SOLITUDE - Page 3
Thread: SOLITUDE
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 94
  1. #51 Re: SOLITUDE
    Senior Member SOLITUDE's Avatar
    Brunswick, GA 31523
    You know that old saying, "Measure twice, cut once." Yeah well, I tend to mess up regardless of how many times I measure.... I ended up welding on the 9" UCA Truss not even close to even. I don't know what possessed me, but I welded it directly over the pumpkin. Needless-to-say, the pumpkin is not centered on the axle. *SLAPS SELF IN FACE*. So I had to backtrack and grind off the truss so I could weld on the Spring perches. I'm gonna try and finish up all the brackets on the 9" tomorrow. Oh.... and this is my workspace.
    Perches are welded on at 13*. I'm trying to eliminate any kind of vibes.
    Maxx, this is for you.
    I've officially run out of space in my apartment. I have boxes everywhere. So much in fact that I don't even have the space to store my suspension pieces. It's over at my girlfriends place in her basement closet.
    1993 Jeep ZJ V8 5.2
    HP44/9", 4.88's, Detroit, OX, Clayton's, ALL IN PROGRESS
    LINK TO MY PAGE
  2. #52 Re: SOLITUDE
    Senior Member tywilson88's Avatar
    that is alot of stuff... i wish i had that cash... and damn that is one hell of a stereo
    Quote Originally Posted by Four Play View Post
    I'll probably go to Hell for that but fawk it, I'll upgrade my 1st class ticket and go for another pack of peanuts... cremation cost are on the rise anyway.
  3. #53 Re: SOLITUDE
    Brunswick, GA 31523
    Pulled my front doors off to try and replace the hinge pins, but, I don't have a small enough angle grinding disc to fit in there to cut the old pin out.... hmmmm......
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  4. #54 Re: SOLITUDE
    Brunswick, GA 31523
    Got the LCA mounts and spring perches welded up. Gonna setup the calipers. brackets, and try and get the truss burned in tomorrow. Might even start on the plumbing.
    Almost set the apartment complex on fire. Lit all the excess acetone on the ground on fire. Had to make a dash for the fire extinguisher, as you can tell from all the chemical compound on the ground.
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  5. #55 Re: SOLITUDE
    Brunswick, GA 31523
    Got the rest of the suspension brackets welded on this afternoon. Spent an hour searching for the spacers and nuts and bolts for the axle shaft retainers. Went through everything. Got a few places left to look tomorrow. But, gonna weld on the caliper brackets and do the brakes tomorrow.
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  6. #56 Re: SOLITUDE
    Member 96_zjlarado's Avatar
    Gaston, OR
    lookin good man.
    if you still have the old drum backing plates, just cut the 4 bolt rectangular section out of the middle of them. that way you know it's the proper thickness. when you go to tack those ballistic caliper brackets on put the pads in place, mount the rotors on the axle shafts with one or 2 lug nuts and make sure your pad sits flush with the rotor or else you'll have uneven pad wear. I wouldn't know this from experience or anything . Oh, and the screw valve cover on your shielding gas bottle for your welder is the same size as the axle tube on the 9" where the bracket mounts to. so you can use that to trace a line on the backet and grid away. i wish i would have known that on my first bracket instead of the second one. would have saved me a lot of time. grind a little, dry fit, grind a little more, dry fit, grind a little more..... yadda yadda yadda...... it sucked!
    Weekend play toy: 96 ZJ 4.0L
    HP44- 4.88's and detroit locker
    Ford 9"- 4.86's and detroit locker
    Clayton's 7" long arm with high clearance axle bracket kits front and rear
    35x12.5 cooper stt's on 15x10 "rock krawler" rims with 4" bs.
    ORGS super nerfs
    Daily driver:
    05 Mitsubishi Lancer Evo VIII MR
    400hp and some eye candy
  7. #57 Re: SOLITUDE
    Brunswick, GA 31523
    yup I believe it. I actually bought some spacers that fit perfectly in there, so I get to sell the hole drum brake kit on ebay and make back a few dollars. Thanks for the advise.
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  8. #58 Re: SOLITUDE
    Brunswick, GA 31523
    It's raining today.... this is what I did last night....
