Thread: Loud ass noise - not sure where to start
Results 1 to 14 of 14
  1. #1 Loud ass noise - not sure where to start
    Santa Fe, NM
    Under heavy accel in 4 wheel full time only. It sounds almost like a bad u-joint does (clicking sound, but louder). I'm thinking it may be the t-case chain, but it only does it in full-time, not in part time or 2wd. If I'm not heavy on the gas it doesn't make any noise at all. It doesn't seem to make any difference if I have the wheel cranked one way or the other or not.
  2. #2 Re: Loud ass noise - not sure where to start
    Senior Member Spr-T-23's Avatar
    Oct 2008
    Imlay City, Michigan
    242 t case i assume, i think it has a diferental for full time 4x4
    96 ZJ, Black, 5.2, Auto, 242 Swap, D30 D44a, 3.5 inch lift and 2 inch poly boost 5.5 inches total lift, 33/12.5/15 BFG MTs on Chrome steelies
  3. #3 Re: Loud ass noise - not sure where to start
    Mar 2007
    Quote Originally Posted by Spr-T-23 View Post
    Huh?
    Anyway, it sounds like it's probably the transfer case chain. From experience, that loud popping will eventually lead to a loud bang, followed by metal and t-case fluid on the ground.
    Any other description you could offer so we can better try and diagnose?
    ~Franklin D. Roosevelt
  4. #4 Re: Loud ass noise - not sure where to start
    Santa Fe, NM
    Yeah, sorry 242 t-case. I considered that as well, but haven't really heard it failing on anyone. I guess if that is the case, for not it doesn't bother me as long as I still have 4 part time.
  5. #5 Re: Loud ass noise - not sure where to start
    Mar 2007
    If it is the chain, it probably should bother you. The last thing you want is that chain busting on the trail, or even on the street for that matter. It'll leave you stranded.
  6. #6 Re: Loud ass noise - not sure where to start
    Santa Fe, NM
    Quote Originally Posted by JordanA View Post
    Huh?
    It is certainly a loud popping. It's odd to me that it only occurs in 4wd full-time though. For the time being I am going to stay out of full-time. I won't have the chance to investigate it for another week and a half and really don't have the resources to mess with it until then either. I'm assuming I can determine if the chain has too much play just from investigation via the fill or drain hole? How much slack should the chain have...if any?
  7. #7 Re: Loud ass noise - not sure where to start
    Oct 2008
    in my 242 it would click a little then try to engadge low range at 40, low range shift for was screwed
  8. #8 Re: Loud ass noise - not sure where to start
    Santa Fe, NM
    Well.....I thought it was only in full-time but on my way back from campus a few minutes ago it did it in part-time as well. I don't really have the resources to diagnose it right now....tools are 500 miles away at home and I don't much care for working in 20 degree weather on snow covered crushed gravel. I'm hoping/praying I can make it 2 weeks until I get home. I'm trying to run it in 2wd as much as possible, but with the weather as shitty as it has been that's a difficult task in itself.
  9. #9 Re: Loud ass noise - not sure where to start
    Oct 2008
    not to hijack but if you ever come to my side of the state let me know
  10. #10 Re: Loud ass noise - not sure where to start
    Santa Fe, NM
    Sure thing.
    Anyone know if you can check the chain w/out cracking the case?
  11. #11 Re: Loud ass noise - not sure where to start
    Houston, TX
    you can unbolt the front DS and twist the tcase yoke. if there is a shit ton of twist slop then the chain has stretched and could lead to failure or worse like a split case that everything falls out of it.... could also be the planetary has cracked and the little gears are moving around in ways that they should not.....
  12. #12 Re: Loud ass noise - not sure where to start
    Santa Fe, NM
    Well.....thanks for the info guys. For the time being I don't think I'm going to mess with it. I wish I could but I just don't have the time and resources. I'll report back when I pull the case apart in a couple weeks.
  13. #13 Re: Loud ass noise - not sure where to start
    Oct 2008
    good luck hope its not a cluster fuck like mine
  14. #14 Re: Loud ass noise - not sure where to start
    Jun 2008
    Lakeview MI 48850
    give me a call when you get it home if you want some help or anything. I got a shop we can heat up if need be.
