I started building this a little over a year ago to tow behind a long since gone project. I have far to many projects now and wanted to know if anybody wanted a sweet 4X4 trailer that needs little work to be done.
The frame was designed by me and built by a local fab. shop so it is perfectly straight and stout. Frame built out of 4" C channel and a 4"x4" center tube. If I remember correctly the tub is built out of 1/16th inch steel sheet that was professionally bent, and end caps welded on. The fenders are made out of the same heavy steel as the tub. They were also custom bent for me. Top rail is 1"x1" square tubing welded and smoothed. The tailgate is made out of 1"x1" square tube and has a removable panel. (Just incase it gets damaged) There are hooks on all 4 sides to attach a cargo tarp or net (included).
All side marker lights are LED and the rear are stop,turn,tail standard lights. All lights and wiring is included.
Has a heavy duty folding jack on the front for easy movement when no hook to the tow rig.
Heavy duty safety chains are also included.
Has a brand new 3000lb torsion axle and leaf springs for a nice ride. The axle has provisions so that you could do a spring over to get the trailer a little higher if wanted.
The wheels and tires are brand new 35" supper swamper SSR's mounted on steelie's with 6 on 5.5 bolt pattern (matched the tow rig)
It has an adjustable pintle on the front to accommodate different height tow rigs.
Welded in to the tub is a High lift jack mount. (see pic's)
Dimensions:
Tub:58.5" wide x 6' 1" long
Total length: Tip to Tail 10' 7"
Total width including tires:76"
Here is what it needs:
Latch for tail gate. Full paint (fenders,tub,frame) and wire up all the lights.
What is included: Trailer as pictured, all lights and wiring, pintle, and safety chains.
I have a ton of time and money invested in this and will hate to see it go but I have too many projects.
Have title and Vin Plate in hand!!1
$2000 obo Reduced to $1800
Located in Denver Colorado. Could deliver for extra charge.
