Rock Slider Build
Thread: Rock Slider Build
Page 1 of 2 12 LastLast
Results 1 to 25 of 42
  1. #1 Rock Slider Build
    Senior Member dangerousdave's Avatar
    charlotte
    I started to build my sliders today. Mt basic design is pretty simple. My rocker panel will be guarded by a piece of 71" long 2x4 steel that is a 1/4" thick. I will have 2 frame mount per-side that will be bolted to the frame in the end.
    Today I got the first bracket made. Its pretty solid imo. I still have some grinding to do to it. The brackets will mount in front of the Kevin's frame mounts that my car has. I built the bracket with a piece of 1/4" angle iron that is 3 1/4" x 4 3/4". The arm off of the angle iron is constructed of a piece of 1/4" 2"x2". I set the angle iron into the 2x2 to get below the pinch seam at the rocker panel. The piece of 2x4 will be 8 3/4" away from the frame mount. Which means the end of the rock slider will be 13" away from the frame.
    95 zj, KOR 7" long arm kit, lockrights front and rear, 285/75/16 (32.9x10.3) on rock crawler 16x8x4.5bs, kevins track bar with a home brew conversion, K&N FIPK, and Rubicon Express gen II discos.
    Ready for install... home brew sliders
    http://www.mallcrawlin.com/forum/sho...hlight=sliders
    Dr. Mambo
    http://www.mallcrawlin.com/forum/sho...ighlight=mambo
  2. #2 Re: Rock Slider Build
    steal = to take without permission
    steel = made from iron
  3. #3 Re: Rock Slider Build
    aka Pikachu piku303's Avatar
    georgia
    look heavy but VERY solid. im excited to see them all mounted up.
    97 zj ltd. 5.2, 3.5 RE w/ adj track bar, 32 maxxis buckshots
  4. #4 Re: Rock Slider Build
    charlotte
    crap..... my bad I do that all the time.
    Dr. Mambo
  5. #5 Re: Rock Slider Build
    charlotte
    Quote Originally Posted by piku303 View Post
    I bought 180 lbs of steel. That allowed for me to have some extra for when I start to toy with the idea of bumpers. The 2x4 will be great in the frame for mounts.
    Dr. Mambo
  6. #6 Re: Rock Slider Build
    charlotte
    I got a bit further on the sliders today. I HAD all of the the brackets built and ready to weld to the 2x4 but a miscalculation is making me rebuild the rear 2 brackets.
    Dr. Mambo
  7. #7 Re: Rock Slider Build
    Arizona
    Your welds are cold.
  8. #8 Re: Rock Slider Build
    Feb 2006
    Sac, California
    how is 285mm 10.3"
    The Blue Submarine
    2001 Grand Cherokee (WJ) 4.7
    RIDE!”
  9. #9 Re: Rock Slider Build
    Arizona
    Quote Originally Posted by AgitatedPancake View Post
    how is 285mm 10.3"
    To the square root of 4.
  10. #10 Re: Rock Slider Build
    charlotte
    Quote Originally Posted by chadjans View Post
    Yeah I'm still learning about welding. Thats why i started with a project like this instead of a bumpers. I'm welding at 175 amps with 1/8" 7018. bump up to 200 amps?
    Dr. Mambo
  11. #11 Re: Rock Slider Build
    Arizona
    How thick is your material? Either up the amps or go to a smaller rod.
  12. #12 Re: Rock Slider Build
    charlotte
    all of the material is 1/4". Im working with 1/8" 7018 rods.
    Dr. Mambo
  13. #13 Re: Rock Slider Build
    charlotte
    how should I connect these to the body of the jeep??? bolts or welds?
    Dr. Mambo
  14. #14 Re: Rock Slider Build
    Midlothian Virginia
    weld
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  15. #15 Re: Rock Slider Build
    Senior Member 93ZeeJ's Avatar
    Oct 2007
    Littleton
    Quote Originally Posted by dangerousdave View Post
    if your new to welding... do you think your good enough to do the unibody welding?
    your choice
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
    HP30-truetrac/D44a-Aussie 4.56
    6.5" Long Arms, 35"s
  16. #16 Re: Rock Slider Build
    Senior Member grandmaster's Avatar
    Utah
    welds will distribute the load more evenly along the unibody. But i personally like the bolt on style just in case i have to take them off to fix welds or replace something.
