Thread: WJ fender trimming, Pics? Methods?
Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
  1. #26 Re: WJ fender trimming, Pics? Methods?
    I'm at 6" of lift with my fenders cut to hell and I'm happy with how it works, I would say on a WJ 4-5" of lift would be min for 35"s without absurb bumpstops.
  2. #27 Re: WJ fender trimming, Pics? Methods?
    Mar 2009
    WINNIPEG
    Alright thanks.
  3. #28 Re: WJ fender trimming, Pics? Methods?
    Nov 2008
    RI
    Hey Pitch you Wj looks sick, do you have a build thread any where online?
  4. #29 Re: WJ fender trimming, Pics? Methods?
    Mar 2005
    Flagstaff, Zona
    Quote Originally Posted by Gb02WJ View Post
    Thanks. No build threads here.
    Sold: 01 WJ, 93 YJ, 86 CJ7
  5. #30 Re: WJ fender trimming, Pics? Methods?
    Feb 2009
    Oregon
    arlo are you saying that 4 inch bumpstops with 6 inch lift requires little trimmiing?
  6. #31 Re: WJ fender trimming, Pics? Methods?
    Mar 2009
    Horn Lake, Ms.
    So does anyone think 33's with a 4" lift 15x8 rims with 4" bs be ok? 02 WJ 4.0 stock gears, discos, arb front bumper. Just a little trimming? Will I really be pushing the axles to there breaking point with 33's? or just go 31 or 32??? Thanks
  7. #32 Re: WJ fender trimming, Pics? Methods?
    Jan 2008
    Basalt, CO
    You will want to regear with 33s on the 4.0. Just don't have a heavy right foot and carry spare shafts.
    Brian
  8. #33 Re: WJ fender trimming, Pics? Methods?
    Boulder, CO
    Quote Originally Posted by WJ4x4 View Post
    I ran 33's on all adjustable SA's with 4" of lift, 16x7" rims (285/75-16 TrXus MT's), 4.56 gears, D30, D44a for about 2 years. Only trimming was on the bumpers and inside of the wheel well.
    -Ryan
  9. #34 Re: WJ fender trimming, Pics? Methods?
    Triming WJ fender method: in the Rustic Inn parking lot, 50 foot extension cord, harbor freight grinder, pre antique moments and three Fat Tires.
  10. #35 Re: WJ fender trimming, Pics? Methods?
    Mar 2010
    Knoxville, TN
    bringing this back from the dead a little bit but i just finished up the rear on mine and i think it turned out pretty good. Heres some more pics for anyone planning on doing this...sorry if the pics are too big
  11. #36 Re: WJ fender trimming, Pics? Methods?
    Shoulda popped the dent out while you had the skins separated. Good work though.
    2004 Ford Lightning
  12. #37 Re: WJ fender trimming, Pics? Methods?
    Member Rangerwj's Avatar
    May 2008
    Golden, Colorado, United States
    how did u reattach the inner fender after you cut. i have seen expanding foam, pop rivets, and tack welds and was just curious what u did.
    2000 WJ. some lift and mods. deathwobble.
    CSM How High Off Road Club
  13. #38 Re: WJ fender trimming, Pics? Methods?
    Mar 2010
    Knoxville, TN
    thanks Jeeptech, yeah i thought about messing with the dent but my whole driver's side is pretty thrashed from a run in with a tree a while back so i figured I'd just leave it.
    As for the connecting the fenders, I used pliers to start bending the inner fender to where i wanted the final line to be and then hammered the outer fender in over it. Then I hit it with a hammer from the inside of the wheel well to bend the edges over one another.
    the paint you see on there is dupli-color spray on truck bed coating...it probably wouldnt be very good for an actual truck bed but for my purposes it came out great
    Hopefully that makes sense...its kinda hard to explain know that im typing it but the actual process is really easy.....just lots of BFH to make it smooth
  14. #39 Re: WJ fender trimming, Pics? Methods?
    PA
    you should weld that seam or use body panel adhesive. folding it over won't hold.
  15. #40 Re: WJ fender trimming, Pics? Methods?
    Exactly what rat said. I drilled holes for plug welds and used seam sealer to completely seal it up.
    2004 Ford Lightning
  16. #41 Re: WJ fender trimming, Pics? Methods?
    Mar 2010
    Knoxville, TN
    yeah i havent decided if im gonna mess with welding it or not it but ive already got some seam sealer from NAPA im gonna hit it with that will hopefully get the job done
  17. #42 Re: WJ fender trimming, Pics? Methods?
    Nov 2010
    Rhode Island
    my buddy and i were working on his WJ and we took a few inches off. we also had to move the windshield washer reservoir because there was barely any plastic between it and the tire, and we were worried about hitting it and damage. anyone else had to do this?
  18. #43 Re: WJ fender trimming, Pics? Methods?
    Mar 2010
    Knoxville, TN
    yes, thats been done about a million times. I did what most people do and get a ZJ washer bottle and mount it in the engine bay. The WJ pumps and low fluid level sensor transfer right over. I have the 4.0 with a small K&N intake so i have plenty of room for it but if you have the 4.7 you may have to get a little creative\
    the search button is your friend!
    http://www.mallcrawlin.com/forum/sho...=washer+bottle
  19. #44 Re: WJ fender trimming, Pics? Methods?
    I have a zj bottle pump and sensor fo sale if anybody wants one. $40 sound fair??
    2004 Ford Lightning
  20. #45 Re: WJ fender trimming, Pics? Methods?
    Boulder, CO
    $40 seems expensive to me IMHO...especially if you don't need the pumps. I think I paid $20 (shipped) for mine from some guy parting out his ZJ.
    Depending on what year ZJ it comes from, the tank will be a different size. And depending on what year WJ you have, you can mount it in a couple different locations.
    -Ryan
  21. #46 Re: WJ fender trimming, Pics? Methods?
    Hrm. Well its from a 97 ZJ and it is rectangular. For $20 its not really worth my time to sell esp since shiping will be $5-9 depending. So $30 shipped sounds good to me if anyone wants it.
    2004 Ford Lightning
  22. #47 Re: WJ fender trimming, Pics? Methods?
    Junior Member wildman_wilds's Avatar
    Mar 2009
    Minnesota
    I know this thread is old, but I went to a junk yard and paid $9.00 for a complete zj wind shield fluid resivor. Cut my front fender to the crease line. A 4" lift with long arms. Im currently running 255/75R17. Gonna stuff 33's under it later and I will not cut the rear fender, but instead I will bump stop the rear just enough so the tires are approximately 1/2" from the fender.
    http://i381.photobucket.com/albums/o...0425161642.jpg
    http://i381.photobucket.com/albums/o...0425132303.jpg
    http://i381.photobucket.com/albums/o...0425082205.jpg
    http://i381.photobucket.com/albums/o...0425093928.jpg
    http://i381.photobucket.com/albums/o...0425184537.jpg
    http://i381.photobucket.com/albums/o...0425135606.jpg
    http://i381.photobucket.com/albums/o...0331154155.jpg
  23. #48 Re: WJ fender trimming, Pics? Methods?
    Well done, looks nice!
  24. #49 Re: WJ fender trimming, Pics? Methods?
    Looks nice. You'll be running a lot of bumpstop with 33's and no trimming in the rear. Are you longarmed f&r?
    2004 Ford Lightning
