Thread: after market fog lights on factory wiring harness
Results 1 to 12 of 12
  1. #1 after market fog lights on factory wiring harness
    Aug 2006
    Grover Beach
    My fog lights on my 95 zj are junk. They work but both lenses are missing. Can a hella 450 or equivelent light be connected to the factory fog light switch?. Does anyone have a wiring diagram?
  2. #2 Re: after market fog lights on factory wiring harness
    Member Zombie's Avatar
    Salt Lake City
    I put some el cheapo autozone fogs on mine. I used the OEM wires, but be aware, the OEM setup is an isolated circuit, meaning if the housing of the light grounds, it will blow fuses. I used a peaive of 1/2" thick delrin(sp?) to mount to metal, and then mount the light to the delrin That might not work for a larger Hella 450, but you will need to isolate the light, or use the factory wires as a trigger for the hella relay.
    "Dood, you were a vampire driving a K5 Blazer. And that's the LEAST weird part of the entire story."
    -J B
  3. #3 Re: after market fog lights on factory wiring harness
    Speaking of those fuses... I was taking out a blown bulb on my factory fog, and I shorted it and heard a pop under the hood and the other one wont light now... I didnt even care to look at what fuse blew... ( I don't use the fogs all that much) but just wondering which fuse (Id assume its a bigger sized one) and how much does one of those puppies cost? where are they available? or is it just a standard type fuse?
    Neil R.
    Funniest thread on MC
  4. #4 Re: after market fog lights on factory wiring harness
    Aug 2008
    Quote Originally Posted by Zombie View Post
    That's what I did to mine 6 years ago. I have never had a problem.
    '95 Grand
    '01 Jetta- dead for now
  5. #5 Re: after market fog lights on factory wiring harness
    Salt Lake City
    Mine was a small fuze, and I went thru a handfull of them before I figured out the isolated circuit.
    -J B
  6. #6 Re: after market fog lights on factory wiring harness
    I used the Piaa harness and connected the accessory lead on the piaa switch to the factory plug and grabbed the wire that was hot when the OEM FOG switch was engaged. You can grab it from behind the dash or straight from the plug.
    But on my XJ I did it straight to the factory plug and it worked for years till I killed the jeep.
    Will
  7. #7 Re: after market fog lights on factory wiring harness
    Nov 2010
    hanover, pa
    got a 94 zj no factory fog lights went and got a head light switch with fog option from local JY and i cant find no wires behind bumper so what pin on the switch can i run to hook my hellas on this switch (thinking i got no wires from relay box to bumper that i got no wires from dash to relay
  8. #8 Re: after market fog lights on factory wiring harness
    Houston, TX
    Thanks for bumping an old ass thread for bad English.
    Plug in the JY switch and the harness plug is under the battery or under the passenger side headlight (around in there somewhere already). go back to the JY and get the rest of the wiring harness that plugs into the EXISTING harness that is already there. (I did just this)
  9. #9 Re: after market fog lights on factory wiring harness
    MallCrawlin Supporter
    Kauzi Zj's Avatar
    Apr 2009
    Quote Originally Posted by reinaldo View Post
    I hope there will be a diagram so that I will be able to follow the steps.
    WOW!!!!! Really?
  10. #10 Re: after market fog lights on factory wiring harness
    Dec 2011
    Kirkland, WA
    Bringing a topic back from the dead...
    I replaced my stock fog lights with HID fog lights on the stock wiring. I tested one first and it worked fine then I hooked the second one up and it blew the fuse. I heard a relay may solve my problem but I dont know how and where to install one. How do I fix this?
  11. #11 Re: after market fog lights on factory wiring harness
    Sep 2014
    Huntington Beach
    Quote Originally Posted by boosted1800cc View Post
    Do you or anyone have a diagram for this? Semi retarded when it comes to electrical
  12. #12 Re: after market fog lights on factory wiring harness
    Member pitbull78133's Avatar
    Dec 2012
    San Marcos, TX
    Quote Originally Posted by WillBeck View Post
    I have a FSM for a 93, but the wiring changed in 96 I believe. I am running 4 Hella's off the factory fog light wiring on a 97 with no problems.
    93 ZJ 3.5" RE Superflex kit, KOR Stealth Rear bumper with carrier, Nates 4x4 Front Stinger bumper, Surco Safari Rack, HP D30 , Ford 8.8 Locked, Trimmed out on both ends with 33" Toyo Open Country M/T's