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  9. #59 Re: SOLITUDE
    Apr 2006
    Canada, somewhere
    hmm painting brake rotors, that looks like a great idea
  10. #60 Re: SOLITUDE
    Dinwiddie, VA
    Why did you paint the rotors? They were new and looked good already. All the paint is going to come off where the pad contacts the rotor anyway. They'll end up looking like shit in the end.
    "Matt"
  11. #61 Re: SOLITUDE
    Brunswick, GA 31523
    I know the pads are just gonna peel off all the paint where they contact the rotor. I didn't want the rest of the rotor to get all that surface rust. It was just easier to paint the whole thing than tape it off.
    I.Was.Bored. And drunk......
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  12. #62 Re: SOLITUDE
    Senior Member cashflowdub's Avatar
    alex bay
    they wouldnt have gotten rust
    95 Zj on 32s
  13. #63 Re: SOLITUDE
    Midlothian Virginia
    Quote Originally Posted by cashflowdub View Post
    x2 on the not rusting thing
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  14. #64 Re: SOLITUDE
    Virginia, Hburg
    Well at least they look pretty?
    WJ-OME-JKS-KEVINS-32' BFGS-SOLD
    WK-DayStar-Spidertrax-BFGS-whoohoo
    Search, helping dumbasses everywhere.
  15. #65 Re: SOLITUDE
    Wow. That's kinda retarded.
  16. #66 Re: SOLITUDE
    Brunswick, GA 31523
    What I was going for.....
    1993 Jeep ZJ V8 5.2
    LINK TO MY PAGE
  17. #67 Re: SOLITUDE
    Senior Member RiPPiNiTuP7's Avatar
    Dec 2004
    Ohio
    well one thing you missed....they didn't paint where the pad meets the rotor. that makes a little bit of a difference from what you did.
    -04' silver ram 1500. 5.7 hemi. 4x4. a few goodies.
    -98' chargold zj. 4.0/242. stocker.
    -09' black yamaha rhino SE. new offroad play toy.
    -96' black zj. 4.0/242. re 4.5" + 2" BB, 35" bfg at's, 8.8 w/ e-locker, open HP30, 4.56's, TW SYE & F/R driveshafts, currie steering, addco's F/R, ARB'ed, Warn 8k winch, & armor. - SOLD
  18. #68 Re: SOLITUDE
    Aug 2006
    Wa
    .....Im sure the NAGCA guys think its totally rad though?
    2003 WJ 4.7, Clayton's 7", 35" Goodyear MTR's, Sliders, ARB, yada yada yada....
  19. #69 Re: SOLITUDE
    Niagara Falls, NY
    sand the paint off the rotors, don't let the brake pads do it. The paint gums up the pads and makes a mess of everything.
  20. #70 Re: SOLITUDE
    Gaston, OR
    Quote Originally Posted by easymunny View Post
    OUCH!! double ouch if you would have said JU.
    ORGS super nerfs
    Daily driver:
  21. #71 Re: SOLITUDE
    Austin, TX
    You paint your parts funny colors just like zj95 does.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  22. #72 Re: SOLITUDE
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    no.. not quite.....
    I go for the "WTF?!?!" look
    Solitude goes for the "LOOK AT ME!! IM AN ATTENTION WHORE!!" look
    but it is cool.. he has a hot GF
  23. #73 Re: SOLITUDE
    Apr 2006
    Canada, somewhere
    not to mention the coefficient of friction of a painted suraface is much lower than an unpainted suface. so have fun not being able to stop when you think you can. but if your going to keep the paint you might as well wax or armour all them to keep em shiny
    the numbers i could find:
    non painted: 0.78
    painted: 0.39
  24. #74 Re: SOLITUDE
    Houston, TX
    nope hes even catching shit for it over there... but says he is now going to wire wheel the paint off. nice looking dif cover though! you should maybe paint just the top portion of the logo silver or something.
    I knew a guy back in high school that would spray his engine belts with WD40 "because they were squealing"
  25. #75 Re: SOLITUDE
    Member midwestxj's Avatar
    Mar 2007
    illinois
    [quote=SOLITUDE;162715]I know the pads are just gonna peel off all the paint where they contact the rotor. I didn't want the rest of the rotor to get all that surface rust. It was just easier to paint the whole thing than tape it off.
    Maaaan, have you smoked yourself retarded?????
    jdhutton---not sure why you wanna go fast in a lifted jeep. its kinda like strapping a jet pack to a retard. just doesnt make sence.
