Project Fuzzy - Page 3
Thread: Project Fuzzy
Page 3 of 10 FirstFirst 12345678910 LastLast
Results 51 to 75 of 246
  1. #51 Re: Project Fuzzy
    Aug 2008
    Virginia
    Here's some of the beginning of the install of the clayton that came in. And here's a bunch of the Clayton's packages hanging out.
    And of course Pat's TJ
    Time to make room for the passenger side unibody stiffiners and control arm brackets.
    And Fuzzy going under the knife!
    And Master Chief doing his own
    Dropping the lp30
    Mmm...Clayton's arms
    And some ACOS action
    Mounting the front Bilsteins on the JKS Shock Conversions
    New completely polished turdy
    ACOS is sitting a little further than we would like so we are going to push the axle forward some.
    Trimming the track bar
    And the wantans
    And now the fun part
    Here's the sound of the stock exhaust on the 5.9
    http://s303.photobucket.com/albums/n...t=MVI_0571.flv
    And a 5.9 cut off after the y pipe
    http://s303.photobucket.com/albums/n...t=MVI_0575.flv
    More to come soon
  2. #52 Re: Project Fuzzy
    $2 your neighbors hated you already anyway
  3. #53 Re: Project Fuzzy
    Aug 2008
    Virginia
    Lol, good point. I'm sure with all the work that has been done in Maxx's driveway the entire neighborhood hates him
  4. #54 Re: Project Fuzzy
    Aug 2008
    Virginia
    And some more progress of the front end and rear
    So let's start doing some more work on the front end, bolting in all the coils, tightening up some bolts, etc etc.
    So here's the Josh under the jeep with me trying to get this FREAKING pitman arm out. I can't describe the frustration of getting this thing out. We busted some tools and knuckles getting it out. Ending up taking a cutting disc and a sawzaw to it in the end. Thanks again to Preppi and Shadow for reaming out the Clayton's pitman arm for me
    And here's that POS that finally broke off
    Master chief helping out with the front end
    Close up of the LA's
    Secksay
    Haha, front end vs. rear end
    Front stance on 31's!
    The beast coming to embarrass me
    And a few of shots of Maxxs on 40's next to mine on 31's on the front, my rear is sitting low still since we haven't swapped the 44hd out for the 8.8
    Rear puny
    Another front shot of the 5.9
    And the front appears to be sitting slightly higher
    And of course Pat's and Maxxs
    And here is the 5.9 minus the exhaust backing out of the driveway to back back in
    http://s303.photobucket.com/albums/n...t=MVI_0608.flv
    Lots of more work to come
  5. #55 Re: Project Fuzzy
    Aug 2008
    Virginia
    Got some work done on the jeep last weekend. Time to work that rear end so let's get to it.
    Pulling rear 44hd out
    Goodbye rear!
    Hello 8.8
    Going to need to get some uber epoxy for the rear acos. For now we just threw on 2 inch pucks to make it sit level. Coils bow pretty bad, might need to relocate the upper mount...
    Front axle needs to shift to passenger side still
    Tall bitchhh! Almost with Maxx's 40's
    Rear is 9 1/2 inches from tire to fender...Maxx' is 7 1/2 for perspective.
    Close to Maxx's!
    Right now I sit about 3 inches shorter than Maxx's...when the new iroks get on, I'll be about 2 inches shorter than him. Bitchhh is tall! Putting on shocks, doing brakelines, tightening bolts, installing rear acos...and thats about it!
  6. #56 Re: Project Fuzzy
    Aug 2008
    Virginia
    So got some work done on the transfer case. Finally got it to fit in snug but of course we ran into other problems. Lets take a look
    Undercarriage shot before we go in
    Start taking that pos 249 down
    Repainted up the Clayton crossmember
    Driveshafts and 249
    Jack helping support the pulling
    And yank, it is out!
    And the new 231 with the sye
    Close up of the SYE
    SYE + the 231 again
    Moving it under the heep
    And trying to bolt it in...
    But not quite all the way, the input shafts were different so we pulled the 249 apart and swapped the shafts. And it's in!
    And another undershot of the trussed rear 8.8
    The hp 30 lookin' fine
    Ran into a little snag...the Tom Wood's drive shafts don't fit snug so I'm going to need to have a shop lengthen and shorten them. Blast
    POS 249 and the infamous VC
    Rear stance
    Front stance
    Another shot of the front ACOS
    And Maxx got his cutting done, opens the front up nicely and Josh messed around with his rear control arms. All of the projects are moving along nicely though.
  7. #57 Re: Project Fuzzy
    Aug 2008
    Virginia
    Some more goodies came in the other day.
    FINALLY that darn tracbar jamnut came in from TNT customs
    And of course the new rubbers came in. Can't wait to see them mounted on Trail Ready beadlocks, definitely on the to do list asap.
    Keep you updated as the rest of it comes in.
  8. #58 Re: Project Fuzzy
    Quote Originally Posted by fuzzy59 View Post
    Did you order the shaft directly from Tom Woods? Did you make your measurements properly?
    When my shaft came it was too short. The measurements we gave them were verified and it ended up that Tom Woods sent the wrong length. They immediately sent us a new shaft at no cost -- and even offered to overnight it since it was a time crunch to get my Jeep ready for an event. Tom Woods has awesome customer service. If you are sure your measurements are correct and you bought this shaft new, I would call them first before spending money locally to get it fixed.
