Project Hookup - Now with Solar - Page 11
Thread: Project Hookup - Now with Solar
Page 11 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 251 to 275 of 416
  1. #251 Re: Project Hookup
    Quote Originally Posted by jborushko View Post
    just out of curiosity why did you dime out for diamond plate just to cover it with carpet? why not a cheaper metal? you said "bling" but you covered your bling!
    Its still a dual purpose rig. I carry tons of stuff in there from chopped wood to glass bowls filled with wife's potato salad. Most times I will leave it out but I would like the option to still have a regular floor for hauling family junk...
    Consider it my bling volume...
    Will
  2. #252 Re: Project Hookup
    Mar 2008
    stationed at tacoma wa
    ah! word
    -e-boner
  3. #253 Re: Project Hookup
    Nicely done sir!
    2004 Ford Lightning
  4. #254 Re: Project Hookup
    Clean work man, I like it! One of my favorite WJ mods period. I still hit my tank from time to time, and I went up between 7-8" when I did it, I don't even want to think about how it would look if I hadn't raised it.
  5. #255 Re: Project Hookup
    Thanks man. Actually, jes who welded up my skid suggested if i didnt have the subwoffer to run the hoses like you had it. I just got an oem hitch and I plan on trimming up the plastic bumper up 8" an install the oem hitch to better the departure angle.
    Will
  6. #256 Re: Project Hookup
    You can mod the hitch for more clearance also. I did it in my build.
    2004 Ford Lightning
  7. #257 Re: Project Hookup
    Its pretty simple. Just cut the reciever off and mark out the area to recess it. Then weld somethong across the cut area before you cut so your mounting holes will line up when you are done. I also added a plate along the top to spread the load out. HTH.
    Will
  8. #258 Re: Project Hookup
    Jan 2009
    Lufkin, TX
    we need updates!
    No longer a JeepTech01 fan.
    Just boobs.
    And biggoofy.
  9. #259 Re: Project Hookup
    Ask and yee shall receive...
    I have been working a lot both at home and at work, jeep sadly is coming 3rd now. My upper rubber joints on the IRO arm failed, it was the passenger side at first and then the driver died not short after. I noticed it started to look a little torn then later that week I was able to push the jeep from side to side in the back about 2" in each direction.
    IRO warrantied them and got them out for free and in a hurry, got them pressed in and back on its wheels. Josh your the man. HANDS DOWN THE BEST CUSTOMER SERVICE IN THE BUSINESS!!!!!!
    Took a pic when I noticed it.
    Will
  10. #260 Re: Project Hookup
    UPDATE 2
    Bought the KOR WJ skid a month ago and went to install it and had a couple issues. If you have the factory Overland skid with the nutserts it will take a little finess to get it to line up but that wasnt the main issue. Just bummed they dragged me along when they could have told me its going to be a month + and I would have gone elsewhere sooner. (Ultimately its not their fault they only planned for factory configuration)
    If you couldn't tell by now i have the IRO setup....
    Anyhow the LCA bracket gets sandwhiched between the factory crossmember and frame which drops everything by 1/4".
    For the factory skid it was fine as it had pleanty of room between it and the tcase due to the curves and holes in the stamped sheet metal. Well this 1/4" flat steel gets close to the bottom of the tcase but with the 1/4 drop it is all up in the case.
    Will
  11. #261 Re: Project Hookup
    So I promptly contacted KOR to get a 1/4" spacer with the matching staggered hole pattern to fill the gap and drop the skid to clear the tcase. Anyhow a week turned to two weeks. Two weeks turned to 3. I emailed but they are busy with projects and gave me the answer it was out at lazer to get cut. I got tired of kicking the steel plate everytime I went onto my patio and just wanted to get it installed so I found a local machine shop who sent me to a dude who they give work to. Cool guy, had some aluminum 1/4" that was perfect, dropped off the skid so he could drill to match, and was done in 2 days.
