Aggie ZJ - Page 3
Thread: Aggie ZJ
Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 389
  1. #51 Re: Mutt
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    no.... stupid ticket took all my money...
    traffic school tomarrow.... son of a......
  2. #52 Re: Mutt
    Austin, TX
    Not much of an update, had to sell the 4Runner. Too many problems, too little time. Mainly just did some routine maintenance, change tranny filter/fluid, flush cooling system, change oil, fixed ebrake, replaced fuel filter, found out the grinding noise upfront was a loose caliper bolt, tightened it up and no more grinding.
    Also, with the help of Jerod's write up (http://www.mallcrawlin.com/forum/showthread.php?t=2881) I fixed the rear main seal leak as well as the oil pump. Was pretty simple, just it is a PITA to drop the oil pan, supporting the whole Jeep to where the front axle can drop definatly clears up a lot of space to take the pan off... just make sure you're head isn't under it when it finally comes down .
    Should hopefully be getting a J-20 steering box, if not just a regular Waggy box, by the end of the week or beginning next week. Have been thinking about making my rear LCA's adjustable too (since it would be cheaper than buying a new pair). Also need to get some more trimming done sometime. Anyways, here's some pics for fun...
    Mmm, bottom of the engine block.
    Main cap with the old seal, and then the cap with the new seal in. EDIT: NOTICE WHICH DIRECTION THE LIP OF THE SEALS ARE FACING, I INSTALLED THE ONE ON THE CAP WRONG (HOPEFULLY THE ONE IN THE BLOCK IS RIGHT). TAKE YOUR TIME AND MAKE SURE ITS RIGHT. I have driven about 300 miles already since doing this and have had no signs of leaks just yet.
    New and old seal.
    Old and new pump.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  3. #53 Re: Mutt
    Houston, TX
    or you could just buy my old ones when you come over this weekend
  4. #54 Re: Mutt
    Surrey, BC Canada
    Is it just me... or is the seal backwards from the before photo? The small/large lips on the seals are opposite. Correct me if I'm wrong....
    And as a side note.... this is great news... I thought the rear main would be a 1 piece seal and I'd have to pull the transmission. Thanks for the link to that rear main seal thread.
  5. #55 Re: Aggie ZJ (Beaten to hell)
    Senior Member tywilson88's Avatar
    your right, i think someone my have a leak later.
    Quote Originally Posted by Four Play View Post
    I'll probably go to Hell for that but fawk it, I'll upgrade my 1st class ticket and go for another pack of peanuts... cremation cost are on the rise anyway.
  6. #56 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    Shit, you're right good catch. I'm an idiot, see what happens when you rush things? Thanks for pointing that out.
    Well it looks like I'll be going back in there next oil change, have driven about 300 miles and haven't seen any sign of leaks yet... hopefully it will hold out until I can fix it.
    So here's some more advise to doing the fix, make sure the seals are installed correctly.
    I also edited the first post noting that they are installed wrong, hopefully others can use it and not make the same mistake. On a good note though the Jeep does feel like it runs a little better!
    Jon
    95 ZJ, it gone.
  7. #57 Re: Aggie ZJ (Beaten to hell)
    you're missing a bolt on your motor mount
  8. #58 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    Quote Originally Posted by zj95 View Post
    Ass, yours is too.
    There is a bolt missing though, funny thing is I've never messed with the mounts on the Jeep.
    Jon
    95 ZJ, it gone.
  9. #59 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    Decided to cut the front bumper and front part of the inner fender since it was starting to take some good chunks out of my tires.
    One side done.
    Here you can see how bad it was rubbing.
    All finished.
    All the crap that was cut off.
    Tomorrow I'll be heading down to Katy to show another MCer how awesome 33s are. Get to play a little tire swap for some free/cheap parts! Also, hopefully it will be alright with him if I cleaned up the cuts some and added some paint to the sides and inner fender while I'm there.
    Oh I also went underneath and put in the motor mount bolt that was missing, dunno how that disappeared.
    Jon
    95 ZJ, it gone.
  10. #60 Re: Aggie ZJ (Beaten to hell)
    Senior Member corrupt143's Avatar
    Indiana
    Looks good. Thats just about how Ive been thinking about cutting it. Thanks for the preview.
    Chris- 97 ZJ, 4.0, some lift, black tires and some Autozone valve caps.
