how did i miss this. that is an amazing build!
Thanks bud!
I'm trying to find a reasonably priced set of LS2 manifolds like these, hopefully they will work. Baring that there are a few sets of CARB certified shorty headers I have found that I can cut and modify if I need; like to change the angle of the outlet flange but I'm still hoping for a cheaper solution. Other than that I think I have solved all other major problems, now it's just all the little stuff like plumbing trans cooling lines, power steering lines, coolant, etc...
Alright I'm continuing to plug along while I search for a reasonably priced set of LS2 manifolds. I got a ton of wiring done going to the interior for the remote start, gauge cluster lights (check engine & cruise control) and OBDII. I also mounted the drive by wire pedal and got the brake pedal back in.
Now this next part is in no way hardcore but I figured I'd put it up here anyway. The leather on the steering wheel has been cracked and flaking shit since I bought the rig. I looked into having it rewrapped but long story short did it myself.
Before:
After:
For those interested in how I did it (I'm sure I'm not the only one with a shitty ZJ steering wheel) I did a write up here.
Alright flame on
Great work! My wheel is starting to peel as well (not nearly as bad as yours was) and I've been wanting to do something about it. Now I know what to do. Thanks a ton for that writeup
Man, I give you props for the dedication to stitch all that!
looks great
Thanks a lot guys
ehhhh, it looks like shit
just kidding man, looks great!
Props to you for having that much patience. I just dont think I could do it.
dude, i'm blown away by how well that came out. I've hand-sewn two covers and neither looked that good. How'd you keep the stitching so tight? Did you buy a special kind of leather? UV treated or anything?
To get the leather so tight I cut it a little smaller and just stretched it using the stitching. I'm not sure if the leather is UV treated. The guy I bought it from does it for a living, he has a motorcycle almost completely skinned in leather that looks bad ass. This is what he recommended. I do know it was on the thinner more flexible side as far as leather goes that helped a ton. Honestly I've never worked with leather before in my life.
Nice job on the wheel! I may have to use that as motivation to one day recover my Dodge steering wheel.
You made it look easy. How did you stitch the three pieces together? Sewing machine or by hand?
Got the SwayLoc installed today, pretty happy with how it's turning out. I used a SwayLoc intended for a TJ because from my understanding they have the longest arms. I want long arms so that at full droop I don't accidentally invert the sway bar (I've done it before)
This part was very much inspired by GoldenSD's SwayLoc install, so credit where credit is due. Here is the combination sway bar bracket and radiator support. Amazingly this thing only weights 5 lbs more than the original radiator support and it is way beefier.
Here is the driver side at ride height, I love how the flash brings out every damn spot of rust, I can't wait to paint & powder coat this stuff.
And the passenger side.
Here is full bump, it touches the coil over hoop barely, so I'll do a little clearancing tomorrow.
And here is full droop, you can see why I wanted the longer arms with these 14" coil overs. Even here I'm a little nervous about the angle between the arm and connecting rod, I might make my own custom length ones.
Do you think it would help any to throw a gusset between those two plates on the trackbar mount? I'm sure you worked calculations and stuff, but it just looks like it could be a little stronger to me. I may be wrong, but that's just my observation.
Love the build, can't wait to see it moving!
Found some Corvette headers finally, they are on the way!
Measured for the limit straps and picked some up. It is handy having Poly Performance two miles away.
This contraption is going where I had intended to put the second battery, looks like it will be going in the back instead. This is a rack that holds the compressors for the lockers on the bottom, the Chevy ECU in the middle and will hold the fuse & relay panel & iPhone controller on top. That cluster of connectors on the right will all be coming out of the fuse box (totaling 56 wires) , it's a lot to keep track of haha.
Sweet build! I'll start a build thread when my 5.3l starts going into my WJ.
I continue to make progress but most of it isn’t photo worthy. I’m still waiting for the headers to get here.
I’ve wanted to have HID fog lights for a long time but they are EXPENSIVE, so I pieced my own together. I have about $125 into each, which is a lot cheaper than most setups.
I used 55W 5000K HID bulbs and Hella 4000 housings. The Hellas come with H1 bulbs so I just order the HID setup with the same.
I had to do a little modification to get them in there but nothing major. I used a stepper bit to drill a hole in the back of the housing and the stand large enough to fit the bulb connectors through.
I used a grommet on the back to protect the wires and keep stuff out.
I don’t have a real world shot yet because they aren’t on the Jeep but here is a garage door shot. I am VERY happy with how bright these puppies are and the quality of light.
Dang man this stuff is way cool, Is your last name mcgiever?
Cool idea on the hid upgrade. Added to must do to Jeep list. Thanks alot...LOL
Hey, I showed it can be done on a budget!
Got the HIDs from http://www.ddmtuning.com for ~40 shipped (I remember when these things cost like $400). Got the Hella 4000s from http://www.adv4x4.com/hera40coblla.html for ~210 shipped.
Tags for this Thread |
