The Polar Bear - NP241 Upgrade - Page 2
Thread: The Polar Bear - NP241 Upgrade
Page 2 of 30 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 737
  1. #26 Re: The Polar Bear
    Seattle, WA
    Haven't done anymore work on it because I'm out of money and I need to get the front drive shaft cut down a couple of inches but my friends and I went out two wheeling and shooting this weekend. Figured I'd put up some pics.
    Think I need to lengthen my rear bump stops and trim the fenders. I know "I told you so"
    My friend Drew goofing around.
    Here's some pics of the trails we were doing. Nothing difficult obviously since I was able to do it in two wheel drive and a rear locker once in a while but it was still a lot of fun.
    And finally a shot of all of us with the guns.
    I collect Jeeps.
    The Polar Bear Detailed Build
  2. #27 Re: The Polar Bear
    Oct 2008
    Greenville, NC
    is it just me or does it look like that guy with the handgun is pointing it directly at the head of the dude on his left..... with his hand on the trigger?
    edit:... now it looks like he's fixin to shoot that girl.... with his finger on the trigger..
    Jeep. Bouncy and fun.
  3. #28 Re: The Polar Bear
    Seattle, WA
    Yeah, really bad form. How about another one.
    I collect Jeeps.
  4. #29 Re: The Polar Bear
    Dec 2005
    Central Mass.
    Guns are cool... put keep your clothes on...
  5. #30 Re: The Polar Bear
    Seattle, WA
    What can I say, my friends are tools. haha
    I collect Jeeps.
  6. #31 Re: The Polar Bear
    Seattle, WA
    Time for an update.
    I broke my hand, that sucked.
    and now for some pictures of my next project.
    It's a 5.3L out of an '03 Silverado, low mileage and freshly rebuilt transmission. As far as I can tell, with the exception of DieselZJ, I'm the first to attempt a non-ZJ native motor swap. Should be fun.
    For those of you going ?!?!? why the fuck would you do that, simple, for a 5.9L V8 its anemic and I get 10mpg on the freeway. With this new motor, I'll get more horsepower, run on regular unleaded and get better gas mileage.
    I collect Jeeps.
  7. #32 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Took the harness off the motor today and now I'm starting to pick through it to remove what I don't need. This is going to take a while ...
    I collect Jeeps.
  8. #33 Re: The Polar Bear
    I though Kraqa ran a propane powered Chebby motor for a while too?
  9. #34 Re: The Polar Bear
    Seattle, WA
    Cool! I must have not found it. I just did a ton of research on motor swaps into ZJs and all I found we're the native ZJ motor ones.
    I collect Jeeps.
  10. #35 Re: The Polar Bear
    There are plenty of guys out on the trails that never cruise the forums. While you are definitely on the early end of this curve, I would be surprised if you're even in the top 10.
    You're definitely making a smart move jumping to a real v8. I don't understand the hype surrounding the 5.9. Sure it makes decent power and Jeep should have put them in every ZJ they ever made, but it's easily overshadowed by even a very modest modern engine like a 5.3.
  11. #36 Re: The Polar Bear - 5.3L Chevy Install Begins
    Mar 2008
    Saint Helens, OR
    Can't wait for a write up on the 5.3L install. Seems a decent choice for a swap. The 5.3L, as far as a quick Google search shows, makes about 285-295 hp and torque is 325-335 lb·ft stock. The 5.9L was rated at 245 hp and 345 lb·ft of torque. Pretty close torque numbers, more horsepower, and with an upgraded engine design that is damn near guaranteed to give better service life and better fuel mileage overall.
    Now the Jeep has Ford and Chevy parts!!
    J.E.E.P.- Just Everyone Else's Parts
    NEW JOB!!!!! NEW BABY!!!!
  12. #37 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    There are defiantly Jeeps out there with non-native motors, I just hadn't seen many ZJs and like I said, it was as far as I could tell.
    Quote Originally Posted by Goosed76 View Post
    Haha seriously. After I swap the motor, literally none of the drive train that originally came on the vehicle will still be there.
    I've been doing the research on cutting down the wire harness and making all of the original gauges work, I'll keep the posts going here and when I'm done do a write up. I want the motor swap to be completely transparent where everything works as it did previously. The only gauge I haven't figured out how to make work yet is the tach, I'm not sure how the stock Jeep ECU calculates RPMs, if its from the crank position sensor or the firing of the ignition system. Once I figure that out I'm just going to make a simple circuit to take the tach signal from the Chevy ECU and use it to generate a dummy signal for the Jeep ECU.
    I collect Jeeps.
  13. #38 Re: The Polar Bear - 5.3L Chevy Install Begins
    Senior Member fr3db3ar's Avatar
    West Michigan
    Nice project....keep us updated....we love information
    5.9 ZJ With stuff attached
    It's true that I'm old enough to have been there done that.....it doesn't make me an expert...it just gives me an educated opinion.
