Goldensd's Build Pics -3/12 Rear Spring Revamp
Thread: Goldensd's Build Pics -3/12 Rear Spring Revamp
Page 1 of 7 1234567 LastLast
Results 1 to 25 of 154
  1. #1 Goldensd's Build Pics -3/12 Rear Spring Revamp
    Jul 2005
    Pittsburg, CA
    OK so I decided to post some pics of my completed Jeep work over the past few years. Since, I am doing this all at once I'm mostly going to put up the completed pics for now, but I do have more pics of most of the builds so if you see anything you'd like to see closer, let me know what you want to see, and I'll post it up if I've got it.
    Also, I'm not going to bother with of too much of the purchased items, as you've all seen them before, but rather the stuff I've fabricated, so that hopefully I can provide some ideas and insight to others out there.
    Please bear in mind that these pics area covering the last 3-4 year, so you may see certain variations on my setup that no longer exist.
    For starters a brief rundown on my setup includes (**UPDATED 5/12/08**):
    Mostly stock 5.2L w/ Auto Trans and Atlas II 4.3:1 Transfer Case
    Claytons Longarms w/ 4.5" Rubicon Springs w/ Acos (front) and Poly (Rear) spacers for about 5.5" of lift
    35" BF Goodrich KM2's
    10" Bilstein 5150's (Triangulated in rear)
    Ford 8.8 w/ Yukon 4:11 Gears and Eaton E-Locker
    Waggy Dana 44 w/ Yukon 4:11 Gears and Eaton E-Locker
    True Highsteer
    Custom work you'll see here includes:
    Front Bumper, Rear Bumper, Diff Skids, Roof Rack, Sliders, Transfer Skid, 8.8 Bracketry, and most of the Dana 44 Bracketry
    Here are a few of the Transfer Case Skids and Sliders:
    '97 ZJ Limited, Atlas II, 35" KM2's, 4.5" RE Springs + ACOS Spacers w/ Clayton's Longarms, Ford 8.8 w/ Triangulated Bilstein 5150's, Waggy D44, Lockers Front and Rear, and Lots of other customs stuff....
    http://www.mallcrawlin.com/forum/showthread.php?t=15667
  2. #2 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    And Here are some of the Roof Rack:
  3. #3 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    The Ford 8.8 brackets and Triangulated shock mounts:
  4. #4 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    The Rear Differential Skid:
  5. #5 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    The Front Differential Skid:
  6. #6 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    The Front Bumper w/ Dual Rate Swayloc integrated into the Radiator Support:
  7. #7 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    And finally, I have a rear bumper nearing completion. The progress pics for the bumper build are under a seperate thread at:
    http://www.mallcrawlin.com/forum//sh...ad.php?t=15250
  8. #8 Re: Goldensd's Build Pics
    Member LILL ZJ's Avatar
    Nov 2007
    NORTHEN MICHIGAN
    Is your rear truss suposed to be off center? i really like your low profile rack though
  9. #9 Re: Goldensd's Build Pics
    Nov 2007
    NORTHEN MICHIGAN
    oh ok i see now your the guy building the rear bumper... i really like that, i take back the origional coment about the rack, i think you coulda done better
  10. #10 Re: Goldensd's Build Pics
    Quote Originally Posted by LILL ZJ View Post
    The pumpkin on the 8.8 is offset to the pass. side. Truss looks centered to the axle as a whole.
    Clean work and good ideas, golden. Keep it up.
  11. #11 Re: Goldensd's Build Pics
    Very nice. Does your rear shock crossmember just bolt to the uniframe? Or is it welded also?
  12. #12 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    I agree... I wouldn't change the design at all, but yes the rack was one of my first builds, and I didn't have the mig, so the quality is off a bit. It still looks good just don't look close
  13. #13 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    It's welded in. I used the bolt setup to hold it in place to get it welded in.
  14. #14 Re: Goldensd's Build Pics
    Senior Member grandmaster's Avatar
    Utah
    Looks really good, nice and clean. How do you like the ected?
  15. #15 Re: Goldensd's Build Pics
    Jan 2007
    Powder Springs, GA
    Looks good. How is your rack mounted to the crossrails?
    Ben
    1993 Jeep Grand Wagoneer ZJ : V8, 3.5", 31" M/Ts, Swapped in D44a with Aussie
    www.gatrailriders.com
  16. #16 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    Quote Originally Posted by Sporer65 View Post
    I got rid of the flimsy triangle shape rail that was one it and squeezed either 1x1 or 3/4x3/4 (I forget which fit) into the factory plastic moulding underneath the rail. Drilled oversize holes in the top to access and use all of the threaded insert from the factory roof mount to bolt it down. I then attached some 3/4" angle iron to the new rail and built the rack off of that.
  17. #17 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    Quote Originally Posted by grandmaster View Post
    No complaints. When I first put it in, I had trouble with it engaging, but one call to Auburn, and they gave me some tolerance specs to check on the magnet, and it turned out I didn't have it seated quite enough. After that no issues. Personally, I like the comfort of knowing that the locker will disengage if it gets really bound up since it is on a small axle, but yet I can't say it has ever popped free when I needed to be locked up.
    Plus, only having to run a couple of wires to it was a big plus to me for installation purposes.
  18. #18 Re: Goldensd's Build Pics
    Senor Member Lifetime Supporter ArloGuthroJeep's Avatar
    Boulder, CO
    Nice rig
    -Ryan
    '04 WJ w/6" on Clayton LA's, 242 SYE, 4.56 (locked 44a), 35" BFG MT KM2's
  19. #19 Re: Goldensd's Build Pics
    Senior Member ILikeMud's Avatar
    Jun 2005
    Paradise, Newfoundland Canada
    Nice looking rig man.
    Do those diff skids ever become anchors?
    Anthony
    96 Talon TSI AWD - Hey, at least it has a transfer case.
    03 Chevy Tracker - I hate IFS!
  20. #20 Re: Goldensd's Build Pics
    Member wjguy's Avatar
    marysville washington
    Quote Originally Posted by ILikeMud View Post
    I was going to say the same thing it looks like they could get hung up real easy. but other than that you have done some outstanding fab work my friend! VERY NICE!
    stuff welded and bolted to a wagon
  21. #21 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    Not at all. They're built with the bottom plate laying against the diff at both the bottom and up near the pinion. That puts a good angle on them to slide over everything better than just the diff itself. Clearance loss is basicly just the thickness of the 1/4" plate.
  22. #22 Re: Goldensd's Build Pics
    Aug 2007
    Paris IL,
    Great lookin front bumper? it's perfect in my opinion! I like the way you have it curve around and it follows the lines nicely!! It looks beefy and I love the low winch mount. Did you build this in the same manner your building the rear?
    98 slate 5.9
    Rolled-rebuilding/upgrading.
  23. #23 Re: Goldensd's Build Pics
    Jul 2005
    Pittsburg, CA
    Quote Originally Posted by just1more19 View Post
    Yes, for the most part. It was quite a bit different, but it is made mostly out of plate
  24. #24 Re: Goldensd's Build Pics
    Jun 2005
    How do you like that Sway Loc front?
    Assuming it's for a TJ as that's all that ORO lists on their site.
    Anthony
  25. #25 Re: Goldensd's Build Pics
    Quote Originally Posted by goldensd View Post
    Nice. I figured it was that way, but I wasn't sure from the pics. Did you find that the triangulation impacted ride quality at all?