  17. #17 Re: Rock Slider Build
    charlotte
    What i cant weld i know my dad can. He was a pro welder for several years. I was just wondering if yall had found a real advantage to it either way. I mean drilling the frame sucks.
    Dr. Mambo
  18. #18 Re: Rock Slider Build
    georgia
    if you mount weld them to the far front and rear your welding to 1/8 inch not 1/16th inch. shouldn't be an issue.
  19. #19 Re: Rock Slider Build
    Both. I welded on steel plates where mine mount and taped them for grade 8 bolts. This way I get the advantage of weld on distribution and bolt removability.
  20. #20 Re: Rock Slider Build
    Apr 2008
    Cary, NC
    Looks good man
  21. #21 Re: Rock Slider Build
    charlotte
    Quote Originally Posted by jsteves View Post
    This is probably the best way to go. It would be nice to make them removable and on top of all that its easier to weld a small piece of plate instead of a large slider.
    Dr. Mambo
  22. #22 Re: Rock Slider Build
    Senior Member Grand Slam West Planner PassRunnerZJ's Avatar
    Aug 2004
    Grand Junction, Colorado, United States
    If it was me, I would sleeve the uni-frame with weld and bolt, then bolt the sliders to that. Win/Win. That said, it will lower your mounting point some since you already have the mounting brackets built. I'll come back to that in a moment. One thought is to notch the lower section of the sleeves so the sliders are up as high as possible and bolt through the uni-frame sleeve horizontally.
    Now for the part that is going to hang you up. You might concider welding some scrap plate at an angle to the bars that hold the sliders and bracket that mounts to the uni-frame. Try and keep things tucked up and/or avoid sharp angles that will catch things.
    '98 ZJ, 33s and an XJ drivetrain, Iron Rock Offroad 4.5" Critical Path suspension lift, D44i, custom rear bumper w/tire carrier, KOR ZJ Radiator Support
    '95 ZJ - after 208k and the fun gear swapped to the '98, now it gets setup to sell
    '01 WJ, T/C skid, K&N replacement - wife's DD
    '04 Honda Civic - my DD
  23. #23 Re: Rock Slider Build
    Senior Member violatedppl's Avatar
    Aug 2005
    Danville CA
    on the welding question, you must be running at AC machine to be running 175 amps and having you welds being cold like that. and try to have you welds more fluid, those gaps probably have slag under them and are not as strong. just MHO
    08 tundra double cab 5.7 4x4
    I am jeepless at the moment.
    Sold- Stock 03 WJ, 4.7HO. lift coming soon.
    Sold-97 ZJ laredo 4.0, 242 RE BB, 31" BFG MTs, custom rear storage boxs, magnaflow hi flow cat, flow 70 series, 2.5 inch exhaust, jks quicker discos and some other crap
    http://www.cardomain.com/ride/2221028
  24. #24 Re: Rock Slider Build
    charlotte
    thanks for the great ideas guys.... I really cant wait to get these built. It sucks that I have been so busy with school. But in 2 weeks i'll be done with that for a few months.
    Dr. Mambo
  25. #25 Re: Rock Slider Build
    Junior Member MuddyLuxury's Avatar
    Jul 2007
    Fairfax/GMU
    i think somebody else touched on this, but the under side of your L-mount were the bar comes in off the slider, that litte piece of steel is gonna be a boat anchor, it will find ever log and rock you cross, grind it, or weld a cover plate there at an angle so it slides instead of catching.
    and i would sugest you have your dad weld the plates to the unibody, its wafer thin in places and its supper easy to burn a whole
    99 grand V8 242 swap 6.5 LAs
    D44s F+R, gas tank tuck, rear tire carrier and home built roof rack on the way
