Project Fuzzy - Page 10
Thread: Project Fuzzy
Page 10 of 10 FirstFirst 12345678910
Results 226 to 246 of 246
  1. #226 Re: Project Fuzzy
    Dec 2010
    kansas city
    looks awesome man. rewiring all my lights is next on my list. not looking forward to it lol
  2. #227 Re: Project Fuzzy
    Aug 2008
    Virginia
    Yes, in hindsight if I had known what I know now the shat wiring would never have happened. Running thicker witter is the lesson I learned. The 8-10g is over kill but I'll never have to worry about the lights again.
  3. #228 Re: Project Fuzzy
    Aug 2008
    Virginia
    Got some more work done last week. Ordered new rear shock brackets, real axle seals, lock rings, and bearings. Continuous work on auxiliary and audio. Lost the charge on the dd so I replaced the alternater as well.
    Alternater was on its last breath so I picked up a used one with half my jeeps miles. Install was pretty easy.
    Unbolt 3 bolts and loosen the tension rod to pull out the original.
    Out with the old, in with the new used.
    Swap and rebolt, new one is 10 times quieter and working like a charm. Plus free battery swap!
    Now back to the 5.9. Opened the Hellas 500 up and ran 10g to them.
    Self grounded them to their own connecting bolt and daisy chained them off each other from the new home run.
    Bye bye stock
    Ordering the wiring harness today to connect the dvd/nav unit.
    Dremel handiwork to fit the new unit.
    Got a really good deal on an video/audio so I'm putting that in as well. Back to the grind!
  4. #229 Re: Project Fuzzy
    Feb 2011
    New Hampshire
    Congrats on the "milestone" with the WJ. I'm on 238K with my 97 4.0 and stock tranny. Still truckin along. As for the wiring, do it nice, not 2wice. Good call on the guage wiring. I ran 10 also on my hellas. Worked out fine. Then again I have no where near all the accesories your packin in your ride. Love all the updates.
    Brian
    1aauto.com
    866-433-3393
    Jeep Repair Parts
  5. #230 Re: Project Fuzzy
    Aug 2008
    Virginia
    Took this weekend to finish up the rear and get the jeep moving. Here's a bunch of the progress. New bearings, seals, and lock ring for the super 8 came in late last week. Had to press the new stuff on with a 20 ton press and 3/4" plate. 1st attempt left the press hissing and bent plates. 2nd attempt with a plate twice as thick. Success on both sides. And a walkthrough of installing the shafts. Exposing where the shafts insert. Removing the old race. Calipers, back plate and rotor removed. Plenty of rtv. And reverse the process. Doneskis. Cleaned up the 8.8 diff, no shavings or chunks. More rtv as always. Bolt up the RockCrusher cover. Rear all cleaned up, void of all leaks. Amazing! Running more 10 gauge home runs for the lights and grounding at the source. Wired in the front IPF's and Hellas 500's. Installed 2 more Hellas on the rear rack and put the original yellow lights from the front bumper inside the Trailready rear bumper. You can see a glimpse of the yellows. Great success overall, moved the jeep about 55 highway miles no problem. The rear calipers feel tight so pulling some from the junkyard today and I'm thinking about adding the front swaybar back since I have extended jks quick disconnects and brackets for it. I'll post pictures of the jeep tomorrow with the day light. Audio/visual here I come!
  6. #231 Re: Project Fuzzy
    Aug 2008
    Virginia
    Went to the junkyard to grab a few goodies for the 9er yesterday.
    Scores a v8 swaybar to help reduce some of the boat effect.
    And some new calipers as well.
    Still looking for a ZJ 231 shifter bezel but in due time.
  7. #232 Re: Project Fuzzy
    Jan 2009
    Tempe, AZ
    are the front sway bars for V8's different than the V6's?? I assume the V6 version is softer right?
    Thanks,
    G-
  8. #233 Re: Project Fuzzy
    Santa Fe, NM
    Thanks,
    G-
    What is this elusive v6 you speak of?
  9. #234 Re: Project Fuzzy
    Aug 2008
    Virginia
    Thanks,
    G-
    A lot of times components from a V8 can be beefier than that of a straight 6. The 5.2 and 5.9 are V8's and the 4.0L are the straight I6.
    Lol's
  10. #235 Re: Project Fuzzy
    Quote Originally Posted by fuzzy59 View Post
    Sway bars are the same.
  11. #236 Re: Project Fuzzy
    Jan 2009
    Tempe, AZ
    sorry... inline6 is what i meant. so they are all the same?
  12. #237 Re: Project Fuzzy
    Santa Fe, NM
    Just giving you shit. AFAIK, like Dave said, the sway bars are the same.
  13. #238 Re: Project Fuzzy
    Sep 2010
    Turkey
    friend,
    could you send detailed rear bumper's pictures ?
    i am going to make rear bumper this month
  14. #239 Re: Project Fuzzy
    Jan 2009
    Tempe, AZ
    I figured as much.. plus, im sure i probably would have heard of it before. It would be nice to get a softer rate one on my rig.. I've been 'rolling' with nothing for the last few months! haha.
  15. #240 Re: Project Fuzzy
    Aug 2008
    Virginia
    Took some shots today in the sun. Hopefully some more progress gets done this weekend. Looking to replace the rear calipers, add the front swaybar mounts, and continue more work on the audio.
  16. #241 Re: Project Fuzzy
    Aug 2008
    Virginia
    New goodies arrived for the 9er. Ordered a dual battery kit from Painless Wiring and grabbed 2 Hellas 500 stone shields for the front bumper. Hopefully get a chance this weekend to install it.
  17. #242 Re: Project Fuzzy
    Aug 2008
    Virginia
    A long Thanksgiving weekend allowed for some more work to be done. Rear calipers felt like they were freezing up a little so we started with them. And opening up. Out with old, in with the used new. Reassembling the brakes The e brake butterfly was acting up a little so we grooved the shoes and it fixed that problem. Final shot of driver and passenger. To add some more "on street drivability" I picked up a swaybar from the junk yard. Here's the beginning of the install. Penetrating fluid to help break the KOR steering brace free. We undid the bolts on both sides and planned on mounting below the brace. Loosening the bolts around the pitman arm. Swaybar and JKS quick disconnects in both side with the brace mounted on top, no new holes needed surprisingly. Passenger side fits perfectly. Driver side however mounted on driver runs directly through the tie rod, and passenger side it his the trac bar mount. So I'm not completely sure yet where I can weld the mount. Took the new Hellas stone shields and mounted them up. I'm thinking I'm going to have to weld a block on the tire side on top of the original swaybar mount and then weld the new one on top of that so that it clears the coil and steering.
  18. #243 Re: Project Fuzzy
    Midlothian Virginia
    Get rid of sway bars. End of problem
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  19. #244 Re: Project Fuzzy
    Aug 2008
    Virginia
    Driving back from work in the WJ and I heard a pop and lost my power steering on the highway. After fighting with the steering wheel I pulled in front of my house and my timing belt had shredded and water pump imploded. Took the weekend for the quick fix.
    A shot of the bent water pump.
    And yanked the pump.
    Out with the old and in with the new.
    Cleaning and prep work.
    Reinstalled and belt ran.
    Water pump installed and working like a charm. Pretty easy install, removed shredded belt, unbolted water pump, clean/prep, rebolt. WJ is running like a charm. ZJ update coming tomorrow.
  20. #245 Re: Project Fuzzy
    Santa Fe, NM
    Timing belt? What timing belt?
  21. #246 Re: Project Fuzzy
    Apr 2006
    Canada, somewhere
    Where we're going we don't need timing belts...
