8.8 is installed
Thread: 8.8 is installed
Results 1 to 23 of 23
  1. #1 8.8 is installed
    San Diego
    It started at Christmas, finally in with 4.88. Would have been sooner but had to install Rusty's LA's due to the stock LCA bracket ripping off from the frame.
    98 Grand Cherokee Limited
    Rusty's 5.5" High Clearance LA Kit
    35" Pro Comp Xtreme MT's
    8.8 /No-Slip Locker
    D30/LockRite Locker
    4.88's
    ARB Bumper/9K Summit Winch (T-Max)
    4.0, I-6, 63MM TB, Header, K&N filter
    Retired Navy
  2. #2 Re: 8.8 is installed
    Louisiana
    looks good
    the brake hardline/flex line mount looks kinda wierd. how fast is it off the like with 4.88 and 31's
  3. #3 Re: 8.8 is installed
    San Diego
    Not very, dosen't even seem like I changed from 3.73 to 4.88 off the line. But I haven't hammered it yet. Gotta break the gears in. And yea, I have to work on the brake lines, looks kinda tacky to me also, but then again flat black paint will cover that up.
    8.8 /No-Slip Locker
    D30/LockRite Locker
    4.88's
    Retired Navy
  4. #4 Re: 8.8 is installed
    Louisiana
    it looks like it would be a pita to take out the springs with the brackets right there, thats all
  5. #5 Re: 8.8 is installed
    San Diego
    Thats actually where the originals mount.
    8.8 /No-Slip Locker
    D30/LockRite Locker
    4.88's
    Retired Navy
  6. #6 Re: 8.8 is installed
    St. Louis
    why the loop in the hardline?
    1997 Limited on 35's, 7" long arm and F/R d44's with alloy's, superoints and other stuff.
  7. #7 Re: 8.8 is installed
    San Diego
    Its to long. I was testing a theory, seeing if the D35 stuff swapped over. I measured the ID where the brake line attaches to the caliper, both (Ford/Jeep)are .380. Still puzzles me how much brakeline is left over from the D35. I have to go get some shorter lines to put on.
    8.8 /No-Slip Locker
    D30/LockRite Locker
    4.88's
    Retired Navy
  8. #8 Re: 8.8 is installed
    Member Jsk8r1's Avatar
    Oct 2006
    Tucson AZ
    Thats weird, when i did my 8.8 swap i used the brake lines from the D35 and it worked out fine with no extra line.
    ZJ is no more
    "GO"...
  9. #9 Re: 8.8 is installed
    Your running 4.88's in a D30? Why?
    Dude 3/16" hardline is like a buck a foot at Napa....
  10. #10 Re: 8.8 is installed
    Oct 2006
    probably the same reason he's using Rusty's long arm.
    95zj 4.0 to 5.2 swap. Budget buggy build in progress.
  11. #11 Re: 8.8 is installed
    Sep 2006
    Chesapeake, VA
    Sorry not all of us can afford to put 8 miles of tubing and one tons under are shit.
  12. #12 Re: 8.8 is installed
    Senior Member nate's Avatar
    Palmer, AK
    Why not? That's what I run as well. Been fine for a couple years.
    03 Subaru WRX
    98 Dodge Ram 2500 CTD
    98 Jeep ZJ
    95 Dodge Ram 3500 CTD
  13. #13 Re: 8.8 is installed
    San Diego
    Quote Originally Posted by Locked98GC View Post
    I was testing a theory, seeing if the D35 stuff swapped over. I have to go get some shorter lines to put on.
    And what is wrong with Rusty's, everyone has their own opinion.
    This is a 8.8 post not a debate about which lift kit is better. Kinda like why didn't I just go with 404 Mogs . Hmmmmmmmm. I agree the LP D30 is not really good with the 33's (after the 31's get worn a bit more) and 4.88 but it works for now. I'm at least going to a HP 30 later with chromo axles. This is a build in progress as the wife won't open up the check book for everything up front. She does let it trickle out though.
    8.8 /No-Slip Locker
    D30/LockRite Locker
    4.88's
    Retired Navy
  14. #14 Re: 8.8 is installed
    Quote Originally Posted by nate View Post
    Two problems the 30 ring rear is puney and with 4.88's there is about 3/4 ring to pinion teeth enguagement. Bind up the 30 and hear things go boom.
  15. #15 Re: 8.8 is installed
    Quote Originally Posted by minydigger View Post
    Then why even build it? Did I even say the way I am building mine is the "right" way? No. But a D30 with 4.88's is not the right way.
  16. #16 Re: 8.8 is installed
    Palmer, AK
    4.88s aren't much worse than 4.56s. I think your thinking of the old 4.88s when they first came out and had a really small contact spot. It's a none issue with the cut they do on them now.
    And if it blows.. oh well. 2 years running on Q78 TSLs and no damage to the locked D30 yet.
    03 Subaru WRX
    98 Jeep ZJ
  17. #17 Re: 8.8 is installed
    How would one contact spot differ from another if numerically they are the same?
  18. #18 Re: 8.8 is installed
    Palmer, AK
    The old 4.88s and the new ones?
    The gears are cut differently.
    03 Subaru WRX
    98 Jeep ZJ
  19. #19 Re: 8.8 is installed
    You are wrong. Mine is only about 160 feet.
  20. #20 Re: 8.8 is installed
    Salt Lake City
    Chad's hardcore. He's wheeled at least 5 times in the last 3 years
  21. #21 Re: 8.8 is installed
    Oct 2006
    Tucson AZ
    5 times in the last 3 years ahaha pretty hardcore
    ZJ is no more
    "GO"...
  22. #22 Re: 8.8 is installed
    You get that 8.8 under your junk?Yet
  23. #23 Re: 8.8 is installed
    Jan 2014
    usa
    What style drive shaft are you running? Any high speed harmonic noise?
