Just got my adjustable track bar from Kevin (via Kolak, part of F>R swap kit he cobbled together). Can we say Beef!?!?!? Install was a 1 wrench. A trick I read somewhere was to take to lower bolt out, then top nut off, the use the bar for leverage to yank the top joint out, no pickle fork needed. 4 good yanks and it was out. Here is a pic: Also the top joint was shot. Rides much better (doesnt wander and no clicking).
The rear is going on this weekend.
And you won't have to worry about replacing tie rod ends after every trail.
I sure hated that damn t55.
When i installed the trilink in my rear I was going to remove the t-55 but after seeing that is was going to be a big PITA i decided to take a cut off wheel and remove it.
Sheesh you guys take all the fun out of this.Have fun with the T-55's on the rear. I suggest you start soaking them in PB Blaster like yesterday.
Thansk for the suggestion, forgot about them.
Does Kevin actually label that his own trackbar? Looks a hell of a lot like the JKS rear one I have and the front looks like JKS too.
http://store.jksmfg.com/merchant2/me...bar_Components
Edit: Nevermind I just checked his site and he states they are JKS.
its all the same thing. The only difference is the one kevin makes for the front has a bracket that the make special for him.
That t55 is a *****. A cutoff wheel and whole lotta PB does the trick!
to sum things up ya don't even waste your time with that T55 on the rear track bar just cut it off and buy a new grade8 bolt with a real head on it.
I used a M12x1.75 on a dirty rotten TJ that fawked with me for a weekend and I was about to burn the fucker down.
Yeah, M12x1.75
I just checked, it look like the nuts are not welded on mine. Still trying to figure out how to get around stuff simply to cut the bolt without disassembling the entire rear end. Or wait till I get the F.R kit in and take everything apart anyway. The UCA is over the end of the track bolt, cant get a socket on it without removing the UCA bolt and swing the UCA out of the way.
Pull the UCA John - as long as you only pull 1 at a time, the pinion angle won't get away from you.
Too easy
