Most of us on here have deviated quite far from the OEM parts on our jeeps and other 4x4's. As many of you are aware, going to a parts store looking for specific parts can sometimes be a chore and an exercise in patience. So with that in mind I figure a sticky topic for "Common part numbers" is long overdue.
If you have any part numbers recorded that will make life easier for a fellow wheeler then please post them up. It will make a big difference for the next trip to the counter.
Let's keep this clean and to the point to make it easy to search. No need to post prices either... they tend to change a lot. Use something like this when you post:
Part name / description
Store and/or brand and part number
Ford 8.8 Flange adapter (1310 u-joint) - d-shaft with 1310 (e.g. oem jeep) u-joint to 8.8 flange yoke
Spicer Part # 2-2-1379
Ford 8.8 Flange adapter (1330 u-joint) - d-shaft with 1330 (94-95 YJ, etc.) u-joint to 8.8 flange yoke
Spicer Part # 2-2-1399
Ford Part # E9TZ 4782 B (Yoke - Drive)
1330 to 1310 Conversion U-joint (Used for Ford 8.8 flange (1330 joint) to Jeep Drive Shaft(1310 joint))
Neapco part # 1-0134.
Spicer part # 5-134X
Extended front brake lines to fit Jeep YJ/XJ/TJ, etc. ~25" long
Auto Sense Part # BH177760
Wagner Part # 116846
Midas Part # 2201
Auto Spec Part # 86043
Bendix Part # 77760
ZJ / TJ Control arm bushings
NAPA Part Numbers
Upper Bushings - NCP2671450
Lower bushings - NCP2673409
Ford 8.8 STEEL differential cover
Cabot Ford / Part # F4TZ-4033-A
Diffs:
D30:
Carrier cone LM501349
Carrier cup LM501314
Carrier cup ARB LM501310
Pinion tail cone M86649
Pinion tail cup M86610
Pinion head cone HM88649
Pinion head cup HM88610
Pinion Oil seal 15788
D44 (steel)
Carrier cone 25590 (Standard 44)
Carrier cup 25523 (Standard 44)
Carrier cone 104949 (Super 44)
Carrier cup 104912 (Super 44)
Carrier cup and cone ARB LM104949/LM104912
Pinion head cone 31594
Pinion head cup 31520
Pinion tail cone 02872
Pinion tail cup 02820
Pinion oil seal 15788
Rear wheel bearing BCA A10 (Federal Mogul-incl. cup/cone/collar)
Rear wheel bearing seal 9912 (National)
ZJ
Steering:
Tie Rod NAPA #269-6085
TRE NAPA #269-2788
Tie Rod Adjusting sleeve NAPA #269-1134
Brakes:
Rear disk calipers Carquest #18-4399 / 18-4398
Park brake shoes for rear disks Carquest # BS701
D300
Input shaft bearing 6209
Input shaft oil seal 471869
Rear output shaft front bearing cone 25880
Rear output shaft front bearing cup 25821
Rear output shaft rear bearing cone 15117
Rear output shaft rear bearing cup 15245
Rear output shaft oil seal 711552
Front output shaft front bearing cone M86649
Front output shaft front bearing cup M86610
Front output shaft rear bearing cone M86649
Front output shaft rear bearing cup M86610
Front output shaft oil seal 711552
Input shaft rear pilot bearing 1612
Shift rail oil seal 2469
Intermediate shaft needle bearings 13367
Intermediate shaft oil seal 470009
AA D300 32 Spline tailshaft kit:
Rear output shaft front bearing cone 26885
Rear output shaft front bearing cup 26822
Rear output shaft rear bearing complete 30207M
Rear output shaft oil seal 18817
14 bolt FF Timken bearing part numbers:
Inner Cone: 387A
Inner Cup: 382A
Outer Cone: LM104949
Outer Cup: LM104911
1310 to 1350 conversion u-joint
Spicer: 5-460X
Neapco: 3-3140
Napa: 348
Rockford: K460
1330 to 1350 conversion u-joint
Spicer: 5-648X
Rockford: K648
1 ton chevy steering swap tie rod end P/Ns
the tie rod uses
ES2233L at the passenger side knuckle(
ES2234R at the drivers side knuckle
the drag link uses
ES2234R at the tie rod end
ES2027L (high misalignment) at the pitman arm
if you are doing full crossover steering use ES2026R(high misalignment) in place of ES2234R at the tie rod
all these part numbers are the same at just about any parts place