  14. #39 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Well before I park the Jeep for the motor swap, I took it out for one last coupe de gras and well ... I made it count. We were driving over the salt flats at Soda Lake in the middle of nowhere in California: http://maps.google.com/maps?f=q&sour...58557&t=h&z=10
    and we found a massive muddy sink hole...
    after 5+ hours of digging and calling one of my friends with a Jeep to come be a land anchor for my winch we got unstuck.
    Lesson learned, even if it looks as dry as the freakin Sahara desert it helps to know exactly what you're mobing on.
    At the end of the day there is a couple of hundred pounds of mud stuck to my Jeep and my steering is pooched. We drove 75 miles back to town at 25 MPH. It's been one hell of an adventure and a long day.
    Tomorrow I'm washing it off and starting the disassembly for the motor swap.
    I collect Jeeps.
  15. #40 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Got the motor out today! Now I've just got to pick up the steel to plate the frame rails and fabricate the motor mounts and coilover hoops out of.
    I collect Jeeps.
  16. #41 Re: The Polar Bear - 5.3L Chevy Install Begins
    Senior Member bnboffroad's Avatar
    Mar 2007
    linville
    was your stock motor a 4.0 or v8? if it was the 4.0 you cant make a 6 cylinder tach work for a v8 ive painfully tried you will prob have to get one form autometer
    Ray Charles gofast Tjuggy tons atlas 40" creepys,BLACKMAMBA 3500 Suburban 8.1 tow monster
  17. #42 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    It was a V8. Maybe you can answer my question, how does the Jeep ECU calculate RPM? Is it based on the crank position sensor or what? The Chevy ECU outputs a signal I can use and modify using a microcontroller to anything I want, I'm just not sure what I need to send the signal to.
    I collect Jeeps.
  18. #43 Re: The Polar Bear - 5.3L Chevy Install Begins
    Mar 2007
    linville
    i would have to say the crank but to be shure i would call a company that goes through harnesses and ask like PAINLESS wiring www.painlessperformance.com theres plenty of companys doing it they could probaley point you in the right direction
  19. #44 Re: The Polar Bear - 5.3L Chevy Install Begins
    Senior Member faststang1's Avatar
    Sep 2007
    Palm Spring's CA
    heres a hemi motor swap!!!
    http://www.cardomain.com/ride/2303256/6
    96 ZJ Limited, 5.2 with K&N filter, Hi flow cat, Cherry bomb extreme muffler, Clayton long arms 6" lift, Steering box brace from KOR, KOR track bar Conversion,TnT steering, 242 TC, 8.8 with ARB Locker, dana 30, 4.88 gearing, 35 KM2's
    KOR bumpers
    http://www.mallcrawlin.com/forum/showthread.php?t=17149
    07 CRF250X
  20. #45 Re: The Polar Bear - 5.3L Chevy Install Begins
    Mar 2008
    Saint Helens, OR
    Yeah, that guy was on this site for a short while- kinda got butt hurt with everyone poking fun at his exo-cage and going to Rockwells I think. Guy is sponsored(why? I have no idea). The hemi fits, but you have to cut the frame rails and widen them, then re-plate the rails in order to clear- apparently it's wider than a 5.2 or a 5.9...
    I kind of like the 5.3L Vortec idea- apart from it being a non Mopar engine- I'm the guy who hates fords with chevy engines- but makes enough sense in a wheeler- we swap all kinds of parts- why not a GM engine with Ford axles in a Jeep? lol
  21. #46 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Yeah, I see what your talking about tearing pretty much the whole front frame rails apart. Damn that's a shit ton of work. Mine fits with a lot less work. I like how he fab'd the coilover hoops though, that's a lot like I had in mind for mine, including the cross brace over the engine.
    I collect Jeeps.
  22. #47 Re: The Polar Bear - 5.3L Chevy Install Begins
    Seattle, WA
    Christmas came early today!
    and here is a quick pic of my friends project:
    I collect Jeeps.
  23. #48 Re: The Polar Bear - 5.3L Chevy Install Begins
    I find myself unable to find the words to describe the AWESOMENESS of that project!
  24. #49 Re: The Polar Bear - 5.3L Chevy Install Begins
    Senior Member dp96zj's Avatar
    Texas
    Is the papa johns sign structural? It looks like it'll prevent you from being stuck on your roof in an endo.
  25. #50 Re: The Polar Bear - 5.3L Chevy Install Begins
    Jan 2008
    Wichita, KS
    just throw some super powerful lights under the papa johns sign and you can use it for night runs
Tags for this Thread
View Tag Cloud
