2008 Carnage Pics
Thread: 2008 Carnage Pics
Results 1 to 9 of 9
  1. #1 2008 Carnage Pics
    Santa Fe, NM
    Post the carnage in here!
    Well, I figured out the problem. It turns out that I bashed my t-case skid/x-member so hard that it was in contact with my transfer case. The vibrations from the motor and transmission/drivetrain were being transmitted back through the cross member and into the body. I'm not sure if it was a result of that bolt coming out of my crossmember, but looking at the design, it seems pretty likely that it will happen again. I need to find a way to stiffen the rear support arm....look below.
    Originally there was no gap between these two surfaces.
    The bracket attached to the unibody was mangled. I pounded it out best I could.
    Final Result:
    I'm going to contact Kevin and see if anyone else had this problem. I think the main problem is that rear bracket that attaches to the unibody rail is just too thin. I'm thinking of modifying it so that it is 1/4" u-channel instead of that thin plate and having 2 bolts running through the frame rail in addition to the 2 tapped in from the bottom.
  2. #2 Re: GS-MW 2008 @ the Badlands!
    Member 10achik's Avatar
    Aug 2006
    STL (IL side)
    Dove into the caliper job today, thought it would be relatively simple...not.
    Pulled off the wheel and found this:
    Notice the sheared bolt still in the back:
    Only way to get to it, was to remove the axle shaft an the dust cover.
    Drilled a hole and used some ezouts and removed it:
    Went to the store and found some new bolts and went to put everything back together and found out the caliper bracket was actually bent. Took the bracket off and put it in a vice and beat the crap out of it. Used a little heat, a wedge and the vice to finally get it bent back right. Cast aluminum parts are not fun to bend. Anyway got it all back together, then the ABS light wouldn't go out, messed witht he wires and got that fixed.
    Here's a few pic's of the other damage I found today:
    The skid plate held up well considering the whole jeep was being supported by it:
    Ken
    99 Limited - 4.7L HO V8, 6.5" IRO High Clearance Long Arms, F&R D44s locked/trussed, 4.10's, 242HD, KMA Bumper, 33" Yokohama Mud Rovers + Lot's more
  3. #3 2008 Carnage Pics
    Senior Member EMTimZJ's Avatar
    Jan 2006
    West Michigan
  4. #4 Re: 2008 Carnage Pics
    Junior Member bgcntry72's Avatar
    Milwaukee
    Maybe I should walk around the rig and take pics of every scratch and scuff like some people.
    For the record, that ass bomb that Ken dropped in the Jeep should count as carnage.
  5. #5 Re: 2008 Carnage Pics
    Aug 2006
    STL (IL side)
    Just trying to share the love man
    Ken
  6. #6 Re: 2008 Carnage Pics
    Senior Member tywilson88's Avatar
    fuckin dana 30
    these are 31 spline alloys
    Quote Originally Posted by Four Play View Post
    I'll probably go to Hell for that but fawk it, I'll upgrade my 1st class ticket and go for another pack of peanuts... cremation cost are on the rise anyway.
  7. #7 Re: 2008 Carnage Pics
    Sep 2007
    hinesburg vt
    my front carier last year
  8. #8 Re: 2008 Carnage Pics
    Boulder, CO
    Wow, never seen a broken carrier like that!
    -Ryan
  9. #9 Re: 2008 Carnage Pics
    Sep 2007
    hinesburg vt
    my Black lab hit the line lock switch (well at least i can say my dog broke my Jeep
