Flatland Rig - Page 4
Thread: Flatland Rig
Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 166
  1. #76 Re: Flatland Rig - lightweight roof rack
    Jan 2008
    Wichita, KS
    Fixing up a car hauler for a tow rig. It's going to be a tight squeeze, but the ZJ should fit. Boards were rotten through so we ripped them off to begin with.
    Started in on the sanding and grinding to get rid of the rust as much as possible.
    Primer to all the bare metal and then started the first coat of black equipment paint.
  2. #77 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Went wheeling yesterday.
    Day went well until the input hose to my radiator blew. Was able to jerry-rig it together to get back out, but it was kind of frustrating. The plastic tube going into the radiator was the piece that cracked right under where the hose clamp was. The hose itself was fine, so I don't know if maybe it was to tight, or what happened...
    Other than that, it was a lot of fun - I accomplished some stuff that I didn't think I could do, so I am pleased.
    Things learned:
    Need a lower temp thermostat
    Need an e-fan
    22 psi is good, but I'd like to try lower in the tires
  3. #78 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Here's the piece of the radiator that broke off. The crack running length-wise down the tube is from me prying it out of the hose.
    Moved the hose clamp to the portion of the radiator still sticking out (about 1/2 in.) and then wrapped a bungee cord around it to help pull it toward the front of the jeep if it needed it.
    It made it through the rest of the day and the 150 mi trip home, so something worked.
    Kind of sucks that I might have to by a new radiator just for that...
  4. #79 Re: Flatland Rig
    holy ghetto fix.
    I have rad from a 4.0 just sitting if you can't find one local.
  5. #80 Re: Flatland Rig
    Aug 2009
    Kansas
    He's a jerry riggin' fool, he got the tool for the job.
  6. #81 Re: Flatland Rig
    Aug 2005
    New Kensington, PA
    That front bumper looks pretty good
    I did the same mounting style on mine except I used sandwich plates on the outside of the uni-body.
    Keep in mind that your gonna want some sort of cross bracing before you start winching with it in case you end up pulling @ an angle.
    Knit up a yj beast
  7. #82 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Quote Originally Posted by boulderado1965 View Post
    that's a funny song
  8. #83 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Just for fun - 30" from ground to tire. Not bad I guess for factory arms haha
    Oh, and got one step closer to overhauling the trailer. I will need to add brakes before hauling.
  9. #84 Re: Flatland Rig
    Sep 2009
    Queen Creek, AZ
    Very nice build bud, love all the custom work. Can't wait to start fabbing more parts for mine.
    Dan- '93 ZJ ,4.0, 249 TC(soon to be 231), open 30/open 35, 3.5" lift, 32x11.50x15s, sliders, KO radiator support, KCs and trimmed.
  10. #85 Re: Flatland Rig
    Member MoonyJohn's Avatar
    West Linn
    I wish I knew someone with a forklift. I want to test mine out.
    Rig looks great man, the front bumper came out real nice.
    ZJ to WJ to JK back to WJ 4 Lyfe
  11. #86 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    It's been a long time since I last updated... probably because I haven't done anything in a really long time. To make a long story short:
    1) 1st Child Born
    2) Sold bumper and roof rack to pay bills
    3) Began new bumper project
    Doesn't look bad from this angle (hasn't been leveled yet):
    But here makes me cringe:
    I will start some hacking to suck it back into the zj. I can't have it sticking that far out. Talk about killing approach angle!
  12. #87 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Made progress today. I built a lower skid to protect the radiator which bolts on to the bottom of the bumper - it should be ok from anything other than a serious crunch.
  13. #88 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Painted and mounted:
  14. #89 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    It has been a long time since I posted an update for my ZJ. Nothing has really changed much since the last post, but I am starting a rear bumper build so I figured I would document it.
    Factory rear bumper was a royal pain to remove. The studs that held it on were completely rusted to the nuts and it began to bend the unibody with all the torque I was putting on it - even after days of soaking them...
    Eventually I had to resort to other methods to get them off.
    I think it's time for some plate. I'm assuming I will want to remove the gas tank before welding back there.
    I will be incorporating the hitch inside the bumper. The top of the bumper is going to be removable for storage and locking of the hitch pin inside. I will be gaining around 7" of clearance from where the hitch receiver sat before.
    Jan 2010
    El Dorado, Kansas, United States
    Dude! You are in wichita? Ever make it up to el dorado?
    Jacob
    1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and IRO OTK steering 35x12.50x15 BFG KM2's
    Artec trussed 8.8
  16. #91 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Quote Originally Posted by lateralus3 View Post
    rarely
    Jan 2010
    Oh well. I come to wichita every now and then,if you see my zj chase me down
    Jacob
    Artec trussed 8.8
  18. #93 Re: Flatland Rig
    Dec 2010
    kansas city
    next time you come out to tuttle(from teh looks of the pic with ur blown radiator it looks like tuttle) hit me up and i can get a group of people together to wheel
    edit: btw nice looking zj. front bumper looks good cant wait to see how the rear turns out
  19. #94 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Quote Originally Posted by PurpleZJ View Post
    I'll have to do that - thanks
    If anyone was curious, here's the rear bumper design:
  20. #95 Re: Flatland Rig
    Feb 2011
    New Hampshire
    Good, I'm glad your back with another little project.
    Brian
    1aauto.com
    866-433-3393
    Jeep Repair Parts
  21. #96 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Gas tank dropped for unibody welding:
    Stitch welded plate - I thought it came out decently.
  22. #97 Re: Flatland Rig
    Jan 2010
    i need to do this. my bumper is rusting
    Jacob
    Artec trussed 8.8
  23. #98 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Finally got a winch too!
  24. #99 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Put the new plasma cutter to use today.
    Parts:
  25. #100 Re: Flatland Rig
    Jan 2008
    Wichita, KS
