Post up stuff that you are willing to part with to save on shipping costs:
Me:
1 pair Bilstein 5100's: 34.9" extended, 14" travel-$60 (used about 3000 miles)
1 pair Bilstein 5150's: 29" extended, 12" travel -$50 (one leaks a little bit, but still working well)
1 Avalanche Engineering (Poison Spider) D 60 Rock Ring + mounting bolts- used $20
1 Mile Marker snatch block (new, never used) $10 -Aprilz Warrior
D44A spiders + cross pin -FREE
D44A/D35 -WJ style wheel seal/bearing replacemnt kit (1 pair to do both sides of the axle) -$30 -wannabeoffroad
2" BB ZJ style only 2
1 cold one all the way to Moab.
PM sent on the snatch block if it won't work for AW.
We can bring the following, if we can make a deal on it prior to 5pm PST Tuesday. Make sure to e-mail us at sales@kevinsoffroad.com. DO NOT SEND PMs. All pricing "no-dicker sticker", unless you purchase a KOR product of $50+ from our website and we save you shipping by carrying everything up together for you.
Crane Diff Cover D44 in great shape.
Retail was $180
Sell for $100
Bilstein 5150 rear WJ/ZJ shocks for 2.5"~4.0" of lift, dirty/used, but still good
Retail is $150/shock x 2 = $300
Sell for $100 for BOTH
D30 axle shafts - CV style for ZJ/XJ/TJ
$20 each, some rights some lefts, some with good CVs, other CVs worn
Makes great spares
D30 axle shafts - CV style for WJ
$40 each, one right, one left, CVs should be good in both
D35c rear ZJ shafts, with tone rings and lug studs in good condition
$25 each
Makes great trail spares
Detroit D44 locker (the original locker) in good condition
$600 retail new
$350 used (works great)
D44 XJ rear axle shafts from Superior, 31-spline. Bent slightly, but great trail spares. Works with both disc and drum brakes. 5x4.5 and 5x5.5 spreads.
$125 ea retail x 2 = $250 plus shipping
$60 for the pair
Nearly new NP231 t-case from a 2000 TJ. Has 4k miles on it, I was told. Purchased for $525 several years back, and has collected dust ever since. Would make a great SYE project for someone, and would save you over $100 in shipping if I bring it along.
$325 barely used
Three 37"x12.5"x15" MT/R tires with better-than-reasonable tread. (50%?)Slightly "chunked" on side-lugs but still good for another 10k-20k miles. Would make excellent spares.
$200+ retail each (new)
$45/ea (used and loved)
JKS-3100 discos
$130 new
$75 used, but in good condition, with all mounting hardware sent to you directly after GSW.
JKS-7100 front upper control arms (ZJ/WJ/XJ/TJ)
$250 new plus shipping
$200, slightly scratched
Silver/Gray fabric set of rear seats (1993-1995 ZJ). Complete and in good shape. No tears.
$35 for the entire thing (two back cushions, two butt cushions, 60/40)
Charcoal set of rear seats (1996-1998 ZJ). Complete and in EXCELLENT shape. No tears.
$55 for the entire thing (two back cushions, two butt cushions, 60/40)
Two front seats, Charcoal, from a 1996-1998 ZJ. Excellent condition. (no bases...use your old base to mount)
$75 each.
Ford SuperDuty/Excursion parts
1999-2008 paddle mirrors, left and right
$20 each
1999-2008 Reese 45008 "Tow Beast" Class-5 Receiver
1700lbs tongue, 14000lbs max w/weight distrib hitch
Also have Class-5 W/D hitch "stinger" (not the hitch...the part the W/D hitch bolts to)
Includes 2.5"x2.5" tongue and 3/4" pin
This thing is HEAVY DUTY, folks! The strongest bumper-pull hitch you can buy
$500+ plus shipping retail, used only once on my 2002 SuperDuty F250
$225 takes EVERYTHING.