  11. #61 Re: Aggie ZJ (Beaten to hell)
    Aug 2007
    College Station, TX
    pfffffff
    fffffffffsfffsffsfpffhfhf
    fpfff
    f
    1998 Nissan Quest GXE
    3.9L......other stuff...... like a sunroof.......
    2005 TJ Willys
  12. #62 Re: Aggie ZJ (Beaten to hell)
    Houston, TX
    I wonder who that is.... don't worry about the tire swaparoo I already decided to get some Maxxis ones like yours sometime soon. I still have my oily axle "shafts" for you
  13. #63 Re: Aggie ZJ (Beaten to hell)
    looks good, nice and clean
  14. #64 Re: Aggie ZJ (Beaten to hell)
    Jun 2005
    Paradise, Newfoundland Canada
    I recognize that front bumper cut from some where.....
    Anthony
  15. #65 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    I have noo idea what you're talking about...
    Yeah only difference on mine is that I didn't go all the way to the 'frame' rail.
    Jon
    95 ZJ, it gone.
  16. #66 Re: Aggie ZJ (Beaten to hell)
    Jackson NJ/ Daytona Beach FL
    Is your jeep doing the gangsta lean or is that sidewalk slanted?
    On a side note, where did you buy your shovel? It seems to be holding up really well for the big hole you keep digging for yourself.
    '02 WJ- 2" RE BB/1 " EE rear BB, 31" Firestone Destinations, RE Twin tube shocks, DoubleJZ rear shock mod, JKS BPE's, JKS/KOR adj Trackbar w/ Rockwell bushings, Magnaflow exhaust, homebrew intake, torque management delete, and a whole lot of aviation grade ingenuity.
  17. #67 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    Quote Originally Posted by Firestarter View Post
    I noticed that this weekend, leans to the passenger side. I do have a bunch of crap in the Jeep so tomorrow I'm going to unload it all and take some measurements to see whats going on.
    Jon
    95 ZJ, it gone.
  18. #68 Re: Aggie ZJ (Beaten to hell)
    Junior Member stlcrawlers's Avatar
    Oct 2007
    St. Louis
    hey sorry to ask but where'd you ge that nice tire carrier i need one?
    3 inch procomp lift,31 pro comp A/T, k&n system, cat back ehaust, airraid throttle body spacer, alpine head unit, mtx sub
    SOON= custom basket or tire carrier, new speakers, maybe coil spacers
    `______
    /l ,[____],
    l---L –0lllllll0- <------ Before
    ()_) ()_)--o-)_)
    .`______
    ./l ,[____],
    .l---L –0lllllll0- <------ After
    ()_) ()_)--o-)_)
  19. #69 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    Quote Originally Posted by stlcrawlers View Post
    I bought that one off of Ronnie (WesTexZJ) a while back. It's a Don-a-vee tire carrier, they're about as rare as the Mopar ones. They'll show up every now and then on eBay.
    Jon
    95 ZJ, it gone.
  20. #70 Re: Aggie ZJ (Beaten to hell)
    Oct 2007
    St. Louis
    is it pretty heavy i only have a 3 inch lift and i already need to coils in the back.
    `______
    /l ,[____],
    ()_) ()_)--o-)_)
    .`______
    ./l ,[____],
    ()_) ()_)--o-)_)
  21. #71 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    It wasn't too heavy, I'd say about 50 lbs or so... maybe a little more. It does hang down low though, I had it caught up in the ground a few times at 3.5".
    Jon
    95 ZJ, it gone.
  22. #72 Re: Aggie ZJ (Beaten to hell)
    Houston, TX
    I had that on mine and figured it out that it was the way the coil was positioned in the lower bucket... the way it was sitting made the pass side sit about 1/2-3/4 inch lower
  23. #73 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    That's about how much my pass side is sitting too, I'll have to check that out.
    Jon
    95 ZJ, it gone.
  24. #74 Re: Aggie ZJ (Beaten to hell)
    Houston, TX
    yeah for a little while I thought it was my front sway that was bent....
  25. #75 Re: Aggie ZJ (Beaten to hell)
    Austin, TX
    Picked up a J-20 steering box from NAPA, hope to get it installed over the Thanksgiving break along with doing more trimming for the rear and figuring out a screeching noise.
    Jon
    95 ZJ, it gone.
