The Polar Bear - NP241 Upgrade - Page 5
Thread: The Polar Bear - NP241 Upgrade
Page 5 of 30 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 737
  1. #101 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    I collect Jeeps.
    The Polar Bear Detailed Build
  2. #102 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Got the track bar done today. Here are models of the frame side and axle side brackets.
    Here is the finished frame side mount.
    At ride height.
    Full bump.
    Side view, it clears the diff by .75"
    I collect Jeeps.
  3. #103 Re: The Polar Bear - 5.3L Chevy Install Begins
    2nd floor Yuma, AZ motel
    Looks really good! Do you think you'll need to gusset the front and rear of the TB mount? It looks kinda like the old RK brackets.
  4. #104 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Quote Originally Posted by Elliott View Post
    Thank you!
    I'm not sure, its 1/4" thick and I've got pretty good penetration on those welds. I'm having the motor mounts, track bar and frame side bracket powder coated so I have until then to make modifications.
    I collect Jeeps.
  5. #105 Re: The Polar Bear - 5.3L Chevy Install Begins
    Senior Member faststang1's Avatar
    Sep 2007
    Palm Spring's CA
    The Mounts looks really good!!!
    96 ZJ Limited, 5.2 with K&N filter, Hi flow cat, Cherry bomb extreme muffler, Clayton long arms 6" lift, Steering box brace from KOR, KOR track bar Conversion,TnT steering, 242 TC, 8.8 with ARB Locker, dana 30, 4.88 gearing, 35 KM2's
    KOR bumpers
    http://www.mallcrawlin.com/forum/showthread.php?t=17149
    07 CRF250X
  6. #106 Re: The Polar Bear - 5.3L Chevy Install Begins
    I think it would be a good idea to plate in atleast one of the sides of that bracket so it cant bend to one side or another. I know it shouldnt, but you cant be too careful
  7. #107 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    True, I'll probably weld in a cross support on the inboard/engine side.
    Todays project: pull everything back out and weld up all the small shit so I can sand blast the engine compartment tomorrow.
    I collect Jeeps.
  8. #108 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Working on the air bump mounts. Between the plated frame rails and large surface are, hopefully it doesn't fold the rails in.
    I collect Jeeps.
  9. #109 Re: The Polar Bear - 5.3L Chevy Install Begins
    Cool, looks like they will be better supported than mine were. And you will be glad you plated the frame there. Mine wasn't plated and I ended up folding in the unibody on a couple hard hits.
    what are you doing for bump pads?
  10. #110 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Hearing about your folded rails influenced the design haha. For the time being I'm going to just put a 2" tube in the clamps with the stock rubber stops on the end. In the future I'm going to order some 2" air bumps from F O A. They will contact tabs that I'm going to weld on to the long arms.
    I collect Jeeps.
  11. #111 Re: The Polar Bear - 5.3L Chevy Install Begins
    nice work.
    I'd box in that panhard mount, or run braces to the frame rails. Looks like it could buckle with a severe hit. Overengineering? what's that
    are you running FEM on this stuff?
  12. #112 Re: The Polar Bear - 5.3L Chevy Install Begins
    Sep 2007
    Palm Spring's CA
    nice work.
    X2!!!!
    KOR bumpers
    07 CRF250X
  13. #113 Re: The Polar Bear - 5.3L Chevy Install Begins
    Midlothian Virginia
    I have never opened this thread and I am glad that I did today. The work in this thread is awesome! What program are you using btw?
    The problem with me making brackets is I have a hard time gettting my drilled holes to line up, ha!
    Looks good man, keep this shit coming.
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  14. #114 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Thank you! I'm using SolidWorks. What I have found works for getting holes to line up is to clamp the two pieces together and drill them in the press at once so that even if they aren't perfectly aligned with the template I made, they are at least both off by the same amount.
    nice work.
    It has been boxed in haha, I'll try to post some pictures of it.
    Like I said, I'm using SolidWorks which has COSMOS FEA package built in but after using it I can say that it is a piece of shit, but it's good at making pretty pictures .
    I collect Jeeps.
