Thread: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
Results 26 to 50 of 69
  1. #26 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Quote Originally Posted by nathaniel View Post
    I'm in as well. Name some of the harder trails in the area cause I dont know of any.
    We drove about 1/3 of Smasher Canyon, and it was pretty chewed up from recent rain. I doubt it's going to change substantially in the next few months. We got Eric pinched into a spot that required a winch and some digging, and the rest of us all hit our RockSliderz and skid plates at least several times. I'd rate it as a solid 3.5+ or a 4.0. The rest of it was pretty much like the third of it that we ran. Typical AZ trail...in the bottom of a wash, short, plenty of "outs", but pretty gnarly in the wash.
    We also WALKED Brutal Canyon. I would say it's every bit as difficult as Predator or Upper Terminator...and maybe more so. That one is a good 4.5+, I think. Again, we didn't run it, but we walked about 2/3 of it. As you know, I'm running 37" tires, and am locked front and rear, and I can tell right now it's going to be an ALL DAY event for anyone with less than a buggy...and maybe even then.
    Those are the two tough ones we saw. Not sure if others exist too, but Eric might.
    Kevin
    602-841-3355
    Phoenix, AZ
    www.KevinsOffroad.com
  2. #27 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Quote Originally Posted by KevinF View Post
    Kevin
    BTW, since I'm leading this trail, I'm going to stipulate that you need to have either a buggy or a winch to do this trail. If you have neither and you are hell-bent on doing it, e-mail me and we'll talk about your level of driving skill and setup, because this is not a trail that you/we want to end up pulling broken Jeeps out of all day , lol. (Particularly if you don't have a tow rig).
    Kevin
    602-841-3355
    Phoenix, AZ
  3. #28 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Senior Member nathaniel's Avatar
    Buckeye, AZ
    Kevin
    Dude you are quoteing yourself.I have a winch and dont care to much about the body and will probably trailer my rig. If you were talking to me.Nathaniel
    hp30, 8.8, long arms, chevy steering, 6" lift, 35 mtrs, 231, locked SOLD
  4. #29 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Mar 2005
    AZ
    I wish i could go! My ZJ has been out of commision since just after GSSW 05. Hmmmm October 19th.
    94 ZJ 4.0L, 2 1/2" lift using ACOS front, XJ coils rear, 33" Xterrain's, taller than stock rockers,DD
  5. #30 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Aug 2007
    Sandy eggo
    Dang. Don't think my '02 2x will do...Anyone know where I can buy a 2004 4x4 Wj Limited without dual climate control?
    Which drive system is "best" for So. Cal/Az. off roading??
  6. #31 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Dude you are quoteing yourself.Nathaniel
    Nathaniel
    .Nathaniel
    LOL. I was just thinking to myself, "Damn...what I had to say was so interesting, that I need to quote it again".
    I wasn't referring only to you, Nathaniel, with respect to the winch...that was kind of a generalized stipulation to everyone who wanted to run it. Anyone is welcome to walk and watch, if you want to. It's pretty gnarly. It's not necessarily a body-damage type of trail unless you tip it over...it's just REALLY chopped up, and no real "lines" for placing your tires, so you just have to have lots of ground clearance and a winch to get yourself out of a spot, when it happens.
    Kevin
    602-841-3355
    Phoenix, AZ
  7. #32 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Mar 2005
    Flagstaff, Zona
    "you just have to have lots of ground clearance and a winch to get yourself out of a spot, when it happens"
    Do you mean a spot like this?
    Sold: 01 WJ, 93 YJ, 86 CJ7
  8. #33 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Mar 2005
    Flagstaff, Zona
    Quote Originally Posted by Cammo View Post
    Either transfer case in the WJ will work for the trails. But depending on what trails you want to run, what is loaded in your diff's will matter a lot more.
    Personally, I prefer a 242 (Select-trac) over the 247 (Quadra-whatever).
  9. #34 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Quote Originally Posted by Pitch View Post
    You are welcome.
  10. #35 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    recon zj's Avatar
    Surf City, USA
    I wasn't referring only to you, Nathaniel, with respect to the winch...that was kind of a generalized stipulation to everyone who wanted to run it. Anyone is welcome to walk and watch, if you want to. It's pretty gnarly. It's not necessarily a body-damage type of trail unless you tip it over...it's just REALLY chopped up, and no real "lines" for placing your tires, so you just have to have lots of ground clearance and a winch to get yourself out of a spot, when it happens.Kevin
    Hmmm, well, I've got the winch covered, but the ground clearance issue definitely rules me out on that one!
    Vacation is on the books, so I'm in this year.
  11. #36 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Aug 2007
    Phoenix, AZ
    hey Eric, it's Bobby the guy from borken arrow. You know you backed into me, LOL. are a bunch of guys camping out for this or is it just an on your own kinda thing?
  12. #37 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Mar 2005
    Flagstaff, Zona
    Quote Originally Posted by Steelblue_WJ View Post
    Yeah, sorry about that Bobby. Are the doors closing OK after the crack?
    We have talked about camping out (see the GSSW lodging thread), but nothing is set in stone yet. Not sure if I will be camping, staying at home, or at the White House Inn yet. I am sure people will be posting up their preferences as the date draws near.
  13. #38 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Jun 2007
    Dragoon AZ.