  9. #59 Re: Project Fuzzy
    Aug 2008
    Virginia
    I bought the drive shafts directly from Maxx. Because my 9er transmission is different than his the driveshafts were the wrong length, no biggie. I already got them shorted and lengthened respectively and they bolted right up I have heard that TW has great CS though, they make some beef products too.
  10. #60 Re: Project Fuzzy
    Mar 2007
    Waynesboro, VA
    tom woods does have great service but the tom woods shafts that fuzzy got where the old ones from under maxx's zj before he put the tons under it. Im guessing that the block is longer in Fuzzys so he had to shorten the rear and lengthen the front??????????
  11. #61 Re: Project Fuzzy
    Aug 2008
    Virginia
    We had to shorten the front shaft and lengthen the rear. Fits snug now
  12. #62 Re: Project Fuzzy
    Mar 2007
    Waynesboro, VA
    why do you think that is though if you swapped in all of the same components. doesnt make cents(sense so i dont have to point out the sarcasm later) to me
  13. #63 Re: Project Fuzzy
    Staunton, VA
    The transmissions are different
    Blocks are the same just different bore and stroke
    I think he said that earlier, if not, I dont give a damn, if he did, I still dont give a damn
  14. #64 Re: Project Fuzzy
    Aug 2008
    Virginia
    Getting some work on the 5.9 in an attempt to see it move! Let's dive in shall we.
    The beast next to the 5.9
    And the beast
    Pat's TJ is making good progress too
    So time to install the Kevins Offroad Steering brace. Pretty simple install, used the old screws from my swaybar that is now gone to screw it in.
    Line KOR brace up on the bolts and around Clayton's pitman arm and away we go! Along with some after shots.
    Driveshafts are in now, tightened the steering down, gave it an "eye" alignment, etc etc. And we are set to move!
    Gasing up for the first time in a while. Was running on fumes on the way there. Not bad considering gas was like $4 last time I filled up
    Broski shot
    Made my way over to my friend JT's house to do a little surgery.
    Smiley plasma cutter/welder
    More knife time. We cut the old control arm brackets off and checked out the 231 transfer case linkage problem. Diagnosed it with a shot rubber snap on so I'll be heading to the stealership to pick up a new one this week. And cut!
    Now its time to take off Kevins rock rails so I can build my own here shortly.
    And cutting the old brackets off the KOR rails
    So we got the jeep moving but it still needs a lot of work. I'll get some more pictures of the finished product today/tomorrow when there is more light out
  15. #65 Re: Project Fuzzy
    Staunton, VA
    What you doing with those rock rails?
    looks good, white jeeps always look better than red jeeps agree? hahahahaha
  16. #66 Re: Project Fuzzy
    Aug 2008
    Virginia
    Quote Originally Posted by 1fox2go View Post
    Those rock rails are going on my brothers jeep. When he gets back from military school this thanksgiving they are getting welded up on his jeep. Need to make some new bracketry for them obviously since we cut all of the existing stuff off.
    I couldn't agree more
    How you been man, haven't heard from you in a while. Making your way towards Richmond anytime soon?
  17. #67 Re: Project Fuzzy
    Staunton, VA
    Not that I know of. Only have the xj to drive now unless I go to blue ridge, dads driving the grand so he can show people interested in it
  18. #68 Re: Project Fuzzy
    Aug 2008
    Virginia
    Is that a bad thing? I like the xj.
  19. #69 Re: Project Fuzzy
    Staunton, VA
    yea it gets 12 miles per gallon, and i have a perfectly good car that i cant drive because the previous owner is a complete dumbass
  20. #70 Re: Project Fuzzy
    Aug 2008
    Virginia
    No title? Insurance problems? I remember Berk had said you got a new dd car.
  21. #71 Re: Project Fuzzy
    Staunton, VA
    Swapped vins, was quite pissed when I found out and now its a matter of legal bullshit and paper pushing with the state, who takes forever, to get it straightened out. Even then the original owner must sign a form saying they are not interested in the car, which is also bullshit, and the cake topper is the original owner is in a state prison somewhere in southern va, fan fucking tastic
    Hopefully they sign it, if not im fucked
  22. #72 Re: Project Fuzzy
    Aug 2008
    Virginia
    Wow, what in the ghey.
  23. #73 Re: Project Fuzzy
    Midlothian Virginia
    installed one beadlock, onto the next 3!
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  24. #74 Re: Project Fuzzy
    Aug 2008
    Virginia
    Ordered an Aero 3030 exhaust from CrawlerReady. Got a great deal on it not to mention shipped quickly from Tyler, great customer service
    Ordered a universal magnaflow catalytic converter from Summit Racing as well to go along with the new exhaust setup.
    And got my transfer case linkage grommet in so I'll be snapping that new one on this week.
  25. #75 Re: Project Fuzzy
    Jan 2008
    Marengo, Illinois, United States
    Hey if i where I would take the cat back and get one from this guy I ordered from shipped to my door for $50 a little bit ago.
    1998 ZJ Jeep Grand Cherokee Limited I6
    Lifted 6", Goodyear MTR's 33", Winch, Bumpers, Sliderz,Long Arm, 4.10, Locked, and Loaded. (the last bit is a pun)
    2000 Mustang and a 2006 Kawasaki Ninja 636
