Project Chewy - Page 4
Thread: Project Chewy
Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 103
  1. #76 Re: Project Chewy
    Damn welder broke...just when I get a weekend off...
  2. #77 Re: Project Chewy
    Asshole Extraordinaire Lifetime Supporter
    MallCrawlin Supporter
    Kauzi Zj's Avatar
    Apr 2009
    Grand Junction, Colorado, United States
    Damn Looking Good!!!! Hopefully I will be able to start working on some fab stuff beginning in Sept!
    "I will offend a bunch of you. I do not know what your moral boundaries are, so I'm probably going to cross them at some point. I sometimes even go beyond my own moral boundaries -- that's how I know I still have them."
    Tosh.0 (Loosely translated by Fuego)(slightly modified to fit my needs!)
  3. #78 Re: Project Chewy
    not the most detailed build post but it shows some progress!
    all welded up
    primed.
    painted w/accessories!
    still need to install winch/fairlead.
  4. #79 Project Chewy
    more progress!
    tabs,truss and brackets from Battlement fabrication
  5. #80 Re: Project Chewy
    Been a while since I posted in here so I'll update what's going on.
    Adding a 9" rear and hp44 front
    Not many pics but I'll post what I get when I find time
    The 9 getting armour.
    Build it. Lock it. Crawl it.
  6. #81 Re: Project Chewy
    Christmas in march!!!
  7. #82 Re: Project Chewy
    Gittin some intsalled
    More pics to come
  8. #83 Project Chewy
    Now for some Dana 44hp wheel hub tech
    Pics inside the hub with races installed
    The spindle with fresh 7/16-20 bolts/locknuts
    The bearing setup what it will kinda look like inside when installed
    You'll have to turn the inner spindle nut to line the pin up with the locking retainer holes then the outer nut goes on!
    you'll need an axle/spindle socket to get it tight ( they rent them at some auto parts stores or you should just buy one for $15-$20 for your rig!)
    The notches should line up
    Just like this!
    Be sure to pack it well with high-temp wheel w/disc brake grease you don't want this going dry!
  9. #84 Re: Project Chewy
    Restored the knuckles, spindles and caliper brackets
    Scraped down and shot with rust converter/restorer
    Then painted ( and of course I later installed double shear arms then repainted)
  10. #85 Project Chewy
    And some more pics
    Special paint job I can scrape off on rocks!
  11. #86 Re: Project Chewy
    Sittin under with only the trac bar hooked up
    Should be close to where it will sit when finished...
  12. #87 Re: Project Chewy
    ...I'm bringing sexy back! Chewy should be running around here shortly!!!
  13. #88 Re: Project Chewy
    keep going!!!!!lol
  14. #89 Re: Project Chewy
    So the trial running of the engine was a success!!!! The first time since I got the jeep 8 years ago it has charged at 14v+ and no Matter how much power was turned on it compensates to match!
    Seems this was the culprit:
    So I put in a new 5.9 (136a) alternator and replaced the wire harness
    So I had my son do the honors and toss that burden in the can!!! 😂😃😁
  15. #90 Re: Project Chewy
    So putting the gears back in I noticed that the ring gear is a hair away from the cast when at full set pinion/backlash etc.., it should clear but of any concerns?
    But they're back in since June!
  16. #91 Re: Project Chewy
    And took it for a test drive just to find more crap!
    Trac bar is loose, the rear drive line shakes pretty bad and the 9" 3rd seems to be missing a yoke seal!
  17. #92 Project Chewy
    Anybody else have the Claytons trac-bar? Cause the threads on the jj end have loosened up and caused a lot of play!
    The threads look fine Not stripped or worn.
  18. #93 Re: Project Chewy
    Clemson, SC
    I had that happen to me.. don't remember what I did to fix the problem. Might can run a tap and dye through the joints and tube inserts.
    Got any pictures of your coilover mounts? and have you gotten the orbital mounted up yet? I have been thinking of doing full hydro rather than assist on my 44.
    -Ronnie
    98 5.9 on 35s
  19. #94 Re: Project Chewy
    Sure I'll take some shots maybe tomorrow of all the mounts!
    The thing I will say is only go full hydro if you don't use much on the highway or over 55mph cause it does get squirrely!
    It is flat out awesome off-road!
    turn with 1 finger even in the most awkward spot!
    If you want the best of both tap the box and go assist!
  20. #95 Re: Project Chewy
    Clemson, SC
    Yeah my plan was a surplus ram, stock pump drilled out, buy a resevoir and tap my current box. Should be around 200 to get it done. I was only gonna do hydro if I found a used orbital on pirate or something.
    -Ronnie
    98 5.9 on 35s
  21. #96 Project Chewy
    Got a few pics of orbital+reservoir etc, and some coil-over setup shots
    Driver side
    Pass side
  22. #97 Re: Project Chewy
    Does someone know if there's a write up of ZJ steering wheel replacement (with working pics!)
  23. #98 Project Chewy
    Some new additions
    Yukon alloys
    I know ...it's about time!
  24. #99 Re: Project Chewy
    End of an era poor Chewy took his last breath today and is now in hell...
    first Jeep, first grand, the Jeep my wife and I had many dates, camping trips, wheeling trips, fishing trips and road adventures with.
    First unibody and where I learned (sometimes the hard way) most of what I know about grands
    The o’l stealth crawler is gone and will be missed but never forgotten.
  25. #100 Re: Project Chewy
    RIP!