    We are planing on taking our moterhome up there some place close, Draging our ZJ behind, but don't know just where yet... thinking about the 18th just waiting for more details...MITCH...
    98 ZJ 5.2 - 35/12.5 Kevlar MT/Rs - JKS (Modified) Quicker-Discos - www.KevinsOffRoad.com - LP1 Sliderz/(SOLD*X-Member Skid*& 33's SOLD) /Light bar w/Remote lights - 2.25 + RE 3.5 Lift - Cobra Ultra III 40 /Fire stick - Bomb - XJ Front DS - 10K w/wired & wireless - Aussie - Garmin - Flex-a-lite - www.ironrockoffroad.com - Auburn E-locker - A few dents
    & a GREAT DANE hanging out the window... (GREAT DANE Died... New one will fill window soon...)
    ..."GOT GAS"???...Let's "GO"...M... (EVIL ZJ)
  14. #39 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Jul 2007
    Lake Powell, Arizona
    Damm I`ve been looking at the previous years Grand Slam pictures. You guys are running some serious equipment I`m thinking I got some upgrading to do before Oct. Lets see.....rocker armor...beefier tie rod setup...bigger shoes....
    94 ZJ 4.0, select-trac, ARB locker, 3" OME lift w/ACOS, RE track bar, ARB front bumper w/Milemarker winch,KOR rear bumper, Engine mods, and lots of sheetmetal underneath. Not a hardcore rock crawler, but a dam fine camp wagon.
  15. #40 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    No place like mountains Lifetime Supporter InIt4TheFun's Avatar
    Sep 2007
    CO Springs
    Never been to a GS event and would love to take part in the event.
    Will be in the area and find it hard to pass up.
    Just don't know how it works. Do I just show up or do I need to register.
    Any info appreciated and look forward to it.
    Thanks in advance,
    Will
    "In almost ANY situation, or dealing with any controversial issue, the two extreme solutions are almost always never correct, and the best course of action lies somewhere in between." -J B
    "I'd piss on a spark plug if I thought it'd do any good!" - General Beringer
  16. #41 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Lakewood, Co.
    Most every thing you need to know is right here. http://gssw.mallcrawlin.com/
    Also subsrcibe to a few of the threads to keep up with the latest & keep an eye on the whole GSSW forum.
    Oh, and welcome to the board noobie!
  17. #42 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Sep 2007
    CO Springs
    Quote Originally Posted by Colorado 5.9 View Post
    Thanks for the link!!!
    And as 4 the welcome
    You going to the event? Hate to be the only CO guy!!
  18. #43 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Lakewood, Co.
    Can't commit 100% yet but as time get's closer we can all talk about a caravan maybe. There are are 2 others that might be going also.
    i have made reservations at La Vista motel in north Sedona.
    http://www.easy-finder.com/brochures/lavista/index.htm
    We talked about it on the lodging thread.
  19. #44 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Jul 2007
    Phoenix
    I might have to withdraw me & my Heep
    Doc wants to cut me again 2nd time 5 months the only good thing is off work for another 6 weeks
  20. #45 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Jun 2007
    Dragoon AZ.
    Any thing new ??? Details/Info ???...M...
  21. #46 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Sep 2007
    CO Springs
    Quote Originally Posted by Varkyl View Post
    I would say "I am in" but it is too close to the wife's due date. Otherwise we would be all over this. We have been waiting for GSSW since we missed last year's.
    Congrats!!
    http://www.youtube.com/watch?v=Ew8VbvZgX5Y
  22. #47 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Senior Member tywilson88's Avatar
    i think im going to be able to make it. not posotive yet. but there is a good chance
    Quote Originally Posted by Four Play View Post
    I'll probably go to Hell for that but fawk it, I'll upgrade my 1st class ticket and go for another pack of peanuts... cremation cost are on the rise anyway.
  23. #48 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Jul 2007
    Well it looks like we are going to join you in Sedona. Me and the girls are cruising down from Page Friday pm and will meet up with you all Sat. morning. Man its hard to find a reasonably priced place in Sedona
    Doing a tech day this weekend and installing rock rails. May as well do a tune up and fluids before it gets cold up here. Looking forward to this trip. See ya then
  24. #49 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    May 2006
    Golden, Colorado
    Unless something unexpected comes up my wife and I plan to attend if there is still time to register. If it is not too late how do I register as it appears that portion of the website is not operational. Do we need to sign up for trails or is that adhoc in the morning? Lastly, who do I contact about making a contribution to the raffle on Saturday night?
    Russ
    ________
    2005 WK Limited with Hemi, 4-inch Superlift suspension, 33-in BFG ATs, custom roof-rack insert, brush/light bar, F/R skid plates and rock sliders--all by 4xGuard, CB, and KC lights.
    2001 WJ Limited with 4.7, 2-inch BB, 32-in BFG ATs, custom rock sliders, Mopar brush guard, CB and KC lights
  25. #50 Re: Announcement: 4th Annual Grand Slam Southwest! Friday, October 19, 2007
    Phoenix, AZ
    Quote Originally Posted by Colo.kid View Post
    No formal registration for the event this year. We will have a liability waiver for drivers to sign once before joining the event. We will evaluate the trails based on driver interest at the drivers meetings.
    That would be me
    David.
    2001 WJ