    So there is a L bracket that bolts to the frame with some self tapping bolts this has 5 elongated holes to match up the the skid which allows you to pull the skid without having to pull the frame bracket off every time. I just had to buy five 2" bolts to be long enough to go through the spacer.
    And now it has 1/4" between skid and tcase. And that skid aint moving!
    I had planned to go wheeling up in southshore this weekend but w/o a skid I didnt want to test my luck and I also am starting a new job on monday so didnt want to call in being stuck in Tahoe on day one.
    Will
  12. #262 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Jan 2009
    Lufkin, TX
    yeah that could be bad, anywho i like the way this jeep is goin, how do you like the IROR kit, im torn between it and the clayton kit.
    Just boobs.
    And biggoofy.
  13. #263 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Quote Originally Posted by cowboy63b View Post
    I am all for my IRO, the have Killer products and some of the best service I have had in ANY business I have dealt with in my life.
    If you can weld go for the Claytons if your like me and only have a carport and no friends that weld it was more cost effective to do the IRO.
    I just didnt have the funds to buy the kit then pay for the money to have someone weld it on, but I am happy and have no regrets.
    Will
  14. #264 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    I know hindsight is 2020 and outside lookin in and all that crap but why not just put a 1/4" spacer under the trans mount to move the case back up a bit?
    2004 Ford Lightning
  15. #265 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    That would have been a good idea. Would have taken a bit more prep work. I dropped off the skid for him to match the hole pattern, wouldn't have been able to do that with the cross member as I have to drive the rig to daycare and work every day.
    Will
  16. #266 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    How disappointed would your teacher be if you missed a day of daycare.. honestly.
    2004 Ford Lightning
  17. #267 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Man I wish I could go to day care, snack time, nap time, plus arts and crafts. Fuck work.
    Will
  18. #268 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Member Hockinaloogie's Avatar
    Oct 2008
    North Alabama
    Dont forget.. You can get away with Whining...
    .... 98' 5.2 LiMiTEd ....
    I am not stupid, just very retarded....
  19. #269 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Jan 2009
    Lufkin, TX
    and shitting your pants, ahhh fun times.
    Just boobs.
    And biggoofy.
  20. #270 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Beaumont, Texas
    One of my favorite Wj's
  21. #271 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Damnit you beat me to it. Dont forget getting someone else to wipe your ass for ya.
    2004 Ford Lightning
  22. #272 Re: Project Hookup *KOR WJ TCase Skid* 8/14
    Oct 2008
    North Alabama
    Ohh yeah and pissing on the sides of the school building making artistic animals.. Wait a min, I still do that...
  23. #273 Re: Project Hookup IRO T-Bar Drop & Steering Upgrade
    So I am tired of the stupid bump steer that I got from flipping the DL to the top of the knuckle. As this is my DD I need it to be solid and to have the wife be able to drive it without bitching would be nice too.
    Here is what I got. Its a IRO TB 3" drop. New DL ends and a 1" PA drop.
    I figure that by raising the DL at the knuckle side by 1-2" it has killed the geomitry. By dropping the TB 3" on the other side it brings it closer to parallel rather than an X (over exaggerating of course) But it probably is 1" too much so I got the PA drop by 1".
    I got the new TRE as the ones I have are sloppy and offer no resistance when grabbing the TR.
    I plan on doing it in pieces (TB then PA then TRE) and get measurements for before and after each step, photos etc.. If you guys have any questions or suggestions please shoot. And comes across and bolts to the flap behind the spring below the frame. (Photo curtesy of Josh at IRO) I was worried that the bolts may come into contact with the JKS disco but it looks like its far enough over.
    Will
  24. #274 Re: Project Hookup IRO T-Bar Drop & Steering Correction
    Looks like it will be a nice setup. Good idea doing it in pieces. Hell you may not even need all of it.
    2004 Ford Lightning
  25. #275 Re: Project Hookup IRO T-Bar Drop & Steering Correction
    My thoughts exactly. Plus I'll be able to narrow down quirks in steering as I do it and if things come back then I will know where to look. I work Sat but have sun & mon off so I should be able to get it done this weekend.
    Will