  15. #115 Re: The Polar Bear - 5.3L Chevy Install Begins
    Member RCB-ZJ's Avatar
    Jul 2008
    Tualatin, Eugene Or
    You can always tack weld the two pieces together also. Thats what I do. A couple quick tacks, Drill, Grind tack off and wa la
    Clamping works also but can move on you sometime
    BTW man killer work. Keep it up
    95 ZJ limited up country 4in lift and 33in BFG 4:10 gears and a posi out back
    63 Willys pick up 4-link front and rear work in progress
    77 Chevy short bed 9in lift 38in toyo m/t with a alum head 427 small block
    84 CJ10a - Project Real BRUTE
  16. #116 Re: The Polar Bear - 5.3L Chevy Install Begins
    Midlothian Virginia
    I would love to know how that SolidWorks program works. Those designs are pretty cool. Care to share how you go about designing something like that track bar mount?
  17. #117 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Since I've got a little time before class, here is how I have gone about making all of my brackets with nothing but a grinder, spray paint and sheets of sticker paper. I use SolidWorks for my modeling because I get it for free through Cal Poly but if I didn't have that luxury I would use Alibre
    1. I start by measuring the dimensions that I need from the frame. For example on the track bar bracket, I measured the distances between all of the bolting holes and how far they were from the bottom on the frame. I used this information to dimension them in SolidWorks.
    2. Next I used the extrude function in SolidWorks to turn them into 3D, since I used 1/4" steel to make the track bar bracket, I made the model 1/4" too.
    3. After turning all of the 2D plates into 3D parts, I combined them all in an assembly. Here I can see how it is all going to fit together and where I need to make changes.
    4. I then take the plates and turn them into drawings. All of these drawings are printed out and stuck to cardboard. I take the cardboard model and use it to make adjustments to the parts to ensure the bracket will come out as I need it.
    5. Once I'm satisfied with the drwaings, I print them out 1:1 on large sheets of sticker paper. These I cut out and stick to the metal that has been cleaned with brake cleaner or lacquer thinner. Below is a photo from my construction of motor mounts.
    6. I then spray around the edges with spray paint in case the sticker comes off I still have a line to follow.
    7. Once all of the brackets are cut out using the grinder, I take the pairs that are supposed to match and clamp them to the drill press and drill the hole. I then use the hole and a matching size bolt to clamp the two pieces together and put them in the vice. Then I use a flap disc on the grinder to give the two pieces the same profile.
    8. And I am left with professional looking pieces that I can use to construct my brackets.
    I collect Jeeps.
  18. #118 Re: The Polar Bear - 5.3L Chevy Install Begins
    Senior Member dp96zj's Avatar
    Texas
    All that with a grinder??? Wow it looks great, I was thinking it was with a plasma.
  19. #119 Re: The Polar Bear - 5.3L Chevy Install Begins
    Houston, TX
    nice how to! I like the idea of the sticker paper to the metal!
  20. #120 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Just wait till I can afford a plasma
    Nope, I was hoping to use the school's CNC plasma but that got shot down, f-ing bureaucracy...
    I collect Jeeps.
  21. #121 Re: The Polar Bear - 5.3L Chevy Install Begins
    Depending on how steady you are, plasma can leave a fairly jagged line esp on thick material. When I plas out brackets, I normally cut them big and flap disc the edges down smooth. On brackets with non-radiused edges, often it's quicker to cut them with a cutoff wheel on an angle grinder, especially once you factor in cooling time for parts that have been plasma cut.
  22. #122 Re: The Polar Bear - 5.3L Chevy Install Begins
    Midlothian Virginia
    You get + rep as soon as I can give it again, thanks for the info man, looks great.
  23. #123 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Your welcome.
    I collect Jeeps.
  24. #124 Re: The Polar Bear - 5.3L Chevy Install Begins
    Wouldn't it be easier in the garage to use the dimension in red? (Below not to scale)
  25. #125 Re: The Polar Bear - 5.3L Chevy Install Begins
    Junior Member Maximoe's Avatar
    Sep 2009
    Prince George BC
    cool to see im not the only one using CAD to design stuff... i definetly like the idea of the sticker paper... might be taking a page out of your books soon as i build my bumper http://i485.photobucket.com/albums/r...jeepdesign.jpg
There are currently 4 users browsing this thread. (0 members and 4 guests)
Tags for this Thread
View Tag Cloud
