (I am tired of her sitting in the garage).
    Now here is how it looks now:
    I also painted the Carolina Rock Shop bumpers:
  7. #32 Re: Project White Noise
    Mar 2008
    Saint Helens, OR
    Wanna do mine next ? Also have a white ZJ- and the paint is-a-peelin'
    Not as bad as yours was, but on it's way there...
  8. #33 Re: Project White Noise
    Jul 2008
    North Carolina
    I really think it is a 93 thing, because most of them that year have problems with the paint on the roof and the hood. Just don't take yours to the pressure washer... or you will have a primer grey/white jeep (ask me how I know).
  9. #34 Re: Project White Noise
    Jul 2008
    North Carolina
    I don't seem to do anything fast so now after having the KOR LP-1 sliders sitting in the garage for over 6 months, I am finally getting around to installing them. I also painted the side grey plastic cladding black.
    I didn't have any help putting the sliders on, and I really don't think a helper would have made it any easier really
    I also repainted the front grill since it had already started to chip.
    Overall the install went OK, those self tapping bolts that you have to use for the "frame" take a little while to get started, and I also don't think you could do this install without a right angle extension on your drill. After all is said and done, these slifers are extremely strong. I am about 280, and I can stand on the sliders and bounce up and down and they do not budge. Very high quality, which is par for the course with KOR stuff.
  10. #35 Re: Project White Noise
    Member mrhotwheels's Avatar
    Jul 2009
    Ferndale, Washington
    All the blackout treatment looks killer!
    '97 ZJ Laredo 4.0. Bone stock, NP 242J, Dana diff's. Dreamin' of all the mods I want to do....
  11. #36 Re: Project White Noise
    Mar 2008
    Saint Helens, OR
    Did you tape the Plastic prior to paint? or remove/paint/reinstall? Also have a white ZJ, have considered doing the black cladding as well...
  12. #37 Re: Project White Noise
    Jul 2008
    North Carolina
    Goosed, I left the cladding on the jeep and just taped it up. I did the passenger side first, and afterwards realized that I did not tape up high enough, so I had to wet sand some of the overspray off the door. For the driver side I just taped much higher and it came out fine. The whole jeep is getting a coat of black paint come fall, so I was not really worried about over spray.
  13. #38 Re: Project White Noise
    Mar 2008
    Saint Helens, OR
    Sweet- thanks. I've considered doing this with a cheap Maaco paint job to hide the paint that is flaking off on the roof/hatch and doors- either doing white again, or something else, Caution Orange? lol
  14. #39 Re: Project White Noise
    Are those Brett's old bumpers? From his green ZJ?
  15. #40 Re: Project White Noise
    Jul 2008
    North Carolina
    Goosed, I have thought about doing the rest in yellow as well! haha
    Elliott, yep, he hit a deer about a year ago and his jeep was totalled, I tried buying them off him but he already sold the entire jeep to someone else. I ended up buying the bumpers from that other guy.
  16. #41 Re: Project White Noise
    Jul 2008
    North Carolina
    Here are some pics of the passenger side slider (those self tapping bolts were a PITA!)
    And here is what happens when you don't clean up your work area and you trip and fall on a jack stand
  17. #42 Re: Project White Noise
    Junior Member AJEEPINDEEPZJ's Avatar
    Jul 2009
    Summerfield, North Carolina
    ive seen this jeep before...i was looking at houses for rent and i drove by this outside..keep up the good work..if you need any assistance with anything i only live 5 min away
    93 ZJ 4.5",RE long arms, tom woods ds, 8.8 swapped, custom bumper, b&m trans cooler, 32s, few dents here and there
  18. #43 Re: Project White Noise
    Jul 2008
    North Carolina
    Small world, yeah the jeep normally is parked on the street in front of my house. I might have seen yours around town, what color is it?
  19. #44 Re: Project White Noise
    Jul 2009
    Grey with a stinger on the front
  20. #45 Re: Project White Noise
    Jul 2008
    North Carolina
    I can't say I have seen it.
    Same goes for you, if you need a hand with anything, give me a shout!
  21. #46 Re: Project White Noise
    Jul 2008
    North Carolina
    Got any pictures of yours?
  22. #47 Re: Project White Noise
    You both will have very similar items on your jeeps in about a week or two
    and change your avatar one of you! it's confusing me!
  23. #48 Re: Project White Noise
    Jul 2008
    North Carolina
    Well I guess we must both think alike. I was kinda hoping I would be the only one around here with the tube doors, but guess not, haha
    I really should pony up the $$ and become a supporting memeber so I could have a better avatar. hey Max, if you want you can discount my doors a little and I will use that for my membership fee!
  24. #49 Re: Project White Noise
    Jul 2008
    North Carolina
    Just got back from trip to Uwharrie today. AWESOME! Even got a trail scar to remember it by!
    This was one huge pit, but my heep made it through with just the one little "love mark"
  25. #50 Re: Project White Noise
    Dinwiddie, VA
    Looking good man!
    "Matt"
