Time for something new - Page 2
Thread: Time for something new
Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
  1. #26 Re: Dr. Mambo
    aka Pikachu piku303's Avatar
    georgia
    come on! i can flex like that on short arms with my sway bars connected. i want to see that baby really flexed out.
    Quote Originally Posted by dangerousdave View Post
    To fix the lift difference I had for the front and rear I added a spacer to the rear of the jeep. It brought the nose of the jeep down and seems to have a positive effect on gas. It might be minor but anything is good.
    I took the jeep up to URE on Friday and had a pretty good time. It was a little muddy.... well very muddy. I decided not to fool with kodak rock due to the mud. I did have a close call but all is well. It wasnt that bad it just the jeep just wanted to slide sideways down the hill which would not have ended well. Here are a few pictures of the days events.
    And even a poser shot.
    On a side note i bent my sway bar mount on the axle with my drag link. So i need to go beat it back into place. It made for a fun drive home.
    97 zj ltd. 5.2, 3.5 RE w/ adj track bar, 32 maxxis buckshots
  2. #27 Re: Dr. Mambo
    charlotte
    Quote Originally Posted by piku303 View Post
    I know... I hope to get a better flex shot here in the next day or so. Im still getting a feel for the lift and I didn't have a spotter that knew any thing. I had a graphic artist with a camera....
    Dr. Mambo
  3. #28 Re: Dr. Mambo
    charlotte
    The jeep is about to get all kinds of TLC. My sliders are in the last stages of construction (stripping and painting). I have secured a dana 44a. It does not have a locker but I think i can get one. Im also going to see puma on sat and purchase his t case skid and his gas tank skid.
    Dr. Mambo
  4. #29 Re: Dr. Mambo
    charlotte
    I was cruising around on craigslist the other day when I came across this....(click the image)
    It is a rebuilt AMC 242 out of a YJ. This motor only has 20,000 miles on it and its going to replace mine that has 241k on it. Im pretty stoked because my factory motor has been very good to me. I have dogged it pretty hard. I plan on resealing my transmisson and t-case as i do this install.
    During this past week I also decied to paint my cladding. I went with flat black to blend into the sliders that I am going to install as soon as I get the new engine in.
    Dr. Mambo
  5. #30 Re: Dr. Mambo
    charlotte
    I got the front locker installed in the jeep. This is great because it means I am in good shape for a URE trip this weekend. The Install can be seen here:
    http://www.mallcrawlin.com/forum/showthread.php?t=16727
    Edit: I was in good shape for URE except the locker had issues and needed to go to the shop. See the install for more details.
    Dr. Mambo
  6. #31 Re: Dr. Mambo
    charlotte
    After a long fight with the locker and both 4x4 shops being baffled by it I finally got a lockright in the jeep that is working great. I took it out and wheeled it some today. It did a great job, even though I still managed to get the jeep stuck in some mud.
    I got to get a poser shot for the jeep club that Im sorta running right now. Its kinda cool so I figured I would show it off. The jk just got the lift install about 2 weeks ago. Its a pretty sweet ride. His sway bars are far superior to ours. I would love to install a set in my jeep but that looks like it would cost a small fortune. I know its not flexed much but its the best you can do here in the city.
    Dr. Mambo
  7. #32 Re: Dr. Mambo
    2nd floor Yuma, AZ motel
    I've flexed on that same rock!
  8. #33 Re: Dr. Mambo
    charlotte
    lol yeah.... its one of the few there that you can and not clog up a trail. It really sucks about your jeep.
    Dr. Mambo
  9. #34 Re: Dr. Mambo
    charlotte
    I started working on the motor I bought for the jeep the other day. It looks like it is going to be a easy install. Im going to put another AMC 242 (4.0) back into it since the on I have now has been a champ for me since I got the jeep. The engine came with everything: wiring harness, throttle body, alt, powersteering pump. THe engine was just recently rebuilt as well so Im hoping to get a ton of use out of it. There was no sludge, grime or anything in the bottom of the oil pan after I removed it. When its all said and done I will have a engine with 20k on it.
    As of on I have changed the water pump, valve cover gasket, oil pan gasket. I'm going to take the alternator and every thing else off of my engine since most of that stuff is pretty new. Im thinking I will be doing the swap this coming weekend. During this I am going to replace the seals on the tcase and tranny.
    I am worried about the chain hoist being tall enough to pull the motor out of my jeep. Right now the best thing i can think to do is put on the 2 stock front tires and remove the coil springs. It will make it hard to work under though.
    Dr. Mambo
  10. #35 Re: Dr. Mambo
    charlotte
    I was looking around on craigslist today and i found a sweet deal on a dana 44. Its out of a widetrack jeep what i dunno. So no im on the look for a rear. I'm thinking a 60 or a 9" i want something of the same weight and width of the 44. Right now th axle is set up with 3:51 gears. Its missing a hub and a rotor but i only paid $50 for it. I really cant complain to much about that. The guy threw in some 60 parts too. Hell of a guy. I'll post up some pictures when I get a chance to.
    Dr. Mambo
  11. #36 Re: Dr. Mambo
    charlotte
    Today was kinda fun I got to play with the 44 that Im going to put in my jeep. Its completely stripped except for the ball joints. So Im going to start the cleaning and welding part of the build to prep it to go under the jeep. Once I get all of this done I will start to gear the axle.
    Some of the stuff was a pita to get off of the axle. WD-40 was my friend.
    Dr. Mambo
  12. #37 Re: Dr. Mambo getting a new set of axles
    hope you got a sandblaster...
    97 V8 zj.
    03 Cobra with horsepowers
  13. #38 Re: Dr. Mambo getting a new set of axles
    charlotte
    No sandblaster for me. I got to do the strip by hand with a big grinder and a twisted wire wheel. Its done being cleaned and is waiting on gears and brackets.
    Dr. Mambo
  14. #39 Re: Dr. Mambo getting a new set of axles
    Van Wyck, SC
    Looks good, have fun w/ that front axle. Take your time and do it right.
    Is that a WHS Lacrosse sticker?
  15. #40 Re: Dr. Mambo getting a new set of axles
    charlotte
    Yeah im the head jv coach there. I really like the school and the kids are great. I take it your from the area.
    Dr. Mambo
  16. #41 Re: Dr. Mambo getting a new set of axles
    Van Wyck, SC
    Yup, born and raised in Weddington. Graduated in '02.
  17. #42 Re: Dr. Mambo getting a new set of axles
    charlotte
    Nice. im sure the school has changed alot since you were there. Theres another new school opening out there this year. That makes 2 in 2 years.
    Dr. Mambo
  18. #43 Re: Dr. Mambo getting a new set of axles
    charlotte
    I haven't got to do much with the jeep or the 44 in awhile. I did install a new header and a replacement steering box this weekend. It sound so much better. I went with a off brand header so im curious to see how it all works out. Im hoping that its not a piece. The install was not bad at all except for the bottom bolts on the intake manifold. Ill do it all again when the weather is warmer and i can do my engine swap.
    Dr. Mambo
  19. #44 Re: Dr. Mambo getting a new set of axles
    charlotte
    Well its a sad day.....
    I just got a 99wj with a new 4.7 in it. The Zj has been getting worse and worse over the past few months so it was time to do something. I will be putting the lift up for sale before long.
    Dr. Mambo