2000 Excursion front grill fits 1999-2004 SuperDuty for a new look
$25 takes it
Kevin,
I'll take these off your hands. -Todd
1" ZJ/XJ/TJ front or ZJ/TJ rear budget boost spacer pair
$40 new
$30 used (for a week)
Kev, I'll take a driver and a passenger D30 shaft - gotta build up my trail spares
I'll shoot you an email.
I got a few things:
Rusty's off Road T-case skid.
Pair of stock D-35 C-clip Axle shafts
I was going to wait until after GSW to put this stuff up for sale, but a swap meet seems to make sense.
Full set of brackets neatly plasma'd off a D44A - $40
D30 carrier, loaded, 3.73 and up (4.10, 4.56, etc) - $25
LP D30 3.73 gears, about 40K miles - $10
Rear drive shaft from I6 ZJ - $10
D44 (iron) diff covers (2) - $5 each
Tow hook mount, front, drivers side only - $5
242 bezel, 1 of the 4 clips is broke - 12oz of beer
Extended front sway bar links (from procomp lift) - 12oz of beer
D44A 3.73 gears - free
front callipers - free
charcoal canister - free
stock intake filter box - free
stock rear track bar - free
front ABS sensor pair - free
The above is from memory, I'm sure I'll unearth some other crap.
I have an adjustable rear tracbar. I think it's JKS or RE. Worked on a ZJ with 5.5" of lift.
$50 obo
I have a ZJ tow hitch--factory from a 98. $20 obo
I also have a AGR steering box, with 1 broken ear (bottom right if facing the box from the drivers wheel well) I was going to turn it in for the $100 core value, but if someone finds it more valueable than $100 then I'm more than happy to do that.
I'll have to see what else is in my pile that might have value.
I have a practically new Kevin's prototype rear tube bumper that I bought from him a few years ago when I was in Phoenix. I never mounted it on my jeep, and I don't think Kevin had it on his very long before I bought it from him and made him take it off his jeep for me. I don't have time to take pics and post them, but the bumper is grayish-silver powerdercoat and it is in perfect condition minus a couple small scuffs from being moved around the shop. It has a 2" receiver hitch built in. The build quality and welds are very professional.
Here it is on Kevin's jeep... http://kevinsjeepparts.com/images/zj...oBump_0010.JPG
For more pics of it, check kevinsjeepparts.com under "bumperz."
The back of my jeep is so mangled right now that a back bumper is the least of my concerns and the money would be more useful to me right now.
400$, and I'll need to know ASAP as we're leaving in a few hours (at least that's the plan!)
-Ron-
Used OME SS-20 bucks
Tera Drop pitman arm-10 bucks
Stock control arms for a WJ.Make offer on what ever you need.
Kevin-
I've got a really pretty bumper for sale...I bet it would look good on your jeep.
-Ron-
Hey Pitch,
If no one picks up your Bilsteins let me know! I can't make it to GSW, but I may be interested in these if no one takes them!
Thanks!
LOL! A few years ago you are in a rush to grab a bumper from me while you're out here in AZ, and we don't have one in stock, so we tear the one right off my OWN JEEP in the name of customer service. Then, you take it back to the Midwest, let it sit around for several years, collecting dust, take on a few bruises from storing it, and then drag it ALL THE WAY back to the Southwest to sell??!!
I know the old adage..."the customer is always right"...but WTF, man??!! LMAO!!!!
Looking forward to seeing your crazy ass there in Moab, my friend!!
Kevin
I have:
driver headlight $15
bored 4.0L throttle body 60mm $75
V8 rear drive shaft $10
one front short side u-joint axle shaft D30 $20
one front long side cv axle shaft D30 needs a new boot but doesn't click $10
Dana 35C axle shafts with tone rings from drum brake TJ I was told one was a superior shaft and one a stock replacement. $50 for the pair
Ken, does that short-side shaft have tone rings?
Negative, sorry I meant to mention that. I was going to pull the ones from my cv shafts to put on it. You can have the cv shaft with it if you want, the short side is crap.
