Allright cool, just makin sure
You asked for it dude
In fact, you ask for it pretty much every time you post. It's just a little more subliminal usually.
Start with this:
1) At the start of what you say, turn the letter from lower case to upper case. For example: the letter "b" would then become "B"
2) When your mind completes a sentence, or a thought, place a period. For example: "I (Note the capital letter) would like a cheeseburger." (That's where the period goes.)
So, to recap, instead of writing: "i upgraded my axles from the stock crap to the new cool heavy duty axles i went did not go to school today the weather outside is crappy"
You would write: "I upgraded my axles from the stock crap to new heavy duty axles. (Note the end of a thought) I did not go to school today. (Woah, another new thought coming up, watch those capital letters!) The weather outside is crappy."
It doesn't take much, but those two rules should help the rest of us keep our sanity.
[/grammar lesson 1]
Are you keeping the stock gears/ lockers? Are you also going to redo the links on the suspension? Even if you cant afford an LA kit, all you have to do is copy a manufacturers LA's, you obviously have the welding skill to build one. Also, I don't know if your jeep already has one, but I'd add a subframe to it.
They have 4:10 gears and im planing on running 35s. Also i have 2 sets of 4:56 gears for the 44 and a lockright. I havent decided wich gears i will run. I have already put stiffners on the unibody and my 3 link works very well i have done some more research on it and its definatley a better choice than the radius arm.
What wheels/tires will you be running?
Omfg, Its like a blessing from heaven when he uses punctuation.
I have one question. You drive this thing on the street everyday, with your three link, Why are you running no sway bars front and rear? I run no rear, but with my front disconnected its down right scary driving.
Here is some info I think you need.
http://www.therangerstation.com/Maga...ech%20Part%201
