Flatland Rig - Page 2
Thread: Flatland Rig
Page 2 of 7 FirstFirst 1234567 LastLast
Results 26 to 50 of 166
  1. #26 Re: Flatland Rig
    look good except that they are super short, looks like your swaybar is at a bad angle but i can't tell completely from the pictures. from what i remember it should be 10-15 degrees upward
    97 V8 zj.
    03 Cobra with horsepowers
  2. #27 Re: Flatland Rig
    You may want to elongate the threaded rod portion.. And might want to use some jam nuts to preload the threads in the heims and prevent any accelerated wear.
  3. #28 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Cool, thanks for the info - not a big deal I can cut a new piece. The rep that sold me the end links told me I wouldn't need jam nuts for female ends... is this true? I'm not sure I understand what you are saying about the jam nuts.
  4. #29 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    I added support for skid plate - doesn't move at all now.
  5. #30 Re: Flatland Rig
    i have the same thing on mine, cam (atlzj) made that peice to the KOR crossmember, looks exactly the same
    97 V8 zj.
  6. #31 Re: Flatland Rig
    May 2008
    Overland Park, KS
    I think ATL ZJ means cut a longer piece of all thread and spin a pair of nuts on before installing the female ends, then tighten the nuts to the end pieces to keep vibrations and load from wearing the ends loose.
    93 ZJ Limited 4.0 AW4
    242 swap
    6.5" springs, JKS discos
    35" Baja Claws
  7. #32 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Beginning a front bumper project. I drew up some plans using Google Sketchup.
    So then I started making a mock-up of the bumper from cardboard. What do you think?
    Goals for Bumper:
    Fairly lightweight
    Winch Capable
    Good Approach Angle
  8. #33 Re: Flatland Rig
    Jan 2008
    North Carolina
    That is some very extensive cardboard work. I say just spray all that black and call it a day.
  9. #34 Re: Flatland Rig
    Long Island NY
    looks good. alittle wide but, idk if you have a reason for that
    Black 97 ZJ, 4.0, 242, Clayton LA 4.5" lift +2"spacers, TW DS, 8.8 4.10's, HPD30 4.11, WJ steering conversion, 1 ton flip, PSC , KOR TB conversion, Front axle Currie JJ bushing conversion, Baja Claws 33's, Custom front & rear bumpers, Rear tire carrier, rock sliders
    Works in progress->...
    http://i23.photobucket.com/albums/b3...4/P1010203.jpg
  10. #35 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Quote Originally Posted by BLK97ZJ View Post
    I think I agree with you on that. I might try and angle the sides in a bit and see how that looks.
  11. #36 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Well, I decided to just tear into it today since I had the day off. Made some good progress too!
    Started by cutting some pieces of 3/16". I made some changes to the design before I began - decided to narrow it up a bit.
    Tack welded together most of it:
    Propped it up on the front end for looks with some boards... I decided it needed to go up and back a bit, but first it was off to the scrap yard to pick up some mounting stock. I found some 3/8" which will work for me but was severely disappointed with the price of some scrap I took to sell to help offset the cost. $.02 per pound in the door - $.20 per pound out the door.
    Anyways, cut my mounting brackets and drilled my holes. Got my bolts and nuts in order and here she sits for the night:
    To Do list includes:
    Cutting angle pieces for lower protection
    Finding some d-ring mounts
    Welding
    Grinding
    etc.
  12. #37 Re: Flatland Rig
    Can't see pics...
    93 ZJ V8
  13. #38 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    red x's or nothing at all?
  14. #39 Re: Flatland Rig
    i see them
    97 V8 zj.
  15. #40 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    I made some progress on the bumper. Got pretty much all the pieces cut out except for some bracing and boxing in of stuff. Welding and grinding needed still. I meant to snag a pic of the bumpers mounting and bracing but forgot.
  16. #41 Re: Flatland Rig
    Senior Member Spr-T-23's Avatar
    Oct 2008
    Imlay City, Michigan
    pretty bad ass, love the custom work
    96 ZJ, Black, 5.2, Auto, 242 Swap, D30 D44a, 3.5 inch lift and 2 inch poly boost 5.5 inches total lift, 33/12.5/15 BFG MTs on Chrome steelies
  17. #42 Re: Flatland Rig
    Mar 2008
    stationed at tacoma wa
    nice looken bumper, how did you attach it?
    -e-boner
  18. #43 Re: Flatland Rig
    Jan 2008
    Wichita, KS
    Thanks - 3/8" mounting brackets into the unibody slots. I welded the nuts to the mounting bolts to the insides of the brackets. Slides in pretty snug and then you can just tighten up the bolts.
  19. #44 Re: Flatland Rig -- Front Bumper Build --
    Jan 2008
    Wichita, KS
    mmm..
  20. #45 Re: Flatland Rig -- Front Bumper Build --
    Dec 2005
    Central Mass.
    Incredible work!
    Looks great.
  21. #46 Re: Flatland Rig -- Front Bumper Build --
    Senior Member greengc4x4's Avatar
    Feb 2008
    lima,ohio
    nice design!
    '98 ZJ 5.9L Ltd
    UC Springs/.5" spacer/MX6 Shocks/SCT Tuned/BBK 52mm TB/K&N FIPK/Amsoil Filter/"Jeep" Valve Covers/Doug Thorley Headers/Random Technologies Cat/Magnaflow/"Kolak" Ignition/Optima Redtop/Lotek Dual Pillar Pod/AEM Tranny Temp Gauge/Mag-Hytec Tranny Pan/RB1 WJ Nav/Vancos/EU Headlights and Turn Signals/Turn Signal Mod/JKS Disconnects
    Waiting to be installed
    M1/Insulated Fuel Rails/24lb FMS Injectors/Underdrive Crank Pulley/Walbro Fuel Pump/Prothane Bushings/Hotchkis Swaybars
  22. #47 Re: Flatland Rig -- Front Bumper Build --
    Jan 2008
    Wichita, KS
    Finished welding. Started applying some body filler to some pockets to smooth things out. This is after a little sanding. I need to finish sanding it down and then its on to primer and paint!
    Thought the d-ring tabs came out pretty nice too:
  23. #48 Re: Flatland Rig -- Front Bumper Build --
    Kiowa, CO
    Great build, it has good lines too.
    Project Never-ending
    1997 ZJ - sold
    www.tntcustoms.com
  24. #49 Re: Flatland Rig -- Front Bumper Build --
    Massachusetts
    nice looking bumper, and jeep. would you mind taking some pics of the mounting setup? once it gets warm enough to do some work outside ill be starting on mine. thanks.
  25. #50 Re: Flatland Rig -- Front Bumper Build --
    Jan 2008
    Wichita, KS
    As requested:
